Im getting an error 13 which says: Library Installation not successful: Moving extracted archive to destination dir: library not valid
****this shows when i tried to look up for the error. Please help ****
PS C:\Program Files\Arduino IDE> ".\Arduino IDE"
.\Arduino IDE
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE".
Arduino IDE 2.2.1
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.2.1" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.34.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2023-08-31T14:35:44.802Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.2.1","cliVersion":"0.34.0","buildDate":"2023-08-31T14:35:44.802Z"}
Starting backend process. PID: 12664
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/tonyh/.arduinoIDE'
Configuring to accept webviews on '^.+.webview..+$' hostname.
2023-12-03T03:12:26.476Z root INFO Backend Object.initialize: 5.0 ms [Finished 0.529 s after backend start]
2023-12-03T03:12:26.483Z root INFO Backend Object.configure: 4.3 ms [Finished 0.529 s after backend start]
2023-12-03T03:12:26.483Z root INFO Backend a.onStart: 1.9 ms [Finished 0.529 s after backend start]
2023-12-03T03:12:26.484Z root INFO Backend a.configure: 0.3 ms [Finished 0.569 s after backend start]
2023-12-03T03:12:26.485Z root INFO Backend u.onStart: 0.1 ms [Finished 0.569 s after backend start]
2023-12-03T03:12:26.486Z root INFO Backend d.configure: 0.1 ms [Finished 0.569 s after backend start]
2023-12-03T03:12:26.487Z root INFO Backend d.initialize: 40.5 ms [Finished 0.569 s after backend start]
2023-12-03T03:12:26.488Z root INFO Backend c.onStart: 0.3 ms [Finished 0.569 s after backend start]
2023-12-03T03:12:26.488Z root INFO Backend s.configure: 8.0 ms [Finished 0.578 s after backend start]
2023-12-03T03:12:26.491Z config INFO >>> Initializing CLI configuration...
2023-12-03T03:12:26.491Z root INFO Backend c.initialize: 0.6 ms [Finished 0.578 s after backend start]
2023-12-03T03:12:26.492Z root INFO Backend P.onStart: 1.2 ms [Finished 0.579 s after backend start]
2023-12-03T03:12:26.493Z config INFO Loading CLI configuration from c:\Users\tonyh.arduinoIDE\arduino-cli.yaml...
2023-12-03T03:12:26.493Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-12-03T03:12:26.493Z root INFO Backend s.initialize: 0.4 ms [Finished 0.580 s after backend start]
2023-12-03T03:12:26.494Z root INFO Backend w.onStart: 1.3 ms [Finished 0.581 s after backend start]
2023-12-03T03:12:26.494Z root INFO Backend r.configure: 2.7 ms [Finished 0.582 s after backend start]
2023-12-03T03:12:26.494Z discovery-log INFO start
2023-12-03T03:12:26.495Z discovery-log INFO start new deferred
2023-12-03T03:12:26.495Z root INFO Backend d.initialize: 0.4 ms [Finished 0.582 s after backend start]
2023-12-03T03:12:26.495Z root INFO Backend y.onStart: 2.9 ms [Finished 0.585 s after backend start]
2023-12-03T03:12:26.495Z root INFO Backend r.configure: 2.9 ms [Finished 0.586 s after backend start]
2023-12-03T03:12:26.495Z root INFO Backend s.onStart: 0.7 ms [Finished 0.588 s after backend start]
2023-12-03T03:12:26.495Z root INFO Backend h.configure: 0.9 ms [Finished 0.588 s after backend start]
2023-12-03T03:12:26.496Z root INFO Backend a.configure: 0.5 ms [Finished 0.589 s after backend start]
2023-12-03T03:12:26.496Z root INFO Backend s.configure: 0.1 ms [Finished 0.589 s after backend start]
2023-12-03T03:12:26.496Z root INFO Backend l.configure: 0.1 ms [Finished 0.590 s after backend start]
2023-12-03T03:12:26.499Z root INFO Theia app listening on http://localhost:50579.
2023-12-03T03:12:26.500Z root INFO Finished starting backend application: 5.0 ms [Finished 0.593 s after backend start]
2023-12-03T03:12:26.502Z root WARN The local plugin referenced by local-dir:/c%3A/Users/tonyh/.arduinoIDE/plugins does not exist.
