Im setting up my Lidar lite v2 and in the docs its stated that i need a electrolytic capacitor 680uF, wich i dont have, i have a large range of others including 1000uF, so i read somewere that i could go higher, but just to be sure im asking the gurus how this all works!
so can i? and how dose this work, i know that the voltage stated is just a cap but the capasitance ?
A request or requirement for a 680uF cap is based on load current requirements. As a general rule, you can NEVER have TOO much capacitance on your power supply lines. 1000uF is fine.
raschemmel:
Okay! so how dose it work? with the dischargeing? is it like amps? the unit pulls whatever it needs in case of instable current?
It's rocket science.
Actually that cap is called a filter cap and is there to reduce/eliminate ripple on the regulated power supply line during operation. The value is chosen based on the device's load current . There's is nothing you need to do or know. Just use the 1000 uF cap and forget it. You haven't given any documentation other than a drawing showing a cap across 5V and GND. I don't have to ask anyone what the cap is doing there, If you say they asked for 680uF , I'm telling you ANY value greater than that is fine. Understand ?
raschemmel:
I regret not taking electronics classes ;_;
And untill i know how /why / where and when its still magic (or rocket science if you prefer) to me and it will annoy my little brain until i can understand it
