Looking to get help with the Adafruit Soundboard 16mb by using QT PY SAMD21
Hey!
So I am very stuck! I have two buttons on a board that I am looking to push for up and down based to scroll through the tracks. I am also trying to do it so that way if I want to change the "track" before the duration is complete the code does that as well. I am having an extremely difficult time with my code and it is quite a mess! I was told a StateChangeDetection would be good. In the code now, I can play the track but it just loops and the up and down buttons do not work. I am also trying to get the OLED to display each track as well as it scrolls up or down. Any help at all is appreciated! I have been working on this or way tooooooo long!
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_Soundboard.h>
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_WIDTH  128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64  // OLED display height, in pixels
#define SFX_RST         9
#define SFX_ACT         8
#define BUTTON_UP_PIN   1
#define BUTTON_DOWN_PIN 3
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Adafruit_Soundboard sfx(&Serial1, &Serial, SFX_RST);
const char *trackNames[] = {
  "Level1.wav",   // Track 0
  "Level2.wav",    // Track 1
  "Level3.wav",   // Track 2
  "Level4.wav",   // Track 3
  "Level5.wav",   // Track 4
  "Level6.wav",   // Track 5
  "Level7.wav",   // Track 6
  "Level8.wav",   // Track 7
  "Level9.wav",   // Track 8
  "Level10.wav",   // Track 9
  "Level11.wav",   // Track 10
  "Level12.wav"    // Track 11
uint8_t currentTrack = 0;
  Serial.begin(9600); // Main serial for debugging
  Serial1.begin(9600); // Secondary serial for Soundboard communication
  sfx.reset(); // Reset the Soundboard
  pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
  pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C))
    Serial.println(F("SSD1306 allocation failed"));
    for(;;);
  display.display();
  delay(2000); // Pause for 2 seconds
  display.clearDisplay();
  // Check button states and scroll through tracks
  if (digitalRead(BUTTON_UP_PIN) == LOW)
    currentTrack++;
    if (currentTrack > 11)
      currentTrack = 11;
    sfx.stop();
    if (currentTrack < sizeof(trackNames) / sizeof(trackNames[0]) - 1) {
      currentTrack++;
      currentTrack = 0;
    //delay(200); // Button debounce
  /*if (digitalRead(BUTTON_DOWN_PIN) == LOW)
    currentTrack--;
    if (currentTrack > 0) {
      currentTrack--;
      currentTrack = sizeof(trackNames) / sizeof(trackNames[0]) - 1;
  // Clear the display
  //display.clearDisplay();
  // Print the current track name on the OLED display
  /*display.setTextSize(2);      // Normal 1:1 pixel scale
  display.setTextColor(SSD1306_WHITE); // Draw white text
  display.setCursor(0, 0);     // Start at top-left corner
  display.print("Playing");
  display.print("   ");
  display.println(trackNames[currentTrack]);
  display.println();
  display.display();            // Show initial text
  display.println("Playing");*/
  Serial.print("Playing Track: ");
  Serial.println(trackNames[currentTrack]);
  sfx.playTrack(1);
  //while(true)
  // Play the current track
  //playTrack(currentTrack);
  //delay(95); // Adjust delay time as needed
void playTrack(uint8_t trackName)
  sfx.playTrack(trackName);