2023-12-03T03:12:26.512Z root WARN The local plugin referenced by local-dir:/c%3A/Users/tonyh/.arduinoIDE/extensions does not exist.
2023-12-03T03:12:26.512Z root WARN The local plugin referenced by local-dir:C:\Users\tonyh.arduinoIDE\plugins does not exist.
2023-12-03T03:12:26.539Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\Users\tonyh\AppData\Local\Arduino15","downloads":"C:\Users\tonyh\AppData\Local\Arduino15\staging","user":"C:\Users\tonyh\OneDrive\Documents\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-12-03T03:12:26.540Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-12-03T03:12:26.540Z config INFO Loaded the CLI configuration.
2023-12-03T03:12:26.556Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/tonyh/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/tonyh/OneDrive/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-12-03T03:12:26.556Z config INFO Validating the CLI configuration...
2023-12-03T03:12:26.557Z config INFO The CLI config is valid.
2023-12-03T03:12:26.561Z config INFO <<< Initialized the CLI configuration.
2023-12-03T03:12:26.606Z root INFO Resolve plugins list: 113.0 ms [Finished 0.699 s after backend start]
2023-12-03T03:12:26.712Z daemon INFO time="2023-12-02T22:12:26-05:00" level=info msg="Using config file: c:\Users\tonyh\.arduinoIDE\arduino-cli.yaml"
time="2023-12-02T22:12:26-05:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-12-02T22:12:26-05:00" level=info msg="Executing arduino-cli daemon"
Daemon is now listening on 127.0.0.1:50580
{"IP":"127.0.0.1","Port":"50580"}
2023-12-03T03:12:26.712Z daemon INFO Daemon is running.
2023-12-03T03:12:26.898Z daemon INFO time="2023-12-02T22:12:26-05:00" level=info msg="Checking signature" index="C:\Users\tonyh\AppData\Local\Arduino15\package_index.json" signatureFile="C:\Users\tonyh\AppData\Local\Arduino15\package_index.json.sig" trusted=true
time="2023-12-02T22:12:26-05:00" level=info msg="Loading hardware from: C:\Users\tonyh\AppData\Local\Arduino15\packages"
time="2023-12-02T22:12:26-05:00" level=info msg="Loading package arduino from: C:\Users\tonyh\AppData\Local\Arduino15\packages\arduino\hardware"
time="2023-12-02T22:12:26-05:00" level=info msg="Missing signature file" index="C:\Users\tonyh\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\installed.json"
time="2023-12-02T22:12:26-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2023-12-02T22:12:26-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2023-12-02T22:12:26-05:00" level=info msg="Checking existence of 'tools' path: C:\Users\tonyh\AppData\Local\Arduino15\packages\arduino\tools"
time="2023-12-02T22:12:26-05:00" level=info msg="Loading tools from dir: C:\Users\tonyh\AppData\Local\Arduino15\packages\arduino\tools"
time="2023-12-02T22:12:26-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2023-12-02T22:12:26-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2023-12-02T22:12:26-05:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2023-12-02T22:12:26-05:00" level=info msg="Loading package builtin from: C:\Users\tonyh\AppData\Local\Arduino15\packages\builtin"
time="2023-12-02T22:12:26-05:00" level=info msg="Checking existence of 'tools' path: C:\Users\tonyh\AppData\Local\Arduino15\packages\builtin\tools"
time="2023-12-02T22:12:26-05:00" level=info msg="Loading tools from dir: C:\Users\tonyh\AppData\Local\Arduino15\packages\builtin\tools"
time="2023-12-02T22:12:26-05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2023-12-02T22:12:26-05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2023-12-02T22:12:26-05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2023-12-02T22:12:26-05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2023-12-02T22:12:26-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2023-12-02T22:12:26-05:00" level=info msg="Adding libraries dir" dir="C:\Users\tonyh\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries" location=platform
time="2023-12-02T22:12:26-05:00" level=info msg="Loading libraries index file" index="C:\Users\tonyh\AppData\Local\Arduino15\library_index.json"
2023-12-03T03:12:27.085Z daemon INFO time="2023-12-02T22:12:27-05:00" level=info msg="Adding libraries dir" dir="C:\Users\tonyh\AppData\Local\Arduino15\libraries" location=ide
time="2023-12-02T22:12:27-05:00" level=info msg="Adding libraries dir" dir="C:\Users\tonyh\OneDrive\Documents\Arduino\libraries" location=user
