Looking for someone to build a wireless remote controlled motor that goes back and forth with the ability to change speeds. Would also like the ability to hit a random button where the engine randomly changes direction and speed while you hold down on a button set for random. Need to be able to plug into wall outlet or extension cord. Bonus if you can make a housing. Would want to retain right to device and code. This is part of a bigger project
Project 2:
Similar in design, but motor only needs to go one way, with variable speeds. Motor will need to be able to pull equivalent of 300 pounds. Remote gives options for go, increase speed, random start ie go immediately or wait several seconds before go, and a random speed option. Something would to retain right to device and code. Part of a bigger project.
Would be open to type of royalty deal on both projects.
Someone here built a greyhound training system that pulls a "bunny" around a track at 60 miles per hour using spinning guide-wheels. They might have insight... was it @anon94801460@johnwasser ?
Youre missing some important bits such as how fast to go and acceleration rates. But all in all, $500 is a fantasy anyway. An off the shelf motor and controller will probably cost that much. $5,000 is closer to what you will need. Budget at least $750 for mechanics.
