Can Anyone help?
The attached sketch, though basic, runs just fine UNTIL I try I try to load the
"Start LoRa duplex TX Sender" in setup.
Everything works just fine except that after loading, Pin 51 remains HIGH.
Even setting Pin 51 LOW in the loop fails to turn off Pin 51.
I need all the Pins from 40 to 52 so I cannot ignore Pin 51 as HIGH.
I have tried another board and redownloaded the loRa.h library.
Without loading LoRa Pin 51 remains LOW as required.
Can anyone suggest anything??
Tx
#include <SPI.h>
#include <LoRa.h>
int aa = 0;
for ( aa = 22;aa<34;aa++){pinMode(aa,OUTPUT);digitalWrite(aa,HIGH);delay(500);digitalWrite(aa,LOW);delay(100);}
for ( aa = 42;aa<54;aa++){pinMode(aa,OUTPUT);digitalWrite(aa,HIGH);delay(500);digitalWrite(aa,LOW);delay(100);}
//... ????????????????????????????????? START LORA Problem Writes Pin 51 HIGH ???????????????????????????????????????????????????????????????
Serial.println("Start LoRa duplex TX Sender");
if (!LoRa.begin(915E6)) {
Serial.println("LoRa init failed. Check your connections.");
while (true) {}
digitalWrite(31,LOW);