2023-12-03T03:12:27.144Z discovery-log INFO start request start watch
2023-12-03T03:12:27.145Z discovery-log INFO start requested start watch
2023-12-03T03:12:27.145Z discovery-log INFO start resolved watching
2023-12-03T03:12:27.249Z daemon INFO time="2023-12-02T22:12:27-05:00" level=info msg="starting discovery builtin:mdns-discovery process"
time="2023-12-02T22:12:27-05:00" level=info msg="starting discovery builtin:serial-discovery process"
time="2023-12-02T22:12:27-05:00" level=info msg="started discovery builtin:serial-discovery process"
time="2023-12-02T22:12:27-05:00" level=info msg="sending command HELLO 1 "arduino-cli 0.34.0" to discovery builtin:serial-discovery"
time="2023-12-02T22:12:27-05:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2023-12-02T22:12:27-05:00" level=info msg="sending command HELLO 1 "arduino-cli 0.34.0" to discovery builtin:mdns-discovery"
time="2023-12-02T22:12:27-05:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
time="2023-12-02T22:12:27-05:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2023-12-02T22:12:27-05:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
time="2023-12-02T22:12:27-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
time="2023-12-02T22:12:27-05:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
time="2023-12-02T22:12:27-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
time="2023-12-02T22:12:27-05:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM3"
2023-12-03T03:12:27.251Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Arduino Uno","fqbn":"arduino:avr:uno","isHidden":false}],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x0043"],["serialNumber","95137313932351103142"],["vid","0x2341"]],"hardwareId":"95137313932351103142"}},"error":""}
2023-12-03T03:12:27.598Z root INFO Deploy plugins list: 113.0 ms [Finished 1.692 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-12-03T03:12:28.131Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 263.3 ms [Finished 1.556 s after frontend start]
2023-12-03T03:12:28.138Z root WARN A command editor.action.toggleStickyScroll is already registered.
[2248:1202/221228.267:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221228.296:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
2023-12-03T03:12:28.390Z root INFO Start frontend contributions: 579.9 ms [Finished 1.809 s after frontend start]
2023-12-03T03:12:28.390Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-12-03T03:12:28.411Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-12-03T03:12:28.412Z root INFO >>> Restoring the layout state...
2023-12-03T03:12:28.413Z root INFO ------- SERIALIZED LAYOUT DATA -------
2023-12-03T03:12:28.414Z root INFO {"version":5,"mainPanel":{"main":null},"mainPanelPinned":[],"bottomPanel":{"config":{"main":null},"pinned":[],"expanded":false},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{"parts":[{"partId":"debug:threads:-1","collapsed":false,"hidden":false,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"debug:threads"},"innerWidgetState":"{}"}},{"partId":"debug:frames:-1","collapsed":false,"hidden":false,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"debug:frames"},"innerWidgetState":"{}"}},{"partId":"debug:variables:-1","collapsed":false,"hidden":false,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"debug:variables"},"innerWidgetState":"{}"}},{"partId":"debug:watch:-1","collapsed":false,"hidden":false,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"debug:watch"},"innerWidgetState":"{}"}},{"partId":"debug:breakpoints:-1","collapsed":false,"hidden":false,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"debug:breakpoints"},"innerWidgetState":"{}"}},{"partId":"plugin-view:cortex-debug.peripherals","collapsed":true,"hidden":true,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"plugin-view","options":{"id":"plugin-view:cortex-debug.peripherals","viewId":"cortex-debug.peripherals"}},"innerWidgetState":"{\"label\":\"Cortex Peripherals\",\"widgets\":[],\"suppressUpdateViewVisibility\":false,\"currentViewContainerId\":\"debug\"}"}},{"partId":"plugin-view:cortex-debug.registers","collapsed":true,"hidden":true,"originalContainerId":"debug:view-container:-1","originalContainerTitle":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true},"widget":{"constructionOptions":{"factoryId":"plugin-view","options":{"id":"plugin-view:cortex-debug.registers","viewId":"cortex-debug.registers"}},"innerWidgetState":"{\"label\":\"Cortex