Questo è il file.h (MF522.cpp):
#include "SPI.h"
#include "MF522.h"
#include "Arduino.h"
#define uchar unsigned char
#define uint unsigned int
#define NORESET 5
#define chipSelectPin 10
//MF522::MF522()
//MF522::~MF522()
void MF522::Write_MFRC522(uchar addr, uchar val)
digitalWrite(chipSelectPin, LOW);
//0XXXXXX0
SPI.transfer((addr<<1)&0x7E);
SPI.transfer(val);
digitalWrite(chipSelectPin, HIGH);
uchar MF522::Read_MFRC522(uchar addr)
uchar val;
//:1XXXXXX0
SPI.transfer(((addr<<1)&0x7E) | 0x80);
val =SPI.transfer(0x00);
return val;
void MF522::SetBitMask(uchar reg, uchar mask)
uchar tmp;
tmp = Read_MFRC522(reg);
Write_MFRC522(reg, tmp | mask); // set bit mask
void MF522::ClearBitMask(uchar reg, uchar mask)
uchar tmp;
Write_MFRC522(reg, tmp & (~mask)); // clear bit mask
void MF522::AntennaOn(void)
uchar temp;
temp = Read_MFRC522(TxControlReg);
if (!(temp & 0x03))
SetBitMask(TxControlReg, 0x03);
void MF522::AntennaOff(void)
ClearBitMask(TxControlReg, 0x03);
void MF522::MFRC522_Reset(void)
Write_MFRC522(CommandReg, PCD_RESETPHASE);
uchar MF522::MFRC522_Request(uchar reqMode, uchar *TagType)
uchar status;
uint backBits;
Write_MFRC522(BitFramingReg, 0x07); //TxLastBists = BitFramingReg[2..0] ???
TagType[0] = reqMode;
status = MFRC522_ToCard(PCD_TRANSCEIVE, TagType, 1, TagType, &backBits);
if ((status != MI_OK) || (backBits != 0x10))
status = MI_ERR;
return status;
uchar MF522::MFRC522_ToCard(uchar command, uchar *sendData, uchar sendLen, uchar *backData, uint *backLen)
uchar status = MI_ERR;
uchar irqEn = 0x00;
uchar waitIRq = 0x00;
uchar lastBits;
uchar n;
uint i;
switch (command)
case PCD_AUTHENT:
irqEn = 0x12;
waitIRq = 0x10;
case PCD_TRANSCEIVE: //FIFO
irqEn = 0x77;
waitIRq = 0x30;
default:
Write_MFRC522(CommIEnReg, irqEn|0x80);
ClearBitMask(CommIrqReg, 0x80);
SetBitMask(FIFOLevelReg, 0x80); //FlushBuffer=1, FIFO
Write_MFRC522(CommandReg, PCD_IDLE); //NO action; ???
//IFO
for (i=0; i<sendLen; i++)
Write_MFRC522(FIFODataReg, sendData[i]);
Write_MFRC522(CommandReg, command);
if (command == PCD_TRANSCEIVE)
SetBitMask(BitFramingReg, 0x80); //StartSend=1,transmission of data starts
i = 2000; //i,M 1 25ms ???
do
//CommIrqReg[7..0]
//Set1 TxIRq RxIRq IdleIRq HiAlerIRq LoAlertIRq ErrIRq TimerIRq
n = Read_MFRC522(CommIrqReg);
i--;
while ((i!=0) && !(n&0x01) && !(n&waitIRq));
ClearBitMask(BitFramingReg, 0x80); //StartSend=0
if (i != 0)
if(!(Read_MFRC522(ErrorReg) & 0x1B)) //BufferOvfl Collerr CRCErr ProtecolErr
status = MI_OK;
if (n & irqEn & 0x01)
status = MI_NOTAGERR; //??
n = Read_MFRC522(FIFOLevelReg);
lastBits = Read_MFRC522(ControlReg) & 0x07;
if (lastBits)
*backLen = (n-1)*8 + lastBits;
*backLen = n*8;
if (n == 0)
n = 1;
if (n > MAX_LEN)
n = MAX_LEN;
//FIFO
for (i=0; i<n; i++)
backData[i] = Read_MFRC522(FIFODataReg);
status = MI_ERR;
//SetBitMask(ControlReg,0x80); //timer stops
//Write_MFRC522(CommandReg, PCD_IDLE);
return status;
uchar MF522::MFRC522_Anticoll(uchar *serNum)
uchar status;
uchar i;
uchar serNumCheck=0;
uint unLen;
//ClearBitMask(Status2Reg, 0x08); //TempSensclear
//ClearBitMask(CollReg,0x80); //ValuesAfterColl
Write_MFRC522(BitFramingReg, 0x00); //TxLastBists = BitFramingReg[2..0]
serNum[0] = PICC_ANTICOLL;
serNum[1] = 0x20;
status = MFRC522_ToCard(PCD_TRANSCEIVE, serNum, 2, serNum, &unLen);
if (status == MI_OK)
for (i=0; i<4; i++)
serNumCheck ^= serNum[i];
if (serNumCheck != serNum[i])
status = MI_ERR;
//SetBitMask(CollReg, 0x80); //ValuesAfterColl=1
return status;
void MF522::CalulateCRC(uchar *pIndata, uchar len, uchar *pOutData)
uchar i, n;
ClearBitMask(DivIrqReg, 0x04); //CRCIrq = 0
SetBitMask(FIFOLevelReg, 0x80); //FIFO
//FIFO?
