Continuation of this post.
Hey everyone, I'm currently working with an Adafruit Feather M4 Express with the SD/RTC featherwing on top. Essentially, the project I'm working on requires high frequency voltage logging to SD card from 4 pins simultaneously (for now I'm using A0, A1, A3, A4).
I've been making use of the onboard DMAC and 6 descriptors to control the 2 ADCs. So far, I have this working near perfectly in the ADC's non-averaged/standard operation mode, but flipping to averaged mode gives some odd behavior and incorrect readings (e.g. a 3.3V readings is saved as ~4009 rather than ~4095, 1.1V as ~1275 rather than ~1360). Another interesting quirk is that in raw mode, with each pin hooked up to a different node of a simple voltage divider, I get the following results (12 bit readings of A0, A1, A3, A4 respectively):
Once switched over to averaging mode, I get the following incorrect results:
Now, the interesting thing is that I sometimes can get the correct result in ADC0 when printing via the debug flags (haven't checked with ADC1 yet, but I presume same phenomena occurs):
The following is my current code for hardware averaged results which causes the unintended behaviors:
This is a demo for reading averaged samples from both ADCs on TWO PINS EACH.
The DMAC then takes these and dumps them into two buffers.
Trying to save something to disk but we'll see if that's possible
Made by paelen1234
#include "FreeStack.h"
#include "SdFat.h"
#include "sdios.h"
#include "helper.h"
#define error(s) sd.errorHalt(&Serial, F(s))
const uint8_t SD_CS_PIN = 10;
#define SPI_CLOCK SD_SCK_MHZ(50)
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, DEDICATED_SPI, SPI_CLOCK)
#define NUM_SAMPLES 1024 // the number of samples per pin.
SdFs sd;
FsFile file;
#define DEBUG_R0_P0 0
#define DEBUG_R0_P1 0
#define DEBUG_R1_P0 0
#define DEBUG_R1_P1 0
#define DEBUG_SD_BEGIN 1
volatile bool results0Part0Ready = false;
volatile bool results0Part1Ready = false;
volatile bool results1Part0Ready = false;
volatile bool results1Part1Ready = false;
uint16_t adcResults0[NUM_SAMPLES*2]; // ADC0 results array
uint16_t adcResults1[NUM_SAMPLES*2]; // ADC1 results array
typedef struct // DMAC descriptor struct
uint16_t btctrl;
uint16_t btcnt;
uint32_t srcaddr;
uint32_t dstaddr;
uint32_t descaddr;
} dmadesc;
A0 ADC_INPUTCTRL_MUXPOS_AIN2
A1 ADC_INPUTCTRL_MUXPOS_AIN5
A2 ADC_INPUTCTRL_MUXPOS_AIN8 ADC_INPUTCTRL_MUXPOS_AIN0
A3 ADC_INPUTCTRL_MUXPOS_AIN9 ADC_INPUTCTRL_MUXPOS_AIN1
A4 ADC_INPUTCTRL_MUXPOS_AIN4
// ADC0 INPUTCTRL register MUXPOS settings
uint32_t inputCtrl0[] = { ADC_INPUTCTRL_MUXPOS_AIN0, // AIN0 = A0
ADC_INPUTCTRL_MUXPOS_AIN5 }; // AIN5 = A1
// ADC1 INPUTCTRL register MUXPOS settings
uint32_t inputCtrl1[] = { ADC_INPUTCTRL_MUXPOS_AIN0, // AIN2 = A3
ADC_INPUTCTRL_MUXPOS_AIN1 }; // AIN3 = A4
volatile dmadesc (*wrb)[DMAC_CH_NUM] __attribute__ ((aligned (16))); // Write-back DMAC descriptors (changed to array pointer)
dmadesc (*descriptor_section)[DMAC_CH_NUM] __attribute__ ((aligned (16))); // DMAC channel descriptors (changed to array pointer)
