Hi all, first time to Arduino Forum, and first venture into how Arduino might help me. I'm a scale modeler with interests in the Sci-Fi genre. I can handle my self around a soldering gun and making small digital clocks from "kits" like you'd find on Amazon or eBay, never dealt with anything involving "code". It was suggested by a chap on one of the modeling forums I visit, to get an Arduino board and download IDE so I could add coding to have the board make LED's flash, strobe, and flicker to get the look of a rocket engine pulsing and flashing. As a raw noobie at this, I was hoping someone could direct me to what actual hardware(Arduino) I would need to be able to program a series of straw hat LED's to "flicker" like a rocket engine, and have other LED's do random strobing and flashing. This is all I need to do at this time. No need to control motors or relays or servos, etc.
Thanks in Advance
Welcome to the forum
Any Arduino board can do what you describe. How much space do you have to accommodate the Arduino in or near your models ?
Actually I think you will be able to answer your question after you go through the Arduino Cookbook. It has lots of documented projects some similar to what you want to do. It also explains how to build them. I highly recommend you do this before purchasing any items. After you get through that we will be more then willing to help with your selection and code. If you want to start simple get a few UNOs and load the IDE into your computer. The cheap china ones will do well for starting and you will not feel bad if you damage one. You will also need a power supply, something in the 9V - 12V range to power the UNO via the barrel connector would be great but not needed until you add several LEDs. Another important item is a multimeter, a cheep one would work, they can be gotten for less then the cost of a pack of cigarettes.
Find out what you can do before deciding to build because there are many ways to do this.
See about 3.3V Arduino’s, rechargeable batteries and Zener diodes to regulate V. Fact is that you can roll your own Duino from an AVR chip and very few components and it will work. AVR chips are nearly complete in themselves, you can program them on a breadboard using an Uno or like (connection to PC) and the small ATtiny chips (with 6 or 8 pins) would be wayyyyy easier to fit in small spaces.
Turn rocks, see what’s underneath.
There is about 2-3 square inches of room inside the Oblivion Drone model. It will end up on a pole that sits in a display base about 6" sq. and 1" thick, so, room for wires, batteries, switches, etc...or, I could put the board in the display base and run wires to the LED;s inside the drone.
I wouldn’t worry about the controller at the beginning. I would research exactly what type of LEDs you want to use first (and how many).
do you want color? Do you want LEDs that can change color? Are you certain you only want a few LEDs (<10ish) or could you conceive using a lot of LEDs on a single model?
This will indicate if regular single-color LED is sufficient, or is you should consider RGB LEDs (or possibly addressable RGB LEDs).
Depending on the LED, you may need some additional circuitry to drive an LED
Hi, @unclepine
Welcome to the forum.
I did this during Covid with a cardboard model of a fabrication workshop.
I only had a few LEDs to control, so each Nano output drove a single LED.
I used white and blue LEDs to make the welder flash and flickered the office light as the welder flashed to show the dodgey electrics.
I used 3mm LEDs
Tom....
A good place to start is with an Arduino Nano or one of the cheap clones you can find on Amazon. It has a built in LED that you can control. Learn how to blink and flicker that first. This limits what you have to buy and you can learn a lot with just that.
Once you have that knowledge under your belt then you can move on to the straw hat LEDs and learn how to use the external resistors (and perhaps other components) that you’ll need.
I actually had some code that flickered an LED like a tea light that I was about to post here but I must have deleted it some time ago.
Don't get Uno, or Mega, unless you have chosen a shield that you want to fit on top of the Uno. If you don't know what a shield is, you don't want an Uno. Unfortunately on this forum, many folks will recommend Uno as a Pavlovian response, without considering your actual needs.
@TomGeorge, that reminds me of Tim Hunkin and Rex Garrod’s The Secreet Life Of Machines museum exhibits. Dodgey electrics indeed!