for (i=0; i<len; i++)
Write_MFRC522(FIFODataReg, *(pIndata+i));
Write_MFRC522(CommandReg, PCD_CALCCRC);
//CRC
i = 0xFF;
do
n = Read_MFRC522(DivIrqReg);
i--;
while ((i!=0) && !(n&0x04)); //CRCIrq = 1
//CRC
pOutData[0] = Read_MFRC522(CRCResultRegL);
pOutData[1] = Read_MFRC522(CRCResultRegM);
uchar MF522::MFRC522_SelectTag(uchar *serNum)
uchar i;
uchar status;
uchar size;
uint recvBits;
uchar buffer[9];
//ClearBitMask(Status2Reg, 0x08); //MFCrypto1On=0
buffer[0] = PICC_SElECTTAG;
buffer[1] = 0x70;
for (i=0; i<5; i++)
buffer[i+2] = *(serNum+i);
CalulateCRC(buffer, 7, &buffer[7]); //??
status = MFRC522_ToCard(PCD_TRANSCEIVE, buffer, 9, buffer, &recvBits);
if ((status == MI_OK) && (recvBits == 0x18))
size = buffer[0];
size = 0;
return size;
uchar MF522::MFRC522_Auth(uchar authMode, uchar BlockAddr, uchar *Sectorkey, uchar *serNum)
uchar status;
uint recvBits;
uchar i;
uchar buff[12];
buff[0] = authMode;
buff[1] = BlockAddr;
for (i=0; i<6; i++)
buff[i+2] = *(Sectorkey+i);
for (i=0; i<4; i++)
buff[i+8] = *(serNum+i);
status = MFRC522_ToCard(PCD_AUTHENT, buff, 12, buff, &recvBits);
if ((status != MI_OK) || (!(Read_MFRC522(Status2Reg) & 0x08)))
status = MI_ERR;
return status;
uchar MF522::MFRC522_Read(uchar blockAddr, uchar *recvData)
uchar status;
uint unLen;
recvData[0] = PICC_READ;
recvData[1] = blockAddr;
CalulateCRC(recvData,2, &recvData[2]);
status = MFRC522_ToCard(PCD_TRANSCEIVE, recvData, 4, recvData, &unLen);
if ((status != MI_OK) || (unLen != 0x90))
status = MI_ERR;
return status;
uchar MF522::MFRC522_Write(uchar blockAddr, uchar *writeData)
uchar status;
uint recvBits;
uchar i;
uchar buff[18];
buff[0] = PICC_WRITE;
buff[1] = blockAddr;
CalulateCRC(buff, 2, &buff[2]);
status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 4, buff, &recvBits);
if ((status != MI_OK) || (recvBits != 4) || ((buff[0] & 0x0F) != 0x0A))
status = MI_ERR;
for (i=0; i<16; i++) //FIFO16Byte
buff[i] = *(writeData+i);
CalulateCRC(buff, 16, &buff[16]);
status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 18, buff, &recvBits);
status = MI_ERR;
return status;
void MF522::MFRC522_Halt(void)
uchar status;
uint unLen;
uchar buff[4];
buff[0] = PICC_HALT;
buff[1] = 0;
status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 4, buff,&unLen);
void MF522::MFRC522_Init(void)
digitalWrite(NORESET,HIGH);
MFRC522_Reset();
//Timer: TPrescaler*TreloadVal/6.78MHz = 24ms
Write_MFRC522(TModeReg, 0x8D); //Tauto=1; f(Timer) = 6.78MHz/TPreScaler
Write_MFRC522(TPrescalerReg, 0x3E); //TModeReg[3..0] + TPrescalerReg
Write_MFRC522(TReloadRegL, 30);
Write_MFRC522(TReloadRegH, 0);
Write_MFRC522(TxAutoReg, 0x40); //100%ASK
Write_MFRC522(ModeReg, 0x3D); //CRC 0x6363 ???
//Write_MFRC522(RxSelReg, 0x86); //RxWait = RxSelReg[5..0]
//Write_MFRC522(RFCfgReg, 0x7F); //RxGain = 48dB
AntennaOn();