dmadesc descriptor __attribute__ ((aligned (16))); // Placeholder descriptor
void adc_init() {
// ADC0 Settings
ADC0->INPUTCTRL.bit.MUXPOS = inputCtrl0[0]; // Set the initial analog input to A0
while(ADC0->SYNCBUSY.bit.INPUTCTRL); // Wait for synchronization
ADC0->SAMPCTRL.bit.SAMPLEN = 0x01; // Extend sampling time by SAMPLEN ADC cycles (12 + 1 + 2)/750kHz = 20us = 50kHz
while(ADC0->SYNCBUSY.bit.SAMPCTRL); // Wait for synchronization
ADC0->DSEQCTRL.reg = ADC_DSEQCTRL_AUTOSTART | // Auto start a DMAC conversion upon ADC0 DMAC sequence completion
ADC_DSEQCTRL_INPUTCTRL; // Change the ADC0 INPUTCTRL register on DMAC sequence
ADC0->CTRLB.reg = ADC_CTRLB_RESSEL_16BIT; // Set ADC resolution to 16 bits (averaging mode)
while(ADC0->SYNCBUSY.bit.CTRLB); // Wait for synchronization
ADC0->CTRLA.reg = ADC_CTRLA_PRESCALER_DIV4; // Divide Clock ADC GCLK by 4 (48MHz/64 = 750kHz) (12 + 1)/750kHz = 17.3us sample time
ADC0->AVGCTRL.reg = ADC_AVGCTRL_SAMPLENUM_16 | // Required for averaging mode
ADC_AVGCTRL_ADJRES(4);
// ADC0.AVGCTRL.bit.SAMPLENUM = 0x4;
// ADC0.AVGCTRL.bit.ADJRES = 0x4;
while (ADC0->SYNCBUSY.bit.AVGCTRL); // Wait for synchronization
ADC0->CTRLA.bit.ENABLE = 1; // Enable the ADC
while(ADC0->SYNCBUSY.bit.ENABLE); // Wait for synchronization
ADC0->SWTRIG.bit.START = 1; // Initiate a software trigger to start an ADC conversion
while(ADC0->SYNCBUSY.bit.SWTRIG); // Wait for synchronization
ADC0->DBGCTRL.bit.DBGRUN = 0;
// ADC1 Settings
ADC1->INPUTCTRL.bit.MUXPOS = inputCtrl1[0]; // Set the initial analog input to A2
while(ADC1->SYNCBUSY.bit.INPUTCTRL); // Wait for synchronization
ADC1->SAMPCTRL.bit.SAMPLEN = 0x01; // Extend sampling time by SAMPCTRL ADC cycles (12 + 1 + 2)/750kHz = 20us = 50kHz
while(ADC1->SYNCBUSY.bit.SAMPCTRL); // Wait for synchronization
ADC1->DSEQCTRL.reg = ADC_DSEQCTRL_AUTOSTART | // Auto start a DMAC conversion upon ADC0 DMAC sequence completion
ADC_DSEQCTRL_INPUTCTRL; // Change the ADC1 INPUTCTRL register on DMAC sequence
ADC1->CTRLB.reg = ADC_CTRLB_RESSEL_16BIT; // Set ADC resolution to 16 bits (averaging mode)
while(ADC1->SYNCBUSY.bit.CTRLB); // Wait for synchronization
ADC1->CTRLA.reg = ADC_CTRLA_PRESCALER_DIV4; // Divide Clock ADC GCLK by 4 (48MHz/64 = 750kHz) (12 + 1)/750kHz = 17.3us sample time
ADC1->AVGCTRL.reg = ADC_AVGCTRL_SAMPLENUM_16 | // Required for averaging mode
while (ADC1->SYNCBUSY.bit.AVGCTRL); // Wait for synchronization
ADC1->CTRLA.bit.ENABLE = 1; // Enable the ADC
while(ADC1->SYNCBUSY.bit.ENABLE); // Wait for synchronization
ADC1->SWTRIG.bit.START = 1; // Initiate a software trigger to start an ADC conversion
while(ADC1->SYNCBUSY.bit.SWTRIG); // Wait for synchronization
ADC1->DBGCTRL.bit.DBGRUN = 0;
void dma_channels_enable() {
DMAC->Channel[2].CHCTRLA.bit.ENABLE = 1; // Enable DMAC channel 2 (ADC0 First Output Descriptor)
DMAC->Channel[3].CHCTRLA.bit.ENABLE = 1; // Enable DMAC channel 3 (ADC1 First Output Descriptor)
DMAC->Channel[4].CHCTRLA.bit.ENABLE = 1; // Enable DMAC channel 4 (ADC0 Sequencing / Input Descriptor)
DMAC->Channel[5].CHCTRLA.bit.ENABLE = 1; // Enable DMAC channel 5 (ADC1 Sequencing / Input Descriptor)