Registers\",\"widgets\":[],\"suppressUpdateViewVisibility\":false,\"currentViewContainerId\":\"debug\"}"}}],"title":{"label":"debug","iconClass":"codicon codicon-debug-alt","closeable":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{"parts":[{"partId":"search-in-workspace","collapsed":false,"hidden":false,"originalContainerId":"search-view-container","originalContainerTitle":{"label":"Search","iconClass":"codicon codicon-search","closeable":true},"widget":{"constructionOptions":{"factoryId":"search-in-workspace"},"innerWidgetState":"{\"matchCaseState\":{\"className\":\"codicon codicon-case-sensitive\",\"enabled\":false,\"title\":\"Match Case\"},\"wholeWordState\":{\"className\":\"codicon codicon-whole-word\",\"enabled\":false,\"title\":\"Match Whole Word\"},\"regExpState\":{\"className\":\"codicon codicon-regex\",\"enabled\":false,\"title\":\"Use Regular Expression\"},\"includeIgnoredState\":{\"className\":\"codicon codicon-eye\",\"enabled\":false,\"title\":\"Include Ignored Files\"},\"showSearchDetails\":false,\"searchInWorkspaceOptions\":{\"matchCase\":false,\"matchWholeWord\":false,\"useRegExp\":false,\"includeIgnored\":false,\"include\":[],\"exclude\":[],\"maxResults\":2000},\"searchTerm\":\"\",\"replaceTerm\":\"\",\"showReplaceField\":false,\"searchHistoryState\":{\"history\":[],\"index\":0},\"replaceHistoryState\":{\"history\":[],\"index\":0},\"includeHistoryState\":{\"history\":[],\"index\":0},\"excludeHistoryState\":{\"history\":[],\"index\":0}}"}}],"title":{"label":"Search","iconClass":"fa fa-arduino-search","closeable":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]}}
2023-12-03T03:12:28.415Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2023-12-03T03:12:28.453Z root INFO <<< The layout has been successfully restored.
2023-12-03T03:12:28.456Z root INFO Initialize the workbench layout: 54.6 ms [Finished 1.905 s after frontend start]
2023-12-03T03:12:28.457Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-12-03T03:12:28.525Z root INFO [df38b3b2-7ce0-4be2-9b14-33ff12c3b730] Waiting for backend deployment: 187.3 ms [Finished 1.973 s after frontend start]
2023-12-03T03:12:29.069Z root INFO [hosted-plugin: 18472] PLUGIN_HOST(18472) starting instance
2023-12-03T03:12:29.639Z root INFO [df38b3b2-7ce0-4be2-9b14-33ff12c3b730] Sync of 23 plugins: 1088.5 ms [Finished 3.062 s after frontend start]
2023-12-03T03:12:29.640Z root INFO [df38b3b2-7ce0-4be2-9b14-33ff12c3b730] Loading plugin contributions
2023-12-03T03:12:29.641Z root INFO [df38b3b2-7ce0-4be2-9b14-33ff12c3b730] Load contributions of 23 plugins: 27.6 ms [Finished 3.089 s after frontend start]
2023-12-03T03:12:29.648Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-12-03T03:12:29.649Z root WARN a registered grammar configuration for 'cpp' language is overridden
[2248:1202/221229.940:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221229.952:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
2023-12-03T03:12:29.970Z root INFO Replace loading indicator with ready workbench UI (animation): 1203.5 ms [Finished 3.112 s after frontend start]
2023-12-03T03:12:29.975Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-12-03T03:12:29.976Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-12-03T03:12:29.977Z root INFO Frontend application start: 1861.5 ms [Finished 4.053 s after backend start]
[2248:1202/221230.025:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
Checking for update
[2248:1202/221230.104:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221230.114:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221230.130:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221230.148:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221230.163:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221230.170:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221230.179:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221230.192:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221230.219:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
Update for version 2.2.1 is not available (latest version: 2.2.1, downgrade is allowed).
