Hi All,
First time posting and first time trying to 'create' a DIY project using Arduino, so please forgive me for any mistakes. I also do not know any programming and have only been googling questions I had to some questions that I ran into.
First of all, I have only ordered the stuff I need after watching this video tutorial: https://youtu.be/k5CtXG1rpZg
My main goal is to make an adapter for my pedals. However, I also had the idea that I can use the same arduino board for my shifter, after watching this video tutorial:
https://youtu.be/dLpWEu8kCec
After reading an old topic here, I think that I can do this by following the below wiring diagram (I just made this, sorry if it looks confusing):
And after looking at the two separate code provided for the two projects, I think it's possible to combine them onto one board by using the below code:
#include <Joystick.h>
// H-shifter mode analog axis thresholds
#define HS_XAXIS_12 400
#define HS_XAXIS_56 500
#define HS_YAXIS_135 800
#define HS_YAXIS_246 300
// Sequential shifter mode analog axis thresholds
#define SS_UPSHIFT_BEGIN 670
#define SS_UPSHIFT_END 600
#define SS_DOWNSHIFT_BEGIN 430
#define SS_DOWNSHIFT_END 500
// Handbrake mode analog axis limits
#define HB_MAXIMUM 530
#define HB_MINIMUM 400
#define HB_RANGE (HB_MAXIMUM-HB_MINIMUM)
// Digital inputs definitions
#define DI_REVERSE 1
#define DI_MODE 3
#define DI_RED_CENTERRIGHT 4
#define DI_RED_CENTERLEFT 5
#define DI_RED_RIGHT 6
#define DI_RED_LEFT 7
#define DI_BLACK_TOP 8
#define DI_BLACK_RIGHT 9
#define DI_BLACK_LEFT 10
#define DI_BLACK_BOTTOM 11
#define DI_DPAD_RIGHT 12
#define DI_DPAD_LEFT 13
#define DI_DPAD_BOTTOM 14
#define DI_DPAD_TOP 15
// Shifter state
#define DOWN_SHIFT -1
#define NO_SHIFT 0
#define UP_SHIFT 1
// Shifter mode
#define SHIFTER_MODE 0
#define HANDBRAKE_MODE 1
//int zAxis_ = 0; only used for 5AXIS
//int RxAxis_ = 0; only used for 5AXIS
int RyAxis_ = 0;
int RzAxis_ = 0;
int Throttle_ = 0;
const bool initAutoSendState = true;
// LED blink counter
int led=0;
// Shifter state
int shift=NO_SHIFT;
// Handbrake mode
int mode=SHIFTER_MODE;
int b[16];
int gear=0; // Default value is neutral
// Constant that maps the phyical pin to the joystick button.
//const int pinToButtonMap = 9;
// Last state of the button
int lastButtonState = 0;
// Create the Joystick
Joystick_ Joystick;
//combined setup() for pedals and shifter
// G29 shifter analog inputs configuration, A0 changed to A4, and A2 changed to A3
pinMode(A4, INPUT_PULLUP); // X axis
pinMode(A3, INPUT_PULLUP); // Y axis
pinMode(2, INPUT);
for(int i=0; i<16; i++) b[i] = 0;
b[DI_MODE] =0;
// Initialize Joystick Library
Joystick.begin();
//was loop() but changed to pedals() for no conflict?
void pedals(){
zAxis_ = analogRead(A0);
zAxis_ = map(zAxis_,0,1023,0,255);
Joystick.setZAxis(zAxis_);
RxAxis_ = analogRead(A1);
RxAxis_ = map(RxAxis_,0,1023,0,255);
Joystick.setRxAxis(RxAxis_);
RyAxis_ = analogRead(A0);
RyAxis_ = map(RyAxis_,0,1023,0,255);
Joystick.setRyAxis(RyAxis_);
RzAxis_ = analogRead(A1);
RzAxis_ = map(RzAxis_,1023,0,255,0);
Joystick.setRzAxis(RzAxis_);
Throttle_ = analogRead(A2);
Throttle_ = map(Throttle_,1023,0,255,0);
Joystick.setThrottle(Throttle_);
delay (50);
//was loop() but changed to shifter() for no conflict?
void shifter() {
int x=analogRead(0); // X axis
int y=analogRead(2); // Y axis
int _isreverse = digitalRead(2);
int _gear_ = 0;
if( _isreverse == 1 ){
_gear_ = 8;
b[DI_REVERSE]= 1;
}else{
if(b[DI_MODE]==0) // H-shifter mode?
if(x<HS_XAXIS_12) // Shifter on the left?
if(y>HS_YAXIS_135) _gear_=1; // 1st gear
if(y<HS_YAXIS_246) _gear_=2; // 2nd gear
else if(x>HS_XAXIS_56) // Shifter on the right?
if(y>HS_YAXIS_135) _gear_=5; // 5th gear
if(y<HS_YAXIS_246) _gear_=6; // 6th gear
else // Shifter is in the middle
if(y>HS_YAXIS_135) _gear_=3; // 3rd gear
if(y<HS_YAXIS_246) _gear_=4; // 4th gear
if(gear!=6) b[DI_REVERSE]=0; // Reverse gear is allowed only on 6th gear position
if (_gear_ != gear ){
gear = _gear_;
desactivar();
Joystick.setButton(gear-1, HIGH);
delay(50);
void desactivar(){
// Depress virtual button for current gear
for(int i = 0; i <= 10 ; i++ ) Joystick.setButton(i, LOW);
For reference, below are the original codes provided by amstudio:
Pedals Code:
Joystick_ Joystick;
//int zAxis_ = 0;
//int RxAxis_ = 0;
int RyAxis_ = 0;
int RzAxis_ = 0;
int Throttle_ = 0;
Joystick.begin();
void loop(){
delay (50);
Shifter Code:
Joystick_ Joystick;
#define DI_MODE 3
// Shifter state
#define NO_SHIFT 0
#define UP_SHIFT 1
// Shifter mode
int led=0;
// Shifter state
int shift=NO_SHIFT;
// Handbrake mode
int b[16];
// G29 shifter analog inputs configuration, A0 changed to A4 and A2 changed to A3
pinMode(2, INPUT);
b[DI_MODE] =0;
Joystick.begin();
int _gear_ = 0;
_gear_ = 8;
b[DI_REVERSE]= 1;
}else{
gear = _gear_;
desactivar();
delay(50);
void desactivar(){
I am unable to test it right now since the parts were ordered a few hours ago, but I wanted to seek help in advance, just in case I run into potential issues.
Also, what does the delay(50) do in both codes?
Thank you in advance!
