This is brilliant! My project is very similar in function but uses 4 buttons and 13 LEDs, written with simple digitalWrites() and delays(). Obviously, any button push is hit/miss with all the delay statements. I never thought to write a time holder in place of the delays, how simple is that!? I will share my results when I finish the setup. Thank you for sharing this.
EDIT: Here is what I came up with using your sketch. Yes, I still have some cleanup to do. I'm looking into more options to simplify also, as this version has more lines than my original plan. However, this one functions very well in response to button pushes. Thank you again for sharing this and to everyone else who has been helpful on the subject. I'm just 5 days into learning this stuff and have gained only a drop of water compared to the ocean, but love to explore!
const int LED1 = 31; // blue
const int LED2 = 33; // blue
const int LED3 = 35; // white
const int LED4 = 37; // white
const int LED5 = 39; // white
const int LED6 = 41; // white
const int LED7 = 43; // blue
const int LED8 = 45; // blue
// lower lights
const int LED9 = 2; // white
const int LED10 = 3; // blue
const int LED11 = 5; // blue
const int LED12 = 6; // white
// in cab
const int LED13 = 12; // red indicator
int buttonPin3 = 18; // left TA
int buttonPin = 19; // case +
int buttonPin2 = 21; // case -
int buttonPin4 = 20; // right TA
int initial = 0;
int oldstate = 0;
int buttonstate = 0;
int myTime = (millis); // Variable for flash control
Serial.begin(9600); // Initialize Serial
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);
pinMode(LED5, OUTPUT);
pinMode(LED6, OUTPUT);
pinMode(LED7, OUTPUT);
pinMode(LED8, OUTPUT);
pinMode(LED9, OUTPUT);
pinMode(LED10, OUTPUT);
pinMode(LED11, OUTPUT);
pinMode(LED12, OUTPUT);
pinMode(LED13, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
pinMode(buttonPin2, INPUT_PULLUP);
pinMode(buttonPin3, INPUT_PULLUP);
pinMode(buttonPin4, INPUT_PULLUP);
void Power_On() { // Red Indicator on
digitalWrite(LED13, HIGH);
void WigWag() { // BLUE x4
digitalWrite(LED1, HIGH);
digitalWrite(LED2, HIGH);
digitalWrite(LED5, HIGH);
digitalWrite(LED6, HIGH);
digitalWrite(LED10, HIGH);
digitalWrite(LED12, HIGH);
mydelay(70);
digitalWrite(LED1, LOW);
digitalWrite(LED2, LOW);
digitalWrite(LED5, LOW);
digitalWrite(LED6, LOW);
digitalWrite(LED10, LOW);
digitalWrite(LED12, LOW);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
//WHITE X4
digitalWrite(LED3, HIGH);
digitalWrite(LED4, HIGH);
digitalWrite(LED7, HIGH);
digitalWrite(LED8, HIGH);
digitalWrite(LED9, HIGH);
digitalWrite(LED11, HIGH);
mydelay(70);
digitalWrite(LED3, LOW);
digitalWrite(LED4, LOW);
digitalWrite(LED7, LOW);
digitalWrite(LED8, LOW);
digitalWrite(LED9, LOW);
digitalWrite(LED11, LOW);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
void Blue_White() { //ALL BLUE X4
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
//ALL WHITE X4
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
void Double_Pulse() { //2x Fast
mydelay(70);
mydelay(50);
mydelay(70);
mydelay(200); //Longer Pause Mid Cycle
mydelay(70);
mydelay(50);
mydelay(70);
mydelay(700);
void Ping_Pong() { // Left to Right
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(140);
// Right to Left
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
void Pulse_and_Sweep() {
// ALL BLUE X2
mydelay(100);
mydelay(70);
mydelay(100);
mydelay(70);
// LEFT TO RIGHT
delay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
// ALL WHITE X2
mydelay(100);
mydelay(70);
mydelay(100);
mydelay(70);
// RIGHT TO LEFT
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
void Jumpy() { // Rapid Pulses
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
mydelay(30);
mydelay(50);
// All Pulse
mydelay(30);
mydelay(30);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(30);
// Sweep Right to Left
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
// Sweep Left to Right
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
mydelay(50);
void TA_Left() { // +1 LED RIGHT TO LEFT
mydelay(100);
mydelay(75);
mydelay(175);
mydelay(100);
mydelay(75);
mydelay(175);
mydelay(100);
mydelay(75);
mydelay(175);
mydelay(100);
mydelay(75);
mydelay(175);
mydelay(175);
// X5 PULSE- ALL LEDS
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(175);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(100);
mydelay(200);
mydelay(50);
void TA_Right() { // +1 LED LEFT TO RIGHT
mydelay(100);
mydelay(75);
mydelay(175);
mydelay(100);
mydelay(75);
mydelay(175);
mydelay(100);
mydelay(75);
mydelay(175);
mydelay(100);
mydelay(75);
mydelay(175);
delay(175);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(175);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(70);
mydelay(100);
mydelay(200);
mydelay(50);
mydelay(myTime); // Check button
buttonstate = digitalRead(buttonPin); // Put all this comand on delay routine
if (buttonstate == HIGH) {
delay(20);
if (buttonstate == LOW)
initial = oldstate + 1;
delay(20);
buttonstate = digitalRead(buttonPin2);
initial = oldstate - 1;
delay(20);
buttonstate = digitalRead(buttonPin3);
initial = oldstate = 8;
delay(20);
buttonstate = digitalRead(buttonPin4);
initial = oldstate = 9;
switch (initial) {
case 1: //2
myTime = 0; // Restore delay time
Power_On();
oldstate = initial;
loop();
case 2: //3
WigWag();
oldstate = initial;
loop();
case 3: //4
Blue_White();
oldstate = initial;
loop();
case 4: //5
Double_Pulse();
oldstate = initial;
loop();
case 5: //6
Ping_Pong();
oldstate = initial;
loop();
case 6: //7
Pulse_and_Sweep();
oldstate = initial;
loop();
case 7: //8
Jumpy();
oldstate = initial;
loop();
case 8: //9
TA_Left();
oldstate = initial;
loop();
case 9:
TA_Right();
oldstate = initial;
loop();
default:
digitalWrite(LED13, LOW);
oldstate = 0;
void mydelay(int time) // Rotine for flash with minimal block
for (int i = 0; i < time; i++) // Run delay times
delay(1); // Delay 1 milisecond
if (digitalRead(buttonPin) == LOW) // Verify button pressed
delay(20); // Debouncing time
if (digitalRead(buttonPin) == CHANGE) // Confirme if button is pressed
Serial.println(initial); // Print sequence value
initial = oldstate + 1; // incremente sequence valu
myTime = 0; // Zero mytime to stop next flashing
// Hold to no increase sequence continus
delay(1);
if (digitalRead(buttonPin2) == LOW) {
delay(20);
if (digitalRead(buttonPin2) == CHANGE)
myTime = 0;
delay(1);
if (digitalRead(buttonPin3) == LOW) {
delay(20);
if (digitalRead(buttonPin3) == CHANGE)
myTime = 0;
delay(1);
if (digitalRead(buttonPin4) == LOW) {
delay(20);
if (digitalRead(buttonPin4) == CHANGE)
myTime = 0;
return; // Return to loop
