1)Looking for some kind of sensor to detect human in a small room (toilet in this case). PIR, weight sensor or mechanical switches are not good option there could be no motion for few(x10) minutes. Room size is about 1,5X1,5 meters.
2)Sensor to detect someone on shower? Some microphone to detect water flow on pipes?
you can also connect a watertight DS18B20 on the cold waterpipe.
If there is no flow the temp is environment temperature,
if it starts to flow it will drop quite fast.
If it stays low - the flow continues
If flow stops temperature will rise again.
You also can use a doppler microwave sensor for this job !
I'm trying to use this sensor to measure the speed of cars, but also you can use it to detect a humam moviment!
This is my post: Radar Speed based on doppler device - Sensors - Arduino Forum
