Continuing the discussion from Programmer is not responding:
Hello
I have the same issue but in my case the upload still fails.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\*****\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x9b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x9b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x9b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x9b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x9b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x9b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x9b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x9b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x9b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x9b
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
Hi @lucabunirigo. Please add a reply here on this forum thread to tell us which Arduino board you are using.
Please be as specific as possible as some Arduino boards with similar names have significant differences and the forum helpers can only provide effective assistance if we are aware of which one is being used.
If you aren't sure how to describe which board you are using, you can provide the link to the online product listing you bought the board from and we'll proceed based on the information found there.
A picture may be (more) useful.
Please try this experiment and then report back with the results:
This procedure is not intended to solve the problem. The purpose is to gather more information.
- Connect the Arduino board to your computer with a USB cable.
- Press and release the button on the Arduino board that is marked "RESET".
Now please reply here on the forum thread with the answer to the following question:
- Did you see the "L" LED blink multiple times quickly immediately after you released the "RESET" button?
OK, that is good. The blink after reset eliminates some possible causes of the upload error. We now know two things:
- The primary microcontroller on the board is running
- The bootloader program that handles sketch uploads is present on the microcontroller.
Now we move on to investigating other possible causes of the error.
This error might be caused by having the wrong port selected from the Tools > Port menu in Arduino IDE.
Please perform this experiment to verify that the port you have selected is your Arduino board:
With official boards, the port will be labeled with the board name in the menu (e.g., "COM42 (Arduino Uno)"). In this case, you can be fairly confident that you have identified the port. Select that port from the menu and try uploading again.
With some cheap derivative boards the port will not be labeled. You can positively identify the port using this procedure:
- Disconnect the USB cable of the Arduino board from your computer.
- Select Tools > Port from the Arduino IDE menus.
- Take note of the ports (if any) listed in the menu.
- Close the Tools menu.
The ports list is only updated when the Tools menu is re-opened, so this step is essential.
- Select Tools > Port from the Arduino IDE menus. - If a new port is listed in the menu, that is the port of your Arduino board.
If you saw a new port appear at the last step, select that port from the Tools > Port menu and try uploading again.
If this doesn't solve the problem, please reply here on this forum thread with the answers to the following questions:
- While following those instructions, did you see a port in the Tools > Port menu at step (6) that was not present at step (3)?
- If you did see a new port, was the upload successful after you selected that port?
i can see a new port but the upload was not successful
I have the same issue than lucabunirigo, with a UNO R3.
I have tried the method suggested above (disconnect the board, note the USB ports (COM1 only), reconnect the board (COM5 appears in addition)) but the upload still fails, both with COM1 selected or COM5 selected.
I am completely sticked and cannot upload any program in the Arduino...
Any solution ?
IDE version
computer operating system
