Installed version 2.3.8 but the port listing under tools is greyed out. loaded ver 1.8.19 and ports show. Using Tahoe, 26.5 Attempted installing drivers but no change(not sure if driver install good)
Mac intel or Apple Silicon?
which driver did you want to install ?
which board?
Intel, and wanted to install driver CH340 series that was advised on another site
After the driver installation, macOS may block the kernel extension. Open System Settings âžś Privacy & Security and look for an "Allow" button near a message saying software from the developer was blocked
if you have a UNO, no driver necessary. that could be used to test if your USB port works...
nothing showing in those settings. Did use uno, but port stays greyed
out
Should not neeed to install any drivers. Show us the System Report for USB and Thunderbolt/USB 4 with an UNO plugged in.
Hi @tom_m_p. I'm going to ask you to provide some additional information that might help us to identify the problem.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
- Select Arduino IDE > Quit Arduino IDE from the Arduino IDE menus if it is running.
All Arduino IDE windows will close. - Open macOS Launchpad.
- Type
terminalin the "Search" field. - Click on the "Terminal" icon.
A "Terminal" window will open. - Type the following command in the Terminal window:
"/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE" - Press the Enter key
- Wait for Arduino IDE to finish starting.
- Switch back to the Terminal window.
- Press the Command+A keyboard shortcut.
This will select all the text in the Terminal window. - Press the Command+C keyboard shortcut.
This will copy the selected text to the clipboard. - Open a reply here on this forum topic by clicking the "Reply" button.
- Click the
<CODE/>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the output is correctly formatted.
- Press the Command+V keyboard shortcut.
This will paste the output into the code block. - Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the "Reply" button to publish the post.
Please let us know if you have any questions or problems while following those instructions.
You neglected to add the quotation marks. These are required in the case where a path contains a space (note the space in the Arduino IDE.app component of the path).
Please try it again, but this time be careful to use the command exactly as I wrote it in my instructions.
Last login: Thu May 28 08:15:23 on console
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
Thomass-iMac:~ thomaspearson$ /Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE
-bash: /Applications/Arduino: No such file or directory
Thomass-iMac:~ thomaspearson$ Applications/Arduino IDE.app
-bash: Applications/Arduino: No such file or directory
Thomass-iMac:~ thomaspearson$ ls
Desktop Library note.txt
Documents Movies Pictures
Downloads Music Sites
iCloud Drive (Archive) My List.txt Untitled.txt
iCloud Drive (Archive) - 1 New document 1.2020_06_24_16_34_02.0.svg X-Plane 12
Instruct.txt New document 2.2020_06_24_16_34_02.2.svg
Thomass-iMac:~ thomaspearson$ cd Applications
Thomass-iMac:Applications thomaspearson$ ls
Autodesk Fusion Service Utility.app Autodesk Fusion.app Remove Autodesk Fusion.app
Thomass-iMac:Applications thomaspearson$ cd/Macintosh HD
-bash: cd/Macintosh: No such file or directory
Thomass-iMac:Applications thomaspearson$ Macintosh HD/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE
-bash: Macintosh: command not found
Thomass-iMac:Applications thomaspearson$ /Applications/AdBlock.app /Applications/Adobe\ Acrobat\ DC /Applications/Adobe\ Acrobat\ DC/Acrobat\ Uninstaller /Applications/Adobe\ Acrobat\ DC/Adobe\ Acrobat.app /Applications/AHFS\ Drug\ Information.app /System/Applications/App\ Store.app /System/Applications/Apps.app /Applications/Arduino\ IDE.app /Applications/Arduino.app /System/Applications/Automator.app /Applications/Banktivity\ 5\ 2.app /Applications/Blackmagic\ Disk\ Speed\ Test.app /System/Applications/Books.app /Applications/Brave\ Browser.app /Applications/Burn.app /System/Applications/Calculator.app /System/Applications/Calendar.app /Applications/Celestron\ Digital\ Imager\ HD.app /Applications/CH34xVCPDriver.app /System/Applications/Chess.app /System/Applications/Clock.app /System/Applications/Contacts.app /Applications/CubicSDR.app /Applications/Decompressor.app /Applications/demos /System/Applications/Dictionary.app /Applications/Disconnect\ Premium.app /Applications/EAGLE-7.7.0 /Applications/Easy\ MP3\ Converter\ Lite.app /Applications/Electric\ Bed.pdf /Applications/Elmedia\ Video\ Player.app /System/Applications/FaceTime.app /System/Applications/FindMy.app /Applications/Firefox.app /Applications/flipclock.app /Applications/Flowchart\ Designer.app /Applications/FolderMarker.app /System/Applications/Font\ Book.app /Applications/Foxit\ PDF\ Reader.app /System/Applications/Freeform.app /Applications/g\ Converter.app /System/Applications/Games.app /Applications/GarageBand.app /Applications/GIMP.app /Applications/Google\ Earth\ Pro.app /System/Applications/Home.app /Applications/iCircuit.app /System/Applications/Image\ Capture.app /Applications/iMovie.app /Applications/Inkscape.app /Applications/IP\ Scanner.app /System/Applications/iPhone\ Mirroring.app /System/Applications/Journal.app /Applications/Keynote.app /Applications/KiCad /Applications/Kindle.app /Applications/Amazon\ Kindle.app /Applications/LightBurn\ 2.app /Applications/LightBurn.app /Applications/MacVim.app /System/Applications/Mail.app /System/Applications/Maps.app /Applications/Menu\ World\ Time.app /System/Applications/Messages.app /Applications/Messenger.app /Applications/Microsoft\ Outlook.app /Applications/miDVD\ Pro.app /System/Applications/Mission\ Control.app /Applications/MKPlayer.app /Applications/Mr\ Stopwatch.app /System/Applications/Music.app /Applications/net.downloadhelper.coapp.app /System/Applications/News.app /Applications/NoteBurner\ iTunes\ DRM\ Audio\ Converter.app /System/Applications/Notes.app /Applications/Numbers.app /Applications/Open\ Any\ File.app /Applications/Pages.app /Applications/PanTunes.app /System/Applications/Passwords.app /Applications/PDFgear.app /System/Applications/Phone.app /System/Applications/Photo\ Booth.app /System/Applications/Photos.app /Applications/Pieces\ Web\ Extension\ App.app /Applications/Pixlr.app /System/Applications/Podcasts.app /System/Applications/Preview.app /Applications/QR\ Detective.app /System/Applications/QuickTime\ Player.app /Applications/RAR\ Extractor\ -\ Unarchiver.app /System/Applications/Reminders.app /Applications/RoboForm.app /Applications/Safari.app /Applications/SerialTools.app /System/Applications/Shortcuts.app /System/Applications/Siri.app /Applications/Speedtest.app /System/Applications/Stickies.app /System/Applications/Stocks.app /Applications/Swift\ Publisher\ 5.app /Applications/Switch.app /System/Applications/System\ Settings.app /Applications/Tenor.app /System/Applications/TextEdit.app /Applications/Thonny.app /System/Applications/Time\ Machine.app /Applications/Tiny\ PDF\ Editor.app /System/Applications/Tips.app /System/Applications/TV.app /Applications/Utilities /Applications/VLC.app /System/Applications/VoiceMemos.app /System/Applications/Weather.app Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE
-bash: /Applications/AdBlock.app: is a directory
Thomass-iMac:~ thomaspearson$ cd/
-bash: cd/: No such file or directory
Thomass-iMac:~ thomaspearson$ cls
-bash: cls: command not found
Thomass-iMac:~ thomaspearson$ cd\applications
-bash: cdapplications: command not found
Thomass-iMac:~ thomaspearson$ cd/Aplications
-bash: cd/Aplications: No such file or directory
Thomass-iMac:~ thomaspearson$ cd/ applications
Thomass-iMac:~ thomaspearson$ cd/ Applications
Thomass-iMac:~ thomaspearson$ dir
-bash: dir: command not found
Thomass-iMac:~ thomaspearson$ /applications/
-bash: /applications/: is a directory
Thomass-iMac:~ thomaspearson$ cd/Applications
-bash: cd/Applications: No such file or directory
Thomass-iMac:~ thomaspearson$ cd/Applications/
-bash: cd/Applications/: No such file or directory
Thomass-iMac:~ thomaspearson$ /applications/arduino ide
-bash: /applications/arduino: No such file or directory
Thomass-iMac:~ thomaspearson$ pwd
/Users/thomaspearson
Thomass-iMac:~ thomaspearson$ cs
-bash: cs: command not found
Thomass-iMac:Applications thomaspearson$ dir
Acrobat Uninstaller.app Font Book.app Open Any File.app
AdBlock.app Foxit PDF Reader.app Pages.app
Adobe Acrobat DC Freeform.app PanTunes.app
Adobe Acrobat.app g Converter.app Passwords.app
AHFS Drug Information.app Games.app PDFgear.app
App Store.app GarageBand.app Phone.app
Apps.app GIMP.app Photo Booth.app
Arduino IDE.app Google Earth Pro.app Photos.app
Arduino.app Home.app Pieces Web Extension App.app
