Load cell 20kg + HX711_ADC
Hi There,
So, to start with this is my first post as I am completely new to Arduino... so be gentile..!!
Second, I am trying (??) to build a loadcell using the HX711 board.
All is connected as it should
I installed the HX711_ADC library and did the calibration using the following code:
#include <HX711_ADC.h>
#if defined(ESP8266)|| defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
//pins:
const int HX711_dout = 4; //mcu > HX711 dout pin
const int HX711_sck = 5; //mcu > HX711 sck pin
//HX711 constructor:
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 0;
  Serial.begin(57600); delay(10);
  Serial.println("Starting...");
  LoadCell.begin();
  //LoadCell.setReverseOutput(); //uncomment to turn a negative output value to positive
  unsigned long stabilizingtime = 2000; // preciscion right after power-up can be improved by adding a few seconds of stabilizing time
  boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
  LoadCell.start(stabilizingtime, _tare);
  if (LoadCell.getTareTimeoutFlag() || LoadCell.getSignalTimeoutFlag()) {
    Serial.println("Timeout, check MCU>HX711 wiring and pin designations");
    while (1);
  else {
    LoadCell.setCalFactor(1.0); // user set calibration value (float), initial value 1.0 may be used for this sketch
    Serial.println("Startup is complete");
  while (!LoadCell.update());
  calibrate(); //start calibration procedure
  static boolean newDataReady = 0;
  const int serialPrintInterval = 0; //increase value to slow down serial print activity
  // check for new data/start next conversion:
  if (LoadCell.update()) newDataReady = true;
  // get smoothed value from the dataset:
  if (newDataReady) {
    if (millis() > t + serialPrintInterval) {
      float i = LoadCell.getData();
      Serial.print("Load_cell output val: ");
      Serial.println(i);
      newDataReady = 0;
      t = millis();
  // receive command from serial terminal
  if (Serial.available() > 0) {
    char inByte = Serial.read();
    if (inByte == 't') LoadCell.tareNoDelay(); //tare
    else if (inByte == 'r') calibrate(); //calibrate
    else if (inByte == 'c') changeSavedCalFactor(); //edit calibration value manually
  // check if last tare operation is complete
  if (LoadCell.getTareStatus() == true) {
    Serial.println("Tare complete");
void calibrate() {
  Serial.println("***");
  Serial.println("Start calibration:");
  Serial.println("Place the load cell an a level stable surface.");
  Serial.println("Remove any load applied to the load cell.");
  Serial.println("Send 't' from serial monitor to set the tare offset.");
  boolean _resume = false;
  while (_resume == false) {
    LoadCell.update();
      _resume = true;
  Serial.println("Now, place your known mass on the loadcell.");
  Serial.println("Then send the weight of this mass (i.e. 100.0) from serial monitor.");
  float known_mass = 0;
  _resume = false;
    LoadCell.update();
      known_mass = Serial.parseFloat();
      if (known_mass != 0) {
        Serial.print("Known mass is: ");
        Serial.println(known_mass);
        _resume = true;
  LoadCell.refreshDataSet(); //refresh the dataset to be sure that the known mass is measured correct
  float newCalibrationValue = LoadCell.getNewCalibration(known_mass); //get the new calibration value
  Serial.print("New calibration value has been set to: ");
  Serial.print(newCalibrationValue);
  Serial.println(", use this as calibration value (calFactor) in your project sketch.");
  Serial.print("Save this value to EEPROM adress ");
  Serial.print(calVal_eepromAdress);
  Serial.println("? y/n");
  _resume = false;
      if (inByte == 'y') {
        EEPROM.begin(512);
#endif
        EEPROM.put(calVal_eepromAdress, newCalibrationValue);
        EEPROM.commit();
#endif
        EEPROM.get(calVal_eepromAdress, newCalibrationValue);
        Serial.print("Value ");
        Serial.print(" saved to EEPROM address: ");
        Serial.println(calVal_eepromAdress);
        _resume = true;
      else if (inByte == 'n') {
        Serial.println("Value not saved to EEPROM");
        _resume = true;
  Serial.println("End calibration");
  Serial.println("To re-calibrate, send 'r' from serial monitor.");
  Serial.println("For manual edit of the calibration value, send 'c' from serial monitor.");
void changeSavedCalFactor() {
  float oldCalibrationValue = LoadCell.getCalFactor();
  Serial.print("Current value is: ");
  Serial.println(oldCalibrationValue);
  Serial.println("Now, send the new value from serial monitor, i.e. 696.0");
  float newCalibrationValue;
      newCalibrationValue = Serial.parseFloat();
      if (newCalibrationValue != 0) {
        Serial.print("New calibration value is: ");
        Serial.println(newCalibrationValue);
        LoadCell.setCalFactor(newCalibrationValue);
        _resume = true;
  _resume = false;
        EEPROM.begin(512);
#endif
        EEPROM.commit();
#endif
        _resume = true;
        _resume = true;
  Serial.println("End change calibration value");
so, the calibration asks to type "t" then to put a weight on the loadcell and to enter the value:
all is well until this point.
Then, they explaine to use the "read load cell 1x" code:
#include <EEPROM.h>
#endif
//pins:
  LoadCell.begin();
  float calibrationValue; // calibration value (see example file "Calibration.ino")
  calibrationValue = 696.0; // uncomment this if you want to set the calibration value in the sketch
  //EEPROM.begin(512); // uncomment this if you use ESP8266/ESP32 and want to fetch the calibration value from eeprom
#endif
  //EEPROM.get(calVal_eepromAdress, calibrationValue); // uncomment this if you want to fetch the calibration value from eeprom
  if (LoadCell.getTareTimeoutFlag()) {
    while (1);
  else {
    LoadCell.setCalFactor(calibrationValue); // set calibration value (float)
  if (newDataReady) {
      Serial.println(i);
      newDataReady = 0;
      t = millis();
  // receive command from serial terminal, send 't' to initiate tare operation:
  // check if last tare operation is complete:
and it's then that things go wrong....
the value of the loadcell just stays 0:
now in some off the instruction video's they uncomment the calibration value so it fetches the value from the EEPROM:
but I still cannot get a value out off my cell and keep on getting 0 or when I uncomment the calibration value I get numbers that count upwards or downwards.
So, can anybody help me out because I am getting desperate....
I have tried to be as inclusive with the information as possible but if you have any other questions, please do ask... I would like to get this solved!!
THX
#include <GyverHX711.h>
GyverHX711 sensor(2, 3);//data,clk
  if (sensor.available()) {
    Serial.println(sensor.read());
sorry for asking, but what are you saying?
download this library and test my sketch
I just get this
congrats, your load cell is broken.
really???? damn, it's a new one!!
what should have been the reading??
It could just be the connections that are broken.
I'll have a look tomorrow!!
make photos
Why all the decimal places for an integer variable?
you are double right
Or maybe .read() is returning a number less than 1145. Could happen if there is little load on the cell; depends on how that library works.
but TO used example sketch from Lib without any divider and get 0.
Maybe wrong (too high) calibration factor. Should just print raw values for checking. As in your now modified sketch, without the -1145 divisor
Or you have a HX711 with a missing ground plane.
Leo..
EUREKA!! it was a bad connection of the white A- wire on the HX711 board... it's working now!!
Second problem now is to figure out how to get these readings onto a OLED display!!
any tips??
