Lidar Lite V3 PWM to NodeMCU ESP8266
Hello, I am trying to read data from my Lidar Lite V3 on my NodeMCU ESP8266 V3, with a 3.3v-5v bi-directional logic level shifter between them. The lidar works fine with my Uno, Nano and Nano Every this way, but the example PWM sketch doesn't on the NodeMCU:
unsigned long pulseWidth;
  Serial.begin(115200); // Start serial communications
  pinMode(14, OUTPUT); // Set pin 2 as trigger pin
  digitalWrite(12, LOW); // Set trigger LOW for continuous read
  pinMode(12, INPUT); // Set pin 3 as monitor pin
  pulseWidth = pulseIn(12, HIGH); // Count how long the pulse is high in microseconds
  // If we get a reading that isn't zero, let's print it
  if(pulseWidth != 0)
    pulseWidth = pulseWidth / 10; // 10usec = 1 cm of distance
    Serial.println(pulseWidth); // Print the distance
I noticed that a very simple HC-SR04 ultrasonic sensor setup worked quite well with the NodeMCU so I figured maybe modifying a simple HC-SR04 sketch might do the job. A few times some correct data was produced by this, but at the moment it mostly produces zeroes.
const int trigPin = 12;
const int echoPin = 14;
long duration;
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  if(duration != 0)
    duration = duration / 10; // 10usec = 1 cm of distance
    Serial.println(duration);
  delay(10);
An update for anyone curious, I replaced the logic converter with a voltage divider and it works great now.
