I am working on logic gate tester for 74LS series. for AND,NAND,OR,EX-OR. for IC all inputs (8 inputs) receive 00,01,10,11 and output of each signal goes to arduino to compare. output1 to output4 if equalls program works and checks the condition. However, gatevalue shows 0 allways.
Program as below;
int gatevalue1; //Declare all of the variables
int gatevalue2;
int gatevalue3;
int gatevalue4;
int gatevalue;
int inputPin1 = 4;
int inputPin2 = 5;
int inputPin3 = 6;
int inputPin4 = 7;
int Output1Pin = 2;
int Output2Pin = 3;
int ledError = 13;
int ledAND = 12;
int ledOR = 11;
int ledNAND = 10;
int ledNOR = 9;
int ledXOR = 8;
//Begin declaring what pin is what
void setup(){
pinMode (Output1Pin, OUTPUT);
pinMode (Output2Pin, OUTPUT);
pinMode (inputPin1, INPUT);
pinMode (inputPin2, INPUT);
pinMode (inputPin3, INPUT);
pinMode (inputPin4, INPUT);
pinMode(ledError, OUTPUT);
pinMode(ledAND, OUTPUT);
pinMode(ledOR, OUTPUT);
pinMode(ledNAND, OUTPUT);
pinMode(ledNOR, OUTPUT);
pinMode(ledXOR, OUTPUT);
gatevalue = 0;
gatevalue1 = 0;
gatevalue2 = 0;
gatevalue3 = 0;
gatevalue4 = 0;
void loop(){
gatevalue1 = gatevalue1 + (check_Gate1(false, false)*1); //When an input is HIGH it will add a value to the gatevalue
gatevalue1 = gatevalue1 + (check_Gate1(false, true)*2); //and each gate will have a different gatevalue.
gatevalue1 = gatevalue1 + (check_Gate1(true, false)*4);
gatevalue1 = gatevalue1 + (check_Gate1(true, true)*8);
gatevalue2 = gatevalue2 + (check_Gate2(false, false)*1); //When an input is HIGH it will add a value to the gatevalue
gatevalue2 = gatevalue2 + (check_Gate2(false, true)*2); //and each gate will have a different gatevalue.
gatevalue2 = gatevalue2 + (check_Gate2(true, false)*4);
gatevalue2 = gatevalue2 + (check_Gate2(true, true)*8);
gatevalue3 = gatevalue3 + (check_Gate3(false, false)*1); //When an input is HIGH it will add a value to the gatevalue
gatevalue3 = gatevalue3 + (check_Gate3(false, true)*2); //and each gate will have a different gatevalue.
gatevalue3 = gatevalue3 + (check_Gate3(true, false)*4);
gatevalue3 = gatevalue3 + (check_Gate3(true, true)*8);
gatevalue4 = gatevalue4 + (check_Gate4(false, false)*1); //When an input is HIGH it will add a value to the gatevalue
gatevalue4 = gatevalue4 + (check_Gate4(false, true)*2); //and each gate will have a different gatevalue.
gatevalue4 = gatevalue4 + (check_Gate4(true, false)*4);
gatevalue4 = gatevalue4 + (check_Gate4(true, true)*8);
if(gatevalue4 == gatevalue3 && gatevalue3 == gatevalue2 && gatevalue2 == gatevalue1)
gatevalue=gatevalue4;
if(gatevalue==8)
Serial.println("The gate is an AND gate."); //When gatevalue is 1 it is an AND gate
digitalWrite(ledError, LOW); //if gate is in, light is off
digitalWrite(ledAND, HIGH);
digitalWrite(ledOR, LOW);
digitalWrite(ledNAND, LOW);
digitalWrite(ledNOR, LOW);
digitalWrite(ledXOR, LOW);
else if(gatevalue==7)
Serial.println("The gate is an NAND gate.");
digitalWrite(ledAND, LOW);
digitalWrite(ledNAND, HIGH);
else if(gatevalue==14)
Serial.println("The gate is an OR gate.");
digitalWrite(ledOR, HIGH);
else if(gatevalue==6)
Serial.println("The gate is an XOR gate.");
digitalWrite(ledXOR, HIGH);
Serial.println("ERROR: Gate Not Present.");
Serial.println(gatevalue);
digitalWrite(ledError, HIGH); //if gate is in, light is off
int check_Gate1(int output1, int output2)
int x1;
digitalWrite(Output1Pin, output1);
digitalWrite(Output2Pin, output2);
delay(5); // Make sure the signal has time to propogate through the gate.
x1 = digitalRead(inputPin1);
return x1;
int check_Gate2(int output1, int output2)
int x2;
x2 = digitalRead(inputPin2);
return x2;
int check_Gate3(int output1, int output2)
int x3;
x3 = digitalRead(inputPin3);
return x3;
int check_Gate4(int output1, int output2)
int x4;
x4 = digitalRead(inputPin4);
return x4;
Logic_Tester.ino (4.78 KB)
