Looping problems while making a Gameshow buzzer using Arduino Uno
Hi, I've tried making a Gameshow buzzer using code I've found online and adding my own code to make it do more things. Originally it can make a sound, wait for a button to be pressed, detect the button, detect which button was pressed first and end the game. I use 3 different buttons and the idea is that 3 people should be able to play and the person who presses his/her button first gets to answer the question (the question is asked verbally by a "Gameshow host").
The code I've added lets the Gameshow host press one of two buttons printing out if the answer was wrong or right. This works! Although not always. The first part of the game always works but when the host presses the "right answer"- or "wrong answer"-button it doesnt always register and thats the problem. I am to be honest pretty lost in why it only works sometimes and would very much appreciate some help with figuring it out.
*Note: I am 99% sure that the physical assembly is right and that the problem lies in the code.
here is my code:
* name:Building a Quiz Buzzer System
* function: first press button 4 to start. If you press button 1 first, you will see the corresponding LED light up and the buzzer will beep. Then press button 4 again to reset before you press other buttons.
//Email:support@sunfounder.com
//Website:www.sunfounder.com
#define button1 2 //the number of the button 1
#define button2 3 //button2 attach to
#define button3 4 //button3 attach to
#define button4 9 //button4 attach to
#define buzzerPin 5 //the buzzer attach to
#define buttonRight 11 //Rätt Svar knapp
#define buttonWrong 12 // Fel svar knapp
#define LED1 6 //LED 1attach to
#define LED2 7 //LED2attach to
#define LED3 8 //LED3 attach to
#define LED4 10 //LED4 attach to
#define uint8 unsigned char
uint8 flag = 0; //used to indicate the state of button4 key
uint8 b1State,b2State,b3State,b4State,switchStateCorrect,switchStateWrong = 0;
  //initialize buzzer,LED1, LED2, LED3 and LED4 as output
  pinMode(buzzerPin, OUTPUT);
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(LED4, OUTPUT);
  //initialize button1,button2 andbutton3 as input,combined with pullup
  pinMode(button1, INPUT_PULLUP);
  pinMode(button2, INPUT_PULLUP);
  pinMode(button3, INPUT_PULLUP);
  pinMode(button4, INPUT_PULLUP);
  //turn all the led off
  digitalWrite(LED1, LOW);
  digitalWrite(LED2, LOW);
  digitalWrite(LED3, LOW);
  digitalWrite(LED4, LOW);
  pinMode(buttonRight, INPUT_PULLUP);
  pinMode(buttonWrong, INPUT_PULLUP);
  //read the state of the button4
  b4State = digitalRead(button4);
  //when button4 pressed
  if(b4State == 0)
    if(b4State == 0) //confirm that the button4 is pressed
      flag = 1; //if so,flag is 1
      digitalWrite(LED4, HIGH); //turn the host LED on
      delay(200);
  if(1 == flag)
    //read the state of the button of buttons
    b1State = digitalRead(button1);
    b2State = digitalRead(button2);
    b3State = digitalRead(button3);
    //If the button1 press the first
    if(b1State == 0)
      flag = 0;
      Alarm(); //buzzer sound
      digitalWrite(LED1,HIGH); //turn the LED1 on only
      digitalWrite(LED2,LOW);
      digitalWrite(LED3,LOW);
      while(digitalRead(button4)); //detect the button4,if pressed,out of the while loop
    //If the button2 press the first
    if(b2State == 0)
      flag = 0;
      Alarm();
      digitalWrite(LED1,LOW);
      digitalWrite(LED2,HIGH);
    //If the button3 press the first
    if(b3State == 0)
      flag = 0;
      Alarm();
      digitalWrite(LED3,HIGH);
      switchStateCorrect = digitalRead(buttonRight);
      switchStateWrong = digitalRead(buttonRight);
     while (digitalRead(buttonRight) == HIGH and digitalRead(buttonWrong) == HIGH){
     if (digitalRead(buttonRight) == LOW){
     AlarmCorrect();
     Serial.println("Correct");
     if (digitalRead(buttonWrong) == LOW){
     AlarmWrong();
     Serial.println("HENKRIK!");
      switchStateCorrect = 0;
//buzzer sound
void Alarm()
  for(int i=0;i<1;i++)
    tone(buzzerPin,1000,2000);
void AlarmCorrect()
    tone(buzzerPin,2000,2000);
void AlarmWrong()
    tone(buzzerPin,500,2000);
I don't understand why all players don't have the same role. It seems you treat button4 differently than the others.
Why do you test twice the same thing here?
  if(b4State == 0)
The second test is not needed as if the µC executes this its because b4State is already LOW.
If I were you I'd declare the buttons in an array and loop over the array to detect which button was pressed first. You can also use a byte variable equal to
byte sum = digitalRead(button1) + digitalRead(button2) + digitalRead(button3) + digitalRead(button4);
While sum remains equal to 4, this means no buttons were pressed. If it is different then you can test each button (it's so fast that the button will still be pressed) and see which one(s) was(were) pressed.
byte sum = 4;
do sum = digitalRead(button[1]) + digitalRead(button[2]) + digitalRead(button[3]) + digitalRead(button[0]);
while (sum == 4);  // Waits until a button is pressed
for (byte i=0; i<4;i++) {
  if (digitalRead(button[i]==LOW) Serial.println(i);
This tests the buttons and tells which was pressed, provided you declared earlier an array
byte button[4]  = {6,7,8,10};
After that you just need to test the 2 buttons of the host
sum = 2;
do sum = digitalRead(buttonRight) + digitalRead(buttonRight);
while (sum == 2);
Then if one was pressed, the sum is equal to 1 and the while stops. You just have to test as you already do
       AlarmCorrect();
     else if (digitalRead(buttonWrong) == LOW){
       AlarmWrong();
Do you intend to compute scores? For example +1 for a good answer and -1 for wrong.