2023-12-03T03:12:30.414Z root ERROR ---- !!!SLOW!!! DURATION: search took 389.855 ms. Args: [{"type":"Updatable"}] ----
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
2023-12-03T03:12:30.452Z root ERROR Uncaught Exception: Error: transport close
2023-12-03T03:12:30.452Z root ERROR Error: transport close
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1071644
at Map.forEach ()
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1071623
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1039338
at i.invoke (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1039428)
at a.fire (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1041222)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1066508
at Map.forEach ()
at Object. (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1066478)
at e.dispose (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1032513)
2023-12-03T03:12:30.453Z root ERROR Uncaught Exception: Error: transport close
2023-12-03T03:12:30.453Z root ERROR Error: transport close
at Map.forEach ()
at Map.forEach ()
2023-12-03T03:12:30.464Z fwuploader ERROR Error: Process exited with exit code: 1
at ChildProcess. (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:603385)
at ChildProcess.emit (node:events:513:28)
at ChildProcess._handle.onexit (node:internal/child_process:291:12)
2023-12-03T03:12:30.465Z root ERROR Request updatableBoards failed with error: Process exited with exit code: 1 Error: Process exited with exit code: 1
2023-12-03T03:12:31.061Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 164.9 ms [Finished 0.611 s after frontend start]
2023-12-03T03:12:31.066Z root WARN A command editor.action.toggleStickyScroll is already registered.
[2248:1202/221231.126:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221231.160:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
2023-12-03T03:12:31.180Z root INFO Start frontend contributions: 339.8 ms [Finished 0.732 s after frontend start]
2023-12-03T03:12:31.182Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-12-03T03:12:31.186Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-12-03T03:12:31.189Z root INFO >>> Restoring the layout state...
2023-12-03T03:12:31.189Z root INFO <<< Nothing to restore.
2023-12-03T03:12:31.207Z root INFO Initialize the workbench layout: 17.4 ms [Finished 0.766 s after frontend start]
2023-12-03T03:12:31.222Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-12-03T03:12:31.240Z root INFO [abfd6636-dc16-49b8-bc1c-9a74abb46d59] Waiting for backend deployment: 72.3 ms [Finished 0.801 s after frontend start]
2023-12-03T03:12:31.757Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876) starting instance
2023-12-03T03:12:32.156Z root INFO [abfd6636-dc16-49b8-bc1c-9a74abb46d59] Sync of 23 plugins: 896.2 ms [Finished 1.698 s after frontend start]
2023-12-03T03:12:32.157Z root INFO [abfd6636-dc16-49b8-bc1c-9a74abb46d59] Loading plugin contributions
2023-12-03T03:12:32.157Z root INFO [abfd6636-dc16-49b8-bc1c-9a74abb46d59] Load contributions of 23 plugins: 20.6 ms [Finished 1.718 s after frontend start]
2023-12-03T03:12:32.167Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-12-03T03:12:32.167Z root WARN a registered grammar configuration for 'cpp' language is overridden
[2248:1202/221232.539:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221232.543:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
2023-12-03T03:12:32.543Z root INFO Frontend application start: 1500.3 ms [Finished 6.636 s after backend start]
2023-12-03T03:12:32.553Z root INFO Replace loading indicator with ready workbench UI (animation): 1059.8 ms [Finished 1.845 s after frontend start]
[2248:1202/221232.561:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
2023-12-03T03:12:32.564Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-12-03T03:12:32.566Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-12-03T03:12:32.634Z root INFO Executing startup tasks:
2023-12-03T03:12:32.635Z root INFO - 'arduino-use-inherited-boards-config' , args: [{},{}]
[2248:1202/221232.660:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
2023-12-03T03:12:32.887Z root ERROR ---- !!!SLOW!!! DURATION: search took 248.465 ms. Args: [{"type":"Updatable"}] ----
[2248:1202/221232.900:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221232.902:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221232.910:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221232.925:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221232.937:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221232.944:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221232.949:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221232.983:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
2023-12-03T03:12:33.044Z root ERROR [hosted-plugin: 17876] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
2023-12-03T03:12:33.044Z root ERROR [hosted-plugin: 17876] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2023-12-03T03:12:33.053Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): PluginManagerExtImpl/init()
2023-12-03T03:12:33.055Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-arduino-api@0.1.2 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.106Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.107Z root INFO [hosted-plugin: 17876] Debugger contribution has been registered: cortex-debug
2023-12-03T03:12:33.108Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.109Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.109Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.111Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.112Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.114Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-cs@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.115Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-de@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.117Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-es@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.117Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-fr@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.118Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.119Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-it@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.120Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-ja@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.120Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-ko@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.120Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.121Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-pl@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.122Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-pt-BR@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.123Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-ru@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.123Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-tr@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.124Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.124Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-zh-hans@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.125Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): initializing(vscode-language-pack-zh-hant@1.78.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-03T03:12:33.130Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2023-12-03T03:12:33.136Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-12-03T03:12:33.197Z root INFO [abfd6636-dc16-49b8-bc1c-9a74abb46d59] Starting plugins.
