Hello!
I am trying to implement Xiaolin Wu's anti-aliased line algorithm into one of my projects. However, upon trying to compile, it repeats the same 3 errors about a dozen or so times. I have no clue what they mean, and thus have failed to fix them.
Here is a frankenstein's monster of a sketch demonstrating the issue:
#define _swap_int16_t(a, b) {a^=b;b^=a;a^=b;}
struct color{//not an issue
byte a=255;
union{
struct{
byte r : 5, g : 6, b : 5;
uint16_t col16=0;
color(byte r2,byte g2,byte b2,byte a2=255){
a=a2;
r=r2>>3,b=b2>>3,g=g2>>2;
color(uint16_t c, byte a2=255){
a=a2;
col16=c;
void pixel(int x, int y, color c,bool transform){}//just to demonstrate errors...
void lineAA(int x0,int y0,int x1,int y1,color c){
//Xiaolin Wu's Anti-Aliased line algorithm: https://en.wikipedia.org/wiki/Xiaolin_Wu%27s_line_algorithm
#define ipart(x) ((int)x)
#define fpart(x) (x-((int)x))
#define rfpart(x) (1-fpart(x))
#define plotAA(x,y,a) {pixel(x,y,color(c.col16,(byte)(c.a*a)));}
bool steep = abs(y1 - y0) > abs(x1 - x0);
if(steep){
_swap_int16_t(x0, y0);
_swap_int16_t(x1, y1);
if(x0 > x1){
_swap_int16_t(x0, x1);
_swap_int16_t(y0, y1);
float dx = x1 - x0;
float dy = y1 - y0;
float gradient = (float)dy / (float)dx;
if(dx == 0.0)
gradient = 1.0;
// handle first endpoint
float xend = round(x0);
float yend = y0 + gradient * (xend - x0);
float xgap = rfpart(x0 + 0.5);
float xpxl1 = xend; // this will be used in the main loop
float ypxl1 = ipart(yend);
if(steep){
plotAA(ypxl1, xpxl1, rfpart(yend) * xgap)
plotAA(ypxl1+1, xpxl1, fpart(yend) * xgap)
}else{
plotAA(xpxl1, ypxl1 , rfpart(yend) * xgap)
plotAA(xpxl1, ypxl1+1, fpart(yend) * xgap)
float intery = yend + gradient; // first y-intersection for the main loop
// handle second endpoint
xend = round(x1);
yend = y1 + gradient * (xend - x1);
xgap = fpart(x1 + 0.5);
float xpxl2 = xend; //this will be used in the main loop
float ypxl2 = ipart(yend);
if(steep){
plotAA(ypxl2 , xpxl2, rfpart(yend) * xgap);
plotAA(ypxl2+1, xpxl2, fpart(yend) * xgap);
}else{
plotAA(xpxl2, ypxl2, rfpart(yend) * xgap);
plotAA(xpxl2, ypxl2+1, fpart(yend) * xgap);
// main loop
if(steep){
for(float x=xpxl1 + 1;x<xpxl2 - 1;x++){
plotAA(ipart(intery) , x, rfpart(intery));
plotAA(ipart(intery)+1, x, fpart(intery));
intery += gradient;
}else{
plotAA(x, ipart(intery), rfpart(intery));
plotAA(x, ipart(intery)+1, fpart(intery));
intery += gradient;
All of the errors are:
sketch_jul28d:24: error: expected unqualified-id before '(' token
C:\Users\FUZZYZ~1\AppData\Local\Temp\arduino_modified_sketch_885217\sketch_jul28d.ino:26:60: note: in definition of macro 'plotAA'
C:\Users\FUZZYZ~1\AppData\Local\Temp\arduino_modified_sketch_885217\sketch_jul28d.ino:83:40: note: in expansion of macro 'fpart'
Repeated many, many more times...
What is the issue? I have tried (and failed) to find any hint of reason as to why these errors occured, but the messages are not helpful ![]()
Thanks!
