Hello! I was building a line folllowing robot, it is a ready to use model, and I tried to use PID. Inicially, everything worked write, but, suddenly, it was not making some left curves. When it finds one, it starts turning normally, but suddenly moves to the other side.
this is the code that im using and, yes, I've done the calibration
This example was created by José Cruz on October 2016
Updated on January 2019 by José Cruz
This code example is in the public domain.
http://www.botnroll.com
IMPORTANT!!!!
Before you use this example you MUST calibrate the line sensor. Use example _04_1_Calibrate.ino first!!!
Line reading provides a linear value between -100 to 100
Line follow:
Motors speed varies using PID control.
Adjustable gains kp, ki and kd.
You can adjust the speed limit of the wheel that is outside the curve.
Press push button 3 (PB3) to enter control configuration menu.
IMPORTANTE!!!!
Antes de usar este exemplo é necessário calibrar o sensor de linha. Usar exemplo _04_1_Calibrate.ino antes deste!!!
Leitura da linha que devolve um valor linear entre -100 e +100 da posição da linha.
Seguimento de linha:
Os motores variam com a linha com controlo PID
Ajuste dos ganhos kp, ki, e kd.
Ajuste do limite de velocidade da roda que está no exterior da curva.
#include <BnrOneA.h> // Bot'n Roll ONE A library
#include <EEPROM.h> // EEPROM reading and writing
#include <SPI.h> // SPI communication library required by BnrOne.cpp
BnrOneA one; // declaration of object variable to control the Bot'n Roll ONE A
//constants definitions
#define SSPIN 2 //Slave Select (SS) pin for SPI communication
#define M1 1 //Motor1
#define M2 2 //Motor2
float batmin=10.5; // safety voltage for discharging the battery
#define LIMITS 100.0
double kp=1.3, ki=0.0013, kd=0.35; //PID control gains <> Ganhos do controlo PID
int vel=60; //Max Speed <> Velocidade Máxima dos motores
int vCurve=3; //Curve outside wheel max speed limit <> Limite de velocidade da roda exterior na curva
Serial.begin(57600); // sets baud rate to 57600bps for printing values at serial monitor.
one.spiConnect(SSPIN); // starts the SPI communication module
one.minBat(batmin); // safety voltage for discharging the battery
one.stop(); // stop motors
readMenuEEPROM(); // read control values from EEPROM <> Ler valores de controlo da EEPROM
one.lcd1("Line Follow PID");
one.lcd2(" Press a button ");
while(one.readButton()==0);//Wait a button to be pressed <> Espera que pressione um botão
while(one.readButton()!=0);//Wait for button release <> Espera que largue o botão
int line=0; // The line sensor value <> Valor da linha no sensor
int lineRef=0; // Reference line value <> Valor de referência da linha
int erroP=0; // Proportional error <> Erro proporcional
static double erroI=0.0; // Integral error <> Erro Integral
static int erroD=0.0; // Differential error <> Erro diferencial
static int erroPAnt=0; // Previous proportional eror <> Erro proporcional anterior
double output=0.0; // PID control output <> Resultado do controlo PID
int velM1=0, velM2=0; // Motor speeds <> Velocidade dos motores
line=one.readLine(); // Read the line sensor value -100 to +100 <> Leitura do valor da linha -100 a +100
//Serial.print(" Line:");Serial.print(line);
erroP=lineRef-line; //Proportional error <> Erro proporcional
erroD=erroP-erroPAnt; //Differential error <> Erro diferencial
output = kp*(double)erroP + ki*erroI + kd*(double)erroD;
//Clean integral error if line value is zero or if line signal has changed
//Limpar o erro integral se o valor da linha é zero ou se o sinal da linha mudou