delay(1); // Wait a millisecond
void dma_init(){
descriptor_section = reinterpret_cast<dmadesc(*)[DMAC_CH_NUM]>(DMAC->BASEADDR.reg); //point array pointer to BASEADDR defined by SD.begin
wrb = reinterpret_cast<dmadesc(*)[DMAC_CH_NUM]>(DMAC->WRBADDR.reg); //point array pointer to WRBADDR defined by SD.begin
DMAC->CTRL.reg = DMAC_CTRL_DMAENABLE | DMAC_CTRL_LVLEN(0xf);
// ADC0 DMA Sequencing setup (Input Descriptor)
DMAC->Channel[4].CHPRILVL.reg = DMAC_CHPRILVL_PRILVL_LVL3; // Set DMAC channel 4 to priority level 3 (highest)
DMAC->Channel[4].CHCTRLA.reg = DMAC_CHCTRLA_TRIGSRC(ADC0_DMAC_ID_SEQ) | // Set DMAC to trigger on ADC0 DMAC sequence
DMAC_CHCTRLA_BURSTLEN_SINGLE | // One beat per burst
DMAC_CHCTRLA_TRIGACT_BURST; // DMAC burst transfer
DMAC->Channel[4].CHINTENSET.reg = DMAC_CHINTENSET_SUSP; // Activate the suspend (SUSP) interrupt on DMAC channel 4
descriptor.descaddr = (uint32_t)&(*descriptor_section)[4]; // Descriptor linked to itself repeatedly
descriptor.srcaddr = (uint32_t)inputCtrl0 + sizeof(uint32_t) * 2; // Address of inputs to swap between
descriptor.dstaddr = (uint32_t)&ADC0->DSEQDATA.reg; // Write the INPUT CTRL
descriptor.btcnt = 2; // Beat count is 2 (???) (code originally had it at 4) TODO TODO TODO TODO TODO
descriptor.btctrl = DMAC_BTCTRL_BEATSIZE_WORD | // Beat size is WORD (32-bits)
DMAC_BTCTRL_SRCINC | // Increment the source address
DMAC_BTCTRL_STEPSEL_SRC | // Indicates that the source address is using these step settings
DMAC_BTCTRL_STEPSIZE_X1 | // The Step size is set to 1x beats
DMAC_BTCTRL_VALID; // Descriptor is valid
memcpy(&(*descriptor_section)[4], &descriptor, sizeof(descriptor)); // Copy the descriptor to the descriptor section
// ADC1 DMA Sequencing setup (Input Descriptor)
DMAC->Channel[5].CHPRILVL.reg = DMAC_CHPRILVL_PRILVL_LVL3; // Set DMAC channel 5 to priority level 3 (highest)
DMAC->Channel[5].CHCTRLA.reg = DMAC_CHCTRLA_TRIGSRC(ADC1_DMAC_ID_SEQ) | // Set DMAC to trigger on ADC1 DMAC sequence
DMAC->Channel[5].CHINTENSET.reg = DMAC_CHINTENSET_SUSP; // Activate the suspend (SUSP) interrupt on DMAC channel 5
descriptor.descaddr = (uint32_t)&(*descriptor_section)[5]; // Descriptor linked to itself repeatedly
descriptor.srcaddr = (uint32_t)inputCtrl1 + sizeof(uint32_t) * 2; // Address of inputs to swap between
descriptor.dstaddr = (uint32_t)&ADC1->DSEQDATA.reg; // Write the INPUT CTRL
memcpy(&(*descriptor_section)[5], &descriptor, sizeof(descriptor)); // Copy the descriptor to the descriptor section
// ADC0 Output Descriptors
DMAC->Channel[2].CHPRILVL.reg = DMAC_CHPRILVL_PRILVL_LVL3; // Set DMAC channel 2 to priority level 2 (highest)
DMAC->Channel[2].CHCTRLA.reg = DMAC_CHCTRLA_TRIGSRC(ADC0_DMAC_ID_RESRDY) | // Set DMAC to trigger when ADC0 result is ready
descriptor.descaddr = (uint32_t)&(*descriptor_section)[6]; // Set up a linked descriptor
descriptor.srcaddr = (uint32_t)&ADC0->RESULT.reg; // Take the result from the ADC0 RESULT register
descriptor.dstaddr = (uint32_t)adcResults0 + sizeof(uint16_t) * NUM_SAMPLES; // Place it in the first half of adcResults0 array
