LSM6DS3 I2C Connection to Arduino Nano
I am attempting to connect a 3.3V LSM6DS3 accelerometer/gyrometer to a 5V arduino nano using I2C for a school project. As a reference I have been using the following site and set-up:
https://learn.sparkfun.com/tutorials/lsm6ds3-breakout-hookup-guide/all#assembly
The equivalent from the redboard to the nano is the following:
A4 --> SDA/SDI
A5 --> SCL
GND --> GND
3V3 --> 3.3V
The following is the code I am using to read the data just to test the functionality of the sensor. The code is straight from the site I specified earlier:
MinimalistExample.ino
Marshall Taylor @ SparkFun Electronics
May 20, 2015
https://github.com/sparkfun/LSM6DS3_Breakout
https://github.com/sparkfun/SparkFun_LSM6DS3_Arduino_Library
Description:
Most basic example of use.
Example using the LSM6DS3 with basic settings.  This sketch collects Gyro and
Accelerometer data every second, then presents it on the serial monitor.
Resources:
Uses Wire.h for i2c operation
Development environment specifics:
Arduino IDE 1.6.4
Teensy loader 1.23
Hardware connections:
Connect I2C SDA line to A4
Connect I2C SCL line to A5
Connect GND and 3.3v power to the IMU
This code is released under the [MIT License](http://opensource.org/licenses/MIT).
Please review the LICENSE.md file included with this example. If you have any questions
or concerns with licensing, please contact techsupport@sparkfun.com.
Distributed as-is; no warranty is given.
#include "SparkFunLSM6DS3.h"
#include "Wire.h"
LSM6DS3 myIMU; //Default constructor is I2C, addr 0x6B
  delay(1000); //relax...
  Serial.println("Processor came out of reset.\n");
  //Call .begin() to configure the IMU
  myIMU.begin();
  //Get all parameters
  Serial.print("\nAccelerometer:\n");
  Serial.print(" X = ");
  Serial.println(myIMU.readFloatAccelX(), 4);
  Serial.print(" Y = ");
  Serial.println(myIMU.readFloatAccelY(), 4);
  Serial.print(" Z = ");
  Serial.println(myIMU.readFloatAccelZ(), 4);
  Serial.print("\nGyroscope:\n");
  Serial.println(myIMU.readFloatGyroX(), 4);
  Serial.println(myIMU.readFloatGyroY(), 4);
  Serial.println(myIMU.readFloatGyroZ(), 4);
  Serial.print("\nThermometer:\n");
  Serial.print(" Degrees C = ");
  Serial.println(myIMU.readTempC(), 4);
  Serial.print(" Degrees F = ");
  Serial.println(myIMU.readTempF(), 4);
The serial monitor displays the following output:
Accelerometer:
 X = 12.2449
 Y = 12.2449
 Z = 12.2449
Gyroscope:
 X = 1756.4399
 Y = 1756.4399
 Z = 1756.4399
Thermometer:
 Degrees C = 1593.2500
 Degrees F = 2899.8500
So the board is reading something but I'm not sure what. The numbers don't change when I manipulate the board. But if I change the delay, the numbers change.
No delay:
Accelerometer:
 X = 5.4988
 Y = 5.4988
 Z = 5.4988
Gyroscope:
 X = 788.7600
 Y = 788.7600
 Z = 788.7600
Thermometer:
 Degrees C = 729.2500
 Degrees F = 1344.6500
delay(5000):
Accelerometer:
 X = 11.7452
 Y = 11.7452
 Z = 11.7452
Gyroscope:
 X = 1684.7600
 Y = 1684.7600
 Z = 1684.7600
Thermometer:
 Degrees C = 1529.2500
 Degrees F = 2784.6499
I have tried troubleshooting a few ways.
  1. Using a code I found online for detecting devices connected in I2C
    Code
// i2c_scanner
// Version 1
//    This program (or code that looks like it)
//    can be found in many places.
//    For example on the Arduino.cc forum.
//    The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
//     Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26  2013
//    V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
//    by Arduino.cc user Krodal.
//    Changes by louarnold removed.
//    Scanning addresses changed from 0...127 to 1...119,
//    according to the i2c scanner by Nick Gammon
//    https://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
//    As version 4, but address scans now to 127.
//    A sensor seems to use address 120.
// Version 6, November 27, 2015.
//    Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
  Wire.begin();
  while (!Serial);             // Leonardo: wait for serial monitor
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
Results
I2C Scanner
Scanning...
  1. Using a previous code provided for a lab. This code had to be modified since the accelerometer was originally connected as a SPI. To change the code, the sensor was defined as an SPI and the argument was changed from a '0' to a '1'.
#include <SparkFunLSM6DS3.h>
#include <Wire.h>
LSM6DS3 IMU;
void setup(){
  Wire.begin();
  Serial.println("Testing Sensor Connections");
  if(IMU.begin() != 1){
    Serial.println("Error connecting to the IMU via SPI at CS=10, check connections");
  else{
    Serial.println("IMU Available!");
void loop(){}
Results
IMU Available!
I honestly don't know what this means and have no idea where to go to get this circuit to work. Any tips or advice would be extremely helpful. Thanks in advance.
From the Sparkfun page:
"A logic level shifter is required for any development platform operating at 5V."
This seems to be a 3.3volt only board. Connoecting the I/O to a 5volt processor might have fried it.
The Nano isn't going to work, at least not reliably, with the pins not soldered to the board.
Leo..
