Board: M0
IDE: 1.8.3 with all latest the libraries
OS: Win 10 Pro, 32 bit, US
I am having some serious issues with an Arduino M0 when it comes to uploading. I have tried to uninstall all Arduino and reinstall with all the latest the libraries but nothing seems to help. I can upload to the M0 board on another PC with W10 Home, 64 bit, US.
I can see the board on COM10 in the Device Manager. But still the programmer is not responding. I have also tried to remove the driver and install it again. During the reinstallation of the driver the board is often only recognized as a USB device without any Arduino identification. I then manually navigate to the correct driver and installs this one.
Below is the output from the IDE.
Build options changed, rebuilding all
Sketch uses 9552 bytes (3%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port COM10
PORTS {COM1, COM2, COM10, } / {COM1, COM2, COM10, } => {}
Uploading using selected port: COM10
C:\Users\Mik\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Mik\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -v -patmega2560 -cstk500v2 -PCOM10 -b57600 -Uflash:w:C:\Users\Mik\AppData\Local\Temp\arduino_build_395672/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Mik\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM10
Using Programmer : stk500v2
Overriding Baud Rate : 57600
avrdude: ser_recv(): programmer is not responding
avrdude: stk500v2_ReceiveMessage(): timeout
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
I have searched high and low and came across this link Arduino Sketch upload issue - avrdude: stk500_recv(): programmer is not responding - Stack Overflow which made me try to press the reset button on the M0 board while the IDE tries to find the COM port. Then the below happens.
PORTS {COM1, COM2, COM10, } / {COM1, COM2, } => {}
PORTS {COM1, COM2, } / {COM1, COM2, } => {}
PORTS {COM1, COM2, } / {COM1, COM2, COM7, } => {COM7, }
Found upload port: COM7
C:\Users\Mik\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Mik\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -v -patmega2560 -cstk500v2 -PCOM7 -b57600 -Uflash:w:C:\Users\Mik\AppData\Local\Temp\arduino_build_395672/Blink.ino.hex:i
Using Port : COM7
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500 Version 2.x firmware
Programmer Model: AVRISP
Hardware Version: 3
Firmware Version Master : 4.05
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: stk500isp_read_byte(.., signature, 0x0, ...)
avrdude: stk500isp_read_byte(): Sending read memory command: avrdude: stk500isp_read_byte(.., signature, 0x1, ...)
avrdude: stk500isp_read_byte(): Sending read memory command: ################avrdude: stk500isp_read_byte(.., signature, 0x2, ...)
avrdude: stk500isp_read_byte(): Sending read memory command: ################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
. (omitted to save characters)
avrdude: writing flash (26192 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 26192 bytes of flash written
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% -0.00s
avrdude: verifying ...
avrdude: 26192 bytes of flash verified
avrdude done. Thank you.
As it can been seen the IDE suddenly sees the board on COM7. If I then changes the COM port to COM7 and tries to upload again, but without resetting, the problem is back and the first dump is the case again. Another reset does not reveal a third COM port.
If I show hidden devices in the Device Manager I can also see
- Arduino M0 (Bootloader Mode) Native Port (COM7) - hidden
- Arduino M0 PRO Native Port (COM9) - hidden
- Arduino M0 Native Port (COM10) - visible
I have no idea where the "Arduino M0 PRO Native Port (COM9)" comes from.
Any ideas?
Mik