descriptor.btcnt = NUM_SAMPLES; // Beat count
descriptor.btctrl = DMAC_BTCTRL_BEATSIZE_HWORD | // Beat size is HWORD (16-bits)
DMAC_BTCTRL_DSTINC | // Increment the destination address
DMAC_BTCTRL_VALID | // Descriptor is valid
DMAC_BTCTRL_BLOCKACT_SUSPEND; // Suspend DMAC channel 2 after block transfer
memcpy(&(*descriptor_section)[2], &descriptor, sizeof(descriptor)); // Copy the descriptor to the descriptor section
descriptor.descaddr = (uint32_t)&(*descriptor_section)[2]; // Set up a linked descriptor
descriptor.dstaddr = (uint32_t)&adcResults0[NUM_SAMPLES] + sizeof(uint16_t) * NUM_SAMPLES; // Place it in the second half of adcResults0 array
DMAC_BTCTRL_BLOCKACT_SUSPEND; // Suspend DMAC channel 6 after block transfer
memcpy(&(*descriptor_section)[6], &descriptor, sizeof(descriptor)); // Copy the descriptor to the descriptor section
NVIC_SetPriority(DMAC_2_IRQn, 0); // Set the Nested Vector Interrupt Controller (NVIC) priority for DMAC Channel 2
NVIC_EnableIRQ(DMAC_2_IRQn); // Connect DMAC Channel 2 to Nested Vector Interrupt Controller (NVIC)
DMAC->Channel[2].CHINTENSET.reg = DMAC_CHINTENSET_SUSP; // Activate the suspend (SUSP) interrupt on DMAC channel 2
// ADC1 Output Descriptors
DMAC->Channel[3].CHPRILVL.reg = DMAC_CHPRILVL_PRILVL_LVL3; // Set DMAC channel 3 to priority level 3 (highest)
DMAC->Channel[3].CHCTRLA.reg = DMAC_CHCTRLA_TRIGSRC(ADC1_DMAC_ID_RESRDY) | // Set DMAC to trigger when ADC1 result is ready
descriptor.descaddr = (uint32_t)&(*descriptor_section)[7]; // Set up a linked descriptor
descriptor.srcaddr = (uint32_t)&ADC1->RESULT.reg; // Take the result from the ADC1 RESULT register
descriptor.dstaddr = (uint32_t)adcResults1 + sizeof(uint16_t) * NUM_SAMPLES; // Place it in the first half of adcResults1 array
DMAC_BTCTRL_BLOCKACT_SUSPEND; // Suspend DMAC channel 3 after block transfer
memcpy(&(*descriptor_section)[3], &descriptor, sizeof(descriptor)); // Copy the descriptor to the descriptor section
descriptor.descaddr = (uint32_t)&(*descriptor_section)[3]; // Set up a linked descriptor
descriptor.dstaddr = (uint32_t)&adcResults1[NUM_SAMPLES] + sizeof(uint16_t) * NUM_SAMPLES; // Place it in the second half of adcResults1 array
DMAC_BTCTRL_BLOCKACT_SUSPEND; // Suspend DMAC channel 7 after block transfer
memcpy(&(*descriptor_section)[7], &descriptor, sizeof(descriptor)); // Copy the descriptor to the descriptor section
NVIC_SetPriority(DMAC_3_IRQn, 0); // Set the Nested Vector Interrupt Controller (NVIC) priority for DMAC Channel 3
NVIC_EnableIRQ(DMAC_3_IRQn); // Connect DMAC Channel 3 to Nested Vector Interrupt Controller (NVIC)
DMAC->Channel[3].CHINTENSET.reg = DMAC_CHINTENSET_SUSP; // Activate the suspend (SUSP) interrupt on DMAC channel 3
while(!Serial); // Wait for the console to open
// Initialize SD card before setting up DMA
if (!sd.begin(SD_CONFIG)) {
Serial.println("SD initialization failed!");
while (1); // Halt if SD card initialization fails
Serial.println("SD initialization succeeded!");
// TODO make this use inputCtrl0 and inputCtrl1
// Is this even necessary?