if(erroP*erroPAnt<=0) erroI=0.0;
if (output>LIMITS) output=LIMITS; //Limit the output value <> Limitar o valor de saída
else if (output<-LIMITS) output=-LIMITS;
else erroI+=(double)erroP; //Increment integral error if output is below limits <> Incrementa o erro integral se a saída está dentro dos limites
erroPAnt=erroP;
//Serial.print(" Out:"); Serial.print(output);
//Limit motors maximum and minimum speed <> Limitar mínimos e máximos da velocidade dos motores
velM1=vel-(int)output;
velM2=vel+(int)output;
if(velM1<-1)
velM1=-1; //Minimum speed -1 causes motor to brake <> Velocidade mínima -1 faz o motor travar
if(velM2<-1)
velM2=-1;
if(velM1>vel+vCurve)
velM1=vel+vCurve; //Maximum speed limit <> Limite da velocidade máxima
if(velM2>vel+vCurve)
velM2=vel+vCurve;
//Serial.print(" M1:"); Serial.print(velM1); Serial.print(" M2:"); Serial.println(velM2);
one.move(velM1,velM2);
//Configuration menu <> Menu de configuração
if(one.readButton()==3) menu();// Entra no menu
void menu()
int var=0;
int butt=0;
double temp=0.0;
one.stop();
one.lcd1(" Menu Config:");
one.lcd2("PB1+ PB2- PB3ok");
delay(150);
while(one.readButton()==3) //Wait PB3 to be released <> Espera que se largue o botão 3
delay(150);
//***** Maximum speed <> Velocidade Maxima ******
var=vel;
while(butt!=3)
one.lcd2(" VelMax:",var);
butt=one.readButton();
if(butt==1)
var++;
delay(150);
if(butt==2)
var--;
delay(150);
while(butt!=0) //Wait PB3 to be released <> Espera que se largue o botão 3
{butt=one.readButton();}
vel=var;
//**** Outside wheel speed boost <> Incremento de velocidade da roda de fora ****
var=vCurve;
while(butt!=3)
one.lcd2(" Curve Boost:",var);
if(butt==1)
var++;
delay(150);
if(butt==2)
var--;
delay(150);
vCurve=var;
//**** Proportional gain kp <> Ganho proporcional kp ****
temp=kp*1000;
var=(int)temp;
while(butt!=3)
one.lcd2(" kp:",var);
if(butt==1)
var+=10;
delay(150);
if(butt==2)
var-=10;
delay(150);
kp=(double)var/1000;
//**** Integral gain ki <> Ganho integral ki ****
temp=ki*10000.0;
var=(int)temp;
while(butt!=3)
one.lcd2(" ki:",var);
if(butt==1)
var+=1;
delay(150);
if(butt==2)
var-=1;
delay(150);
ki=(double)var/10000.0;
//**** Differential gain kd <> Ganho diferencial kd ****
temp=kd*1000;
var=(int)temp;
while(butt!=3)
one.lcd2(" kd:",var);
if(butt==1)
var+=10;
delay(150);
if(butt==2)
var-=10;
delay(150);
kd=(double)var/1000;
//**** Configuration end <> Termina Configuração *****
writeMenuEEPROM(); // Write control values to EEPROM <> Escrever valores de controlo na EEPROM
one.lcd1("Line Following!");
one.lcd2("www.botnroll.com");
delay(250);
//Write values on EEPROM <> Escrever valores na EEPROM
void writeMenuEEPROM()
byte eepromADD=10;
int var=0;
var=vel;
EEPROM.write(eepromADD,lowByte(var)); //Guardar em EEPROM
eepromADD++;
var=vCurve;
eepromADD++;
var=(int)(kp*1000.0);
EEPROM.write(eepromADD,highByte(var)); //Guardar em EEPROM
eepromADD++;
eepromADD++;
var=(int)(ki*10000.0);
eepromADD++;
eepromADD++;
var=(int)(kd*1000.0);
eepromADD++;
eepromADD++;
//Read values from EEPROM <> Ler valores da EEPROM
void readMenuEEPROM()
byte eepromADD=10;
int var=0;
vel=(int)EEPROM.read(eepromADD);
eepromADD++;
vCurve=(int)EEPROM.read(eepromADD);
eepromADD++;
var=0;
var=(int)EEPROM.read(eepromADD);
eepromADD++;
var=var<<8;
var+=(int)EEPROM.read(eepromADD);
eepromADD++;
kp=(double)var/1000.0;
var=0;
eepromADD++;
var=var<<8;
eepromADD++;
var=0;
eepromADD++;
var=var<<8;
eepromADD++;
kd=(double)var/1000.0;
if(vel==255) vel=60;
if(vCurve==255) vCurve=3;
if(kp<0) kp=1.3;
if(ki<0) ki=0.0013;
if(kd<0) kd=0.35;
