Loop Unexpectedly Terminates and Disconnects Board
I wrote a simple program for a servo motor. I'm using a GUI written in Processing to communicate with the board. There are two buttons in the GUI: "Open" and "Close". "Open" tells the servo to go to 180 degrees and "Close" tells the servo to go to 0 degrees. Both are if statements within an if loop based on the board being connected. Or so I thought. Both buttons work, but only one or the other, and only once, the loop terminates after one option executes and the board disconnects. I've tried variations "while", "else if". I'm new at this, but I don't understand what I'm missing here. I am attaching the code in the Arduino IDE and Processing.
Thanks for any help
Arduino IDE:
#include <Servo.h>
Servo myservo;  // (Library) create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  Serial.begin(9600); // start serial communication @9600 bps
  if(Serial.available()) { // ID data is available to read
    char val = Serial.read();
    if (val == 'o') {     // if o recieved
        myservo.write(180);
         delay(15);                       // waits 15ms for the servo to reach the position
    else if (val == 'c') {  // if c received
       myservo.write(0);
Processing:
import controlP5.*; //import ControlP5 library
import processing.serial.*;
Serial port;
ControlP5 cp5; //create ControlP5 object
PFont font;
void setup(){ //same as arduino program
  size(300, 400); //window size WxH
  printArray(Serial.list()); //prints all available serial ports
  port = new Serial(this, "COM14", 9600); // Connection to Arduino on com14
  // Create Button
  cp5 = new ControlP5(this);
  font = createFont("Impact", 34); // font type and size on button
  cp5.addButton("OPEN") // "OPEN" is name of button
    .setPosition(100, 50) // X and Y coordinates of upper left corner of button
    .setSize(100, 60) // (Width, Height)
    .setFont(font)
    .setColorForeground(color(134, 175, 28))
    .setColorActive(color(167, 165, 115))
    .setColorBackground(color(148, 182, 112))
     cp5.addButton("CLOSE") // "CLOSE" is name of button
    .setPosition(100, 140) // X and Y coordinates of upper left corner of button
    .setFont(font)
    .setColorForeground(color(234, 111, 117))
    .setColorActive(color(182, 143, 111))
    .setColorBackground(color(205, 112, 112))
void draw(){ //same as loop in arduino
  background (143, 123, 100); //background color of window (R, G, B) or (0 to 255)
  //title for window
  fill(0, 255, 255);   // color of text (R, G, B)
  text(":P", 100, 30); // ("text", x coordinate, y coordinate)
// add functionality to buttons
void OPEN(){
  port.write('o');
void CLOSE(){
  port.write('c');
How are you powering the servos?
Please post a schematic of your project and be sure to include all sources of power.
a7
I'm powering via USB from a standard port.
And what is the stall current of that servo?
That is not long enough to reach the destination. You need something in the order of a second or so.
Ok thanks, let me try.
Here are the specs of the servo:
maximum torque is up to 21.5 kg/cm (298.5 oz/in)@6.8V and speed up to 0.14 >sec/60°(6.8V)@6.8V
Operating voltage: 4.8 - 6.8V
Operating speed ( 5.0V ): 0.15 sec/60 degree
Operating speed ( 6.8V ): 0.13 sec/60 degree
Stall torque ( 5.0V ): 18kg/cm
Stall torque ( 6.8V ): 21.5kg/cm
Operating travel:180deg(PWM 500-2500mus)
Dead band:
Working frequency: 50-333Hz
Connector wire: About 280mm
Gear type: Metal
Motor Type: DC motor
CE Certification: Yes
So to go 180 degrees, you should be waiting 0.45 seconds or 450 ms.
Have you a voltmeter? See if the 5 volts on the servo goes down considerably when it is told to move.
a7
That did the trick. Thank you
I don't have a voltmeter, but I will check that. Thanks