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
adc_init();
dma_init();
dma_channels_enable();
create_dat_file(&sd, &file);
// empty 18KB file creation takes 30-40 ms
// filling half a buffer takes 2-3 ms
// writing 1 half buffer takes 6-7 ms
// getting file size takes 0.1-0.4 ms
// file sync takes <0.1 ms
uint16_t a[NUM_SAMPLES*4]; // should be a0 a1 a2 a3, a0 a1 a2 a3, a0 a1 a2 a3
int rollovers = 0;
int dac = 1;
bool ascend = true;
bool R0_P0_dirty = false;
bool R0_P1_dirty = false;
bool R1_P0_dirty = false;
bool R1_P1_dirty = false;
// DEBUGGING
// stop the sketch on 12th file creation. for some reason it goes till 12? and not 10 or 11?
if (rollovers > 10) {
ascend = false;
Serial.println("now read the data and see what is going on");
Serial.println(micros());
for (int i = 0; i < NUM_SAMPLES; i++) {
Serial.print(a[i*4]);
Serial.print(" ");
Serial.print(a[i*4+1]);
Serial.print(" ");
Serial.print(a[i*4+2]);
Serial.print(" ");
Serial.print(a[i*4+3]);
Serial.println(" ");
while (true);
// perform auto rollover check and count how many rollovers there have been
rollovers += do_rollover_if_needed(&sd, &file, sizeof(a)) ? 1 : 0;
// only write a if everything is dirty
if (R0_P0_dirty && R0_P1_dirty && R1_P0_dirty && R1_P1_dirty) {
// Serial.println(F("DIRTY"));
// Serial.print("\t"); Serial.println(R0_P0_dirty);
// Serial.print("\t"); Serial.println(R0_P1_dirty);
// Serial.print("\t"); Serial.println(R1_P0_dirty);
// Serial.print("\t"); Serial.println(R1_P1_dirty);
// write the buffer to SD
file.write(a, sizeof(a));
if (results0Part0Ready) {
R0_P0_dirty = true;
// `i` should account for which half of buffer this is
// e.g. since this is first half of the buffer, it will go (0,1) to (2044,2045)
// and for r0p1, it should go (2048,2049) to (4092, 4093)
for (uint16_t i = 0; i < NUM_SAMPLES; i++) {
// fills in a like x x _ _ x x _ _ x x _ _
// where x x is a0 a1, and _ _ is left for a2 a3
uint16_t j = (i/2)*4 + i%2;
// copy the data over
a[j] = adcResults0[i];
#if DEBUG_R0_P0
Serial.print("hiii:");
Serial.print(5000);
Serial.print(",");
Serial.print("lo:");
Serial.print(0);
Serial.print(",");
Serial.print("R0_P0_reading0:");
Serial.print(adcResults0[0]);
Serial.print(", ");
Serial.print("R0_P0_reading1:");
Serial.print(adcResults0[1]);
#endif
results0Part0Ready = false; // Clear the results0 ready flag
if (results0Part1Ready) {
R0_P1_dirty = true;
// e.g. since this is second half of the buffer, it will go (2048,2049) to (4092, 4093)
for (uint16_t i = NUM_SAMPLES; i < NUM_SAMPLES*2; i++) {
// fills in `a` like x x _ _ x x _ _ x x _ _
#if DEBUG_R0_P1
Serial.print(5000);
Serial.print(",");
Serial.print(0);
Serial.print(",");
Serial.print("R0_P1_reading0:");
Serial.print(adcResults0[1024]);
Serial.print(", ");
Serial.print("R0_P1_reading1:");
Serial.print(adcResults0[1025]);
#endif
results0Part1Ready = false; // Clear the results1 ready flag
Serial.println("AAAAA");
while (true);
if (results1Part0Ready) {
R1_P0_dirty = true;
// fills in a like _ _ x x _ _ x x _ _ x x
// where _ _ is left for a0 a1, and x x is a2 a3
uint16_t j = (i/2)*4 + 2 + i%2;
a[j] = adcResults1[i];
#if DEBUG_R1_P0
