Linear regulators and inductors
Just thought I would start this discussion/fire fight.
When designing a power supply using a linear regulator who puts an inductor in series with the input and why/why not. In particular, automotive applications with a micro.
Let the fun begin.
Inductor's don't like letting AC thru.
So an inductor in series will tend to block AC spikes on the line.
Switching regulator that chops up DC (and AC noise) to make known AC frequency to turn back into filtered PWM for DC also works well. That's what cigarette lighter USB adapters do. Can be nice & compact.
Yes I understand the difference.
I was just curious as to how many of you, if any, use an inductor on the input of a linear reg.
Inductors can be helpful when they reduce noise.
However, some inductors cannot handle much DC current, so component selection can be important. Also, if the load current changes significantly, an inductor tends to maintain the original current and could interfere with voltage regulation. I tend towards NOT using inductors because I tend to deal with significant DC current and significant load current changes. Also, some inductors use a lot of space and space can be precious to me.
However, I can see that inductors can be useful in some situations.
vaj4088:
Good response. Valid reasons not to use them.
In my current situation there will be almost no change in current and it will be in the range less than 100mA total, probably closer to 50mA.
You need to be careful using inductors before or after a regulator; basically any regulator includes an amplifier and they can become unstable and oscillate; that is why regulator IC's often specify capacitors at input and output pins.
Of course you need a cap between the inductor and regulator input. The inductor may help to reduce noise from other parts to enter your device as well as reduce noise from your device to affect other parts of the system.
It is said automotive power is dirty, full of spikes. The inductor may help to reduce them.
It depends on application if the inductor is appropriate.
The ONLY time I've used an inductor as a power supply filter was to reduce noise in a car stereo.
A voltage regular usually makes a better "noise filter" than an inductor (or capacitor).
DVDdoug:
Only at "low" frequency. The passives are needed for the high frequency noise (where they are more efficient).
What value inductor would you use?
