Hello guys,
I installed the Arduino IDE 1.8.16 in my C:\Prog\arduino-1.8.16 folder using the zip archive.
My idea is to have a complete local installation with everything I need on this folder (so I want to have compilers, tools and libraries on this folder and its childs).
More or less everything is OK apart that in the Preferences menu I am not able to change the folder where preferences.txt is saved: C:\Users\massimo\AppData\Local\Arduino15
I really want that EVERYTHING related to this installation of the Arduino IDE could be stored in C:\Prog\arduino-1.8.16 folder and its childs, where am I wrong?
If you make it a portable installation then the preferences file and everything else that would normally be under C:\Users\massimo\AppData\Local\Arduino15 will instead be under the portable subfolder of the Arduino IDE installation:
When you unzip the installation in a folder of your choice, before you click arduino.exe you have to create an empty directory in the same folder where "arduino.exe" is with the foldername "portable".
Mmmmm... I have it but I did not remember if I created the folder before launching the first time Arduino.exe I will repeate the installation to be sure.
OK, I confirm it solves my problem.
Do you know how to remove AVR and ARM boards from this installation? I woul like to have a portable installation dedicated to ESP32 boards only.
Thanks.
I do not think that's possible. The boards manager has no "remove" button, like with add-on boards packages.
If my assumption is wrong, I'd like to know also, as I have more than 20 portable installation, all tweaked and tuned for specific situations.
You should not have any ARM boards in the installation to begin with. Years ago, the ARM boards were bundled with the Arduino IDE, but that is not the case with any modern version of the Arduino. Only the "Arduino AVR Boards" platform is bundled with the Arduino IDE installation now.
You can remove that by deleting the following subfolders of the Arduino IDE installation folder:
What about the json and txt files in the hardware folder?
Installing the ESP32 boards the IDE did not create hardware/arduino/esp32 and /hardware/tools/esp-32 . Where are saved the ESP32 boards and compilers? Because it compiles correctly. If the boards and the compilers are installed in a folder that is not a child of the root folder of the portable installation... it breaks the concept of portable installation.
Give it a try. When I did a quick test of removing the hardware folder completely, the IDE would no longer start up. But I didn't check what was the absolute minimum needed since it seemed unimportant to me.
portable/packages/esp32
If you turn on "Verbose output during: Compilation" in the Arduino IDE preferences, this will all be shown to you in the compilation output.