Serial.print(5000);
Serial.print(",");
Serial.print(0);
Serial.print(",");
Serial.print("R1_P0_reading0:");
Serial.print(adcResults1[0]);
Serial.print(", ");
Serial.print("R1_P0_reading1:");
Serial.print(adcResults1[1]);
#endif
results1Part0Ready = false; // Clear the results0 ready flag
if (results1Part1Ready) {
R1_P1_dirty = true;
// fills in `a` like _ _ x x _ _ x x _ _ x x
uint16_t j = (i/2)*4 + i%2 + 2;
#if DEBUG_R1_P1
Serial.print(5000);
Serial.print(",");
Serial.print(0);
Serial.print(",");
Serial.print("R1_P1_reading0:");
Serial.print(adcResults1[1024]);
Serial.print(", ");
Serial.print("R1_P1_reading1:");
Serial.print(adcResults1[1025]);
#endif
results1Part1Ready = false; // Clear the results1 ready flag
void DMAC_2_Handler() // Interrupt handler for DMAC channel 2
// Serial.println("AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA");
static uint8_t count0 = 0; // Initialise the count
if (DMAC->Channel[2].CHINTFLAG.bit.SUSP) // Check if DMAC channel 2 has been suspended (SUSP)
DMAC->Channel[2].CHCTRLB.reg = DMAC_CHCTRLB_CMD_RESUME; // Restart the DMAC on channel 2
DMAC->Channel[2].CHINTFLAG.bit.SUSP = 1; // Clear the suspend (SUSP)interrupt flag
if (count0) // Test if the count0 is 1
results0Part1Ready = true; // Set the results 0 part 1 ready flag
results0Part0Ready = true; // Set the results 0 part 0 ready flag
count0 = (count0 + 1) % 2; // Toggle the count0 between 0 and 1
void DMAC_3_Handler() // Interrupt handler for DMAC channel 3
// Serial.println("BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB");
if (DMAC->Channel[3].CHINTFLAG.bit.SUSP) // Check if DMAC channel 3 has been suspended (SUSP)
DMAC->Channel[3].CHCTRLB.reg = DMAC_CHCTRLB_CMD_RESUME; // Restart the DMAC on channel 3
DMAC->Channel[3].CHINTFLAG.bit.SUSP = 1; // Clear the suspend (SUSP)interrupt flag
results1Part1Ready = true; // Set the results 0 part 1 ready flag
results1Part0Ready = true; // Set the results 0 part 0 ready flag
The following is my current (working) code for raw results:
This is a demo for reading samples from both ADCs on TWO PINS EACH.
Made by paelen1234
#include "SdFat.h"
#include "sdios.h"
#include "helper.h"
SdFs sd;
FsFile file;
typedef struct // DMAC descriptor structure
uint16_t btctrl;
uint16_t btcnt;
uint32_t srcaddr;
uint32_t dstaddr;
uint32_t descaddr;
} dmadesc;
// ADC INPUTCTRL register MUXPOS settings
dmadesc descriptor __attribute__ ((aligned (16))); // Place holder descriptor
void adc_init() {
// ADC0 Settings
ADC0->INPUTCTRL.bit.MUXPOS = inputCtrl0[0]; // Set the analog input to A0
ADC0->CTRLB.reg = ADC_CTRLB_RESSEL_12BIT; // Set ADC resolution to 12 bits
// ADC1 Settings
ADC1->INPUTCTRL.bit.MUXPOS = inputCtrl1[0]; // Set the analog input to A2
ADC1->SAMPCTRL.bit.SAMPLEN = 0x01; // Extend sampling time by SAMPLEN ADC cycles (12 + 1 + 2)/750kHz = 20us = 50kHz
ADC1->CTRLB.reg = ADC_CTRLB_RESSEL_12BIT; // Set ADC resolution to 12 bits
void dma_init(){
descriptor.descaddr = (uint32_t)&(*descriptor_section)[4]; // Set up a circular descriptor
descriptor.srcaddr = (uint32_t)inputCtrl0 + sizeof(uint32_t) * 2; // Configure the DMAC to set the (???)
