Hey,
Does anyone have a good tutorial or modul for safe charging?
Lipo should power board and leds so i need to boost to 5V.
Any good advises?
Thx
There is a website called battery university, try this link: BU-409: Charging Lithium-ion - Battery University
It goes into a lot of detail on this and other batteries.
Thx,
The Step Up Modul only allows 2A to pass. Does this matter because my project needs 4V at Max Brightness.
Do I have to connect the esp32 and the led seperatly or can I power the esp32 via the led strip.
There are many step up modules with various characteristics such as: HERE or HERE, it is just a matter of looking for the right one.
At how many volts does the led strip work?. And what esp32 board are you going to use?
LED Strips works with 5V.
I think of the Lolin D32 but if you can me give a better solution it is possible to switch the board
I haven't tried it. It looks like a good plate.
From the 5V of the led strip and through the usb port of the board, with a usb cable only with + and gnd, without the two data cables.
