Hello Everyone,
My name is Brandon and I am new to the Arduino environment. I was experimenting with the serial monitor by taking a function I had from an old Data Structs assignment and converting it to the Arduino IDE. Please take a look at my code and respond with any comments or suggestions as to how I can improve the code to be more suited for the cause. Thank you
//Brandon Markham
//Prime Integer Algorithm
//05/16/20
int userNum;
int origNum;
int count;
char userChoice;
Serial.println("Please enter an integer greater than 2 to see if it is prime.");
Serial.println("If the entered number is not prime, the program will display ");
Serial.println("the closest prime integer less than the number entered.\n");
while (Serial.available() == 0) {
userNum = Serial.parseInt();
Serial.print("Number entered was: ");
Serial.println(userNum);
while (userNum <= 2) {
Serial.println("Please enter a valid input greater than 2.\n");
Serial.print("The number entered was: ");
origNum = userNum;
PrimeInteger(userNum, origNum, count);
Serial.print("Would you like to test another integer?\n");
Serial.print("Select Y for yes and N for no.\n\n");
userChoice = Serial.read();
Serial.print("User choice was: ");
Serial.println(userChoice);
while (userChoice != 'y' && userChoice != 'Y' && userChoice != 'n' && userChoice != 'N') {
Serial.println("Please enter valid input Y/y or N/n.\n");
while (userChoice == 'Y' || userChoice == 'y') {
Serial.println("Please enter another integer greater than 2.\n");
while (userChoice == 'N' || userChoice == 'n') {
Serial.println("This program has terminated successuflly.");
exit(0);
void PrimeInteger(int uNum, int oNum, int c) {
bool isPrimeInteger = true;
if (uNum <= 1) {
isPrimeInteger = false;
for (int i = 2; i <= uNum / 2; ++i) {
if (uNum % i == 0) {
if (isPrimeInteger && c > 0) {
Serial.print(uNum);
Serial.print(" is the closest prime integer to ");
Serial.print(oNum);
Serial.println(".");
return;
else if (isPrimeInteger) {
Serial.print(uNum);
Serial.print(" is a prime number\n");
return;
if (!isPrimeInteger) {
c++;
uNum = uNum - 1;
PrimeInteger(uNum, oNum, c);
