DrAzzy:
Yeah, there's a graph in the datasheets for most mosfets.
Graphs for "typical values" aren't a promise of anything, whereas the Rds(on) max spec is
a more legally binding part of the datasheet.
Gate threshold values vary a lot between devices, and vary as a device ages(*), so the "typical"
graphs have to be taken with a liberal dose of salt - if the typical graph shows a plateau at 4V,
you basically know it cannot be logic level since actual plateaus will be in the 3 to 5V range.
(*) ion migration in the gate oxide occurs over time due to the extreme electric fields across
it, and this changes the arrangement of charge that biases the threshold voltage. The fields are
extreme because the gate oxide thickness is measured in nanometres. This is also why MOSFETs
are very static sensitive.
Nomenclature:
"theshold voltage" - the point the device switches (nearly) fully off, you must
drive the gate to well below this (normally 0V) to switch off quickly.
"plateau voltage" - the point at which the channel is opening up as the device switches on
and the gate charges up (gate charge mirrors channel space-charge). The plateau shape
depends on the drain-source current level.
"on voltage" - as specified in the Rds(on) specification, a voltage for which there is a guaranteed
on-resistance, typically quoted for 1/2 the maximum current (more than you normally ever run a MOSFET
at BTW)
Typically you'd see the plateau voltage is about 50 to 60% of the on voltage, the threshold voltage is
20 to 30% of the on-voltage.
As I mentioned you don't run a MOSFET near its maximum current rating, because that is the
thermal limit with unlimited heatsinking (usually), so basically you'd treat it as a peak pulse rating,
never a continuous one.
Watch out for certain manufacturers 'lying' about their current spec - they quote something like
270A, and then in a footnote say the package limit is 120A (which is also a thermal limit you'd
never go near in practice, A TO220 package is best kept to 20A or below).
You choose MOSFETs by their on-resistance, and the power dissipation you can tolerate. You also
have to make sure (particularly for logic level devices) that the drain-source voltage is small when on,
less than 0.5V is appropriate, because if parts of the channel are at a higher voltage the device isn't
guaranteed to turn on fully - the voltage difference that matter is that between the gate and the
channel