2023-12-03T03:12:33.215Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-12-03T03:12:33.246Z root INFO [hosted-plugin: 17876] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-12-03T03:12:33.251Z root INFO [hosted-plugin: 17876] GDB server console created
2023-12-03T03:12:33.258Z root INFO [abfd6636-dc16-49b8-bc1c-9a74abb46d59] Start of 23 plugins: 1093.2 ms [Finished 2.820 s after frontend start]
[2248:1202/221344.393:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221344.409:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221344.434:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
2023-12-03T03:13:44.459Z daemon INFO time="2023-12-02T22:13:44-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
time="2023-12-02T22:13:44-05:00" level=info msg="Required tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2023-12-02T22:13:44-05:00" level=info msg="Required tool" tool="arduino:avrdude@6.3.0-arduino17"
2023-12-03T03:13:44.463Z daemon INFO time="2023-12-02T22:13:44-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
[2248:1202/221344.474:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
2023-12-03T03:13:44.487Z daemon INFO time="2023-12-02T22:13:44-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
2023-12-03T03:13:44.491Z daemon INFO time="2023-12-02T22:13:44-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
2023-12-03T03:13:44.512Z daemon INFO time="2023-12-02T22:13:44-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
2023-12-03T03:13:44.519Z daemon INFO time="2023-12-02T22:13:44-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
[2248:1202/221344.529:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
[2248:1202/221344.556:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
2023-12-03T03:13:44.575Z root INFO Starting language server: arduino:avr:uno
2023-12-03T03:13:44.579Z daemon INFO time="2023-12-02T22:13:44-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
2023-12-03T03:13:44.582Z daemon INFO time="2023-12-02T22:13:44-05:00" level=info msg="Required tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
[2248:1202/221344.583:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
2023-12-03T03:13:44.588Z daemon INFO time="2023-12-02T22:13:44-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
2023-12-03T03:13:44.598Z root INFO [hosted-plugin: 17876] PLUGIN_HOST(17876): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2023-12-03T03:13:45.716Z daemon INFO time="2023-12-02T22:13:45-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
time="2023-12-02T22:13:45-05:00" level=info msg="Required tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2023-12-02T22:13:45-05:00" level=info msg="Required tool" tool="arduino:avrdude@6.3.0-arduino17"
2023-12-03T03:13:45.718Z daemon INFO time="2023-12-02T22:13:45-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
2023-12-03T03:13:45.719Z daemon INFO time="2023-12-02T22:13:45-05:00" level=info msg="Required tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2023-12-02T22:13:45-05:00> & ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE".& ".\Arduino IDE"."arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2023-12-03T03:13:45.725Z daemon INFO time="2023-12-02T22:13:45-05:00" level=info msg="Adding libraries dir" dir="C:\Users\tonyh\AppData\Local\Arduino15\libraries" location=ide
2023-12-03T03:13:45.727Z daemon INFO time="2023-12-02T22:13:45-05:00" level=info msg="Adding libraries dir" dir="C:\Users\tonyh\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries" location=platform
time="2023-12-02T22:13:45-05:00" level=info msg="Adding libraries dir" dir="C:\Users\tonyh\OneDrive\Documents\Arduino\libraries" location=user
2023-12-03T03:13:47.079Z daemon INFO time="2023-12-02T22:13:47-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
time="2023-12-02T22:13:47-05:00" level=info msg="Required tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2023-12-02T22:13:47-05:00" level=info msg="Required tool" tool="arduino:avrdude@6.3.0-arduino17"
2023-12-03T03:13:47.081Z daemon INFO time="2023-12-02T22:13:47-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
2023-12-03T03:13:47.082Z daemon INFO time="2023-12-02T22:13:47-05:00" level=info msg="Required tool" tool="arduino:avrdude@6.3.0-arduino17"
2023-12-03T03:13:47.086Z daemon INFO time="2023-12-02T22:13:47-05:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.3.0"
2023-12-03T03:13:47.086Z daemon INFO time="2023-12-02T22:13:47-05:00" level=info msg="Required tool" tool="arduino:avrdude@6.3.0-arduino17"
[1460:1202/221426.007:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL is disabled, ANGLE is
