Hello,
I have a Arduino Uno with a GRBL shield for my CNC. I dont know if anybody other rund this setup as well and may be able to help me.
I am having problems with my end stops.
I tried to only enable $16=1 when I do this the cnc does not move. I then enabled $17=1 and still are not able to move (this is OK since it sais in the manual that you need to home first) I then run the $H command. The cnc first raises the Z, and then the x axis and Y axis run, but the Y axis is really slow and I need to run the home command many times before it actually hit the switch.
But after the machine is home, It stil does not respond when I press any of the arrows on the controller in Grbl Controller.