descriptor.descaddr = (uint32_t)&(*descriptor_section)[5]; // Set up a circular descriptor
descriptor.srcaddr = (uint32_t)inputCtrl1 + sizeof(uint32_t) * 2; // Configure the DMAC to set the (???)
descriptor.dstaddr = (uint32_t)adcResults0 + sizeof(uint16_t) * NUM_SAMPLES; // Place it in the middle of adcResults0 array
descriptor.dstaddr = (uint32_t)&adcResults0[NUM_SAMPLES] + sizeof(uint16_t) * NUM_SAMPLES; // Place it in the adcResults0 array
descriptor.dstaddr = (uint32_t)adcResults1 + sizeof(uint16_t) * NUM_SAMPLES; // Place it in the middle of adcResults1 array
descriptor.dstaddr = (uint32_t)&adcResults1[NUM_SAMPLES] + sizeof(uint16_t) * NUM_SAMPLES; // Place it in the adcResults1 array
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
// // Configure PB08 (A2) and PB09 (A3) for analog input
// PORT->Group[1].PINCFG[8].bit.PMUXEN = 1; // Enable peripheral multiplexer for PB08
// PORT->Group[1].PINCFG[9].bit.PMUXEN = 1; // Enable peripheral multiplexer for PB09
// // Set peripheral function B (0x1) for analog
// PORT->Group[1].PMUX[4].reg = PORT_PMUX_PMUXE(1) | PORT_PMUX_PMUXO(1); // PB08 is even, PB09 is odd, they share PMUX[4]
// Debug output
// Serial.print("PB08 PINCFG: 0x");
// Serial.println(PORT->Group[1].PINCFG[8].reg, HEX);
// Serial.print("PB09 PINCFG: 0x");
// Serial.println(PORT->Group[1].PINCFG[9].reg, HEX);
// Serial.print("PB08/PB09 PMUX: 0x");
// Serial.println(PORT->Group[1].PMUX[4].reg, HEX);
adc_init();
dma_init();
analogWriteResolution(12);
int rollovers = 0;
int dac = 1;
bool ascend = true;
ascend = false;
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
while (true);
// // DAC stuff on A0 for debugging
// if (dac <= 1) {
// ascend = true;
// if (dac >= 4095) {
// ascend = false;
// dac += ascend ? 5 : -5;
// analogWrite(A0, dac);
R0_P0_dirty = true;
#if DEBUG_R0_P0
Serial.print(5000);
Serial.print(",");
Serial.print(0);
Serial.print(",");
Serial.print(", ");
#endif
R0_P1_dirty = true;
#if DEBUG_R0_P1
Serial.print(5000);
Serial.print(",");
Serial.print(0);
Serial.print(",");
Serial.print(", ");
#endif
R1_P0_dirty = true;
#if DEBUG_R1_P0
Serial.print(5000);
Serial.print(",");
Serial.print(0);
Serial.print(",");
Serial.print(", ");
#endif
R1_P1_dirty = true;
#if DEBUG_R1_P1
Serial.print(5000);
Serial.print(",");
Serial.print(0);
Serial.print(",");
Serial.print(", ");
#endif
My hunch is that I'm somehow either improperly configuring the ADCs for averaging mode or that I'm overlooking something in the DMA descriptors that should be modified, but after looking at it all weekend I can't see where I'm going wrong. Please let me know if anything looks incorrect, or if anyone has ideas on what could be going wrong to cause this issue. Thanks!
