I am loading GRBL on a UNO and all goes well until I see this near end of upload:
- Correct port selected? It should disappear from the IDE and your operating system when you disconnect the board.
- Correct board selected?
- Which version of the IDE are you using?
- Which operating system are you using?
- Is your board a real Uno or a clone; post a link to what you bought.
- When you press and release the reset button, does the L-LED give a couple of flashes in quick succession after the release?
Thanks I found the issue, I had a UNO but it was R4 incompatable processor.
I had an original Nano laying around and that solved the issue!
Tim O
