Lora BLE bridge
Does any one have a example of a Lora BLE bridge?
I have two T-Beams, the one T-beam I want to be a BLE gateway and then re-transmit on Lora to the distant T-Beam, then a serial output from this T-beam will be used into a Raspberry PI. The transmission will be only a packet every 10-15 min, very low bandwidth and short time on the air.
I have just started to search, but not found a example. I will continue searching in the background for one, but will be a great help is someone have a example.
Wrong section, you are not permitted to post in uncategorised.I have moved your post here.
have a read of how-to-get-the-best-out-of-this-forum
have you got the transmission between the LoRa modules working?
Yes that works, thank you
if the LoRa communication is working it appears you have two tasks left
  1. BLE to T-beam - have a look at File>Examples>ESP32 BLE Arduino for sample programs- have you implemented the code to send BLE to the T-Beam or have some ideas
  2. T-beam EP32 to RPi - are you planning to use WiFi for this? e.g. TCP or UDP client/server?
  1. I have not paid too much attention yet to the 8 devices that needs to connect via ble to the T-Beam. That is my next step
  2. The T-beam will connect via USB to the PI to power it up and the communication.
  3. Need to look at how to do the BLE to Lora.