Autodesk Fusion Service Utility.app iCircuit.app Pixlr.app
Autodesk Fusion.app Image Capture.app Podcasts.app
Automator.app iMovie.app Preview.app
Banktivity 5 2.app Inkscape.app QR Detective.app
Blackmagic Disk Speed Test.app IP Scanner.app QuickTime Player.app
Books.app iPhone Mirroring.app RAR Extractor - Unarchiver.app
Brave Browser.app Journal.app Reminders.app
Burn.app Keynote.app Remove Autodesk Fusion.app
Calculator.app KiCad RoboForm.app
Calendar.app Kindle Classic.app Safari.app
Celestron Digital Imager HD.app Kindle.app SerialTools.app
CH34xVCPDriver.app LightBurn 2.app Shortcuts.app
Chess.app LightBurn.app Siri.app
Clock.app MacVim.app Speedtest.app
Contacts.app Mail.app Stickies.app
CubicSDR.app Maps.app Stocks.app
Decompressor.app Menu World Time.app Swift Publisher 5.app
demos Messages.app Switch.app
Dictionary.app Messenger.app System Settings.app
Disconnect Premium.app Microsoft Outlook.app Tenor.app
EAGLE-7.7.0 miDVD Pro.app TextEdit.app
Easy MP3 Converter Lite.app Mission Control.app Thonny.app
Electric Bed.pdf MKPlayer.app Time Machine.app
Elmedia Video Player.app Mr Stopwatch.app Tiny PDF Editor.app
FaceTime.app Music.app Tips.app
Find My.app net.downloadhelper.coapp.app TV.app
Firefox.app News.app Utilities
FlipClock.app NoteBurner iTunes DRM Audio Converter.app VLC.app
Flowchart Designer.app Notes.app Voice Memos.app
FolderMarker.app Numbers.app Weather.app
Thomass-iMac:Applications thomaspearson$ arduino IDE
-bash: arduino: command not found
Thomass-iMac:Applications thomaspearson$ Arduino IDE.app/Contents/MacOS/Arduino IDE
-bash: Arduino: command not found
Thomass-iMac:Applications thomaspearson$ cd Arduino IDE.app/Contents/MacOS/Arduino IDE
-bash: cd: Arduino: No such file or directory
Thomass-iMac:Applications thomaspearson$ arduino.app
-bash: arduino.app: command not found
Thomass-iMac:Applications thomaspearson$ cd/arduino.app
-bash: cd/arduino.app: No such file or directory
Thomass-iMac:Applications thomaspearson$ calculator
-bash: calculator: command not found
Thomass-iMac:~ thomaspearson$ "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.3.9
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.9" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.5.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2026-05-26T14:02:43.375Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"arduino-ide"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.9","cliVersion":"1.5.0","buildDate":"2026-05-26T14:02:43.375Z"}
Starting backend process. PID: 26873
Showing main window early
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/thomaspearson/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2026-05-28T19:43:52.694Z root INFO Backend u.initialize: 21.0 ms [Finished 0.471 s after backend start]
2026-05-28T19:43:52.695Z root INFO Backend Object.initialize: 19.8 ms [Finished 0.471 s after backend start]
2026-05-28T19:43:52.695Z root INFO Backend a.initialize: 0.5 ms [Finished 0.471 s after backend start]
2026-05-28T19:43:52.695Z root INFO Backend a.initialize: 0.3 ms [Finished 0.471 s after backend start]
2026-05-28T19:43:52.695Z root INFO Backend u.initialize: 0.6 ms [Finished 0.472 s after backend start]
2026-05-28T19:43:52.696Z root INFO Backend l.initialize: 20.8 ms [Finished 0.473 s after backend start]
2026-05-28T19:43:52.701Z root INFO configured all backend app contributions
2026-05-28T19:43:52.701Z root INFO Backend l.onStart: 0.9 ms [Finished 0.479 s after backend start]
2026-05-28T19:43:52.701Z root INFO Backend d.onStart: 0.1 ms [Finished 0.479 s after backend start]
2026-05-28T19:43:52.702Z root INFO Backend a.onStart: 0.2 ms [Finished 0.480 s after backend start]
2026-05-28T19:43:52.702Z config INFO >>> Initializing CLI configuration...
2026-05-28T19:43:52.702Z root INFO Backend x.onStart: 0.2 ms [Finished 0.480 s after backend start]
2026-05-28T19:43:52.702Z config INFO Loading CLI configuration from /Users/thomaspearson/.arduinoIDE/arduino-cli.yaml...
2026-05-28T19:43:52.702Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2026-05-28T19:43:52.702Z root INFO Backend w.onStart: 0.2 ms [Finished 0.480 s after backend start]
2026-05-28T19:43:52.702Z discovery-log INFO start
2026-05-28T19:43:52.702Z discovery-log INFO start new deferred
2026-05-28T19:43:52.702Z root INFO Backend v.onStart: 0.2 ms [Finished 0.481 s after backend start]
2026-05-28T19:43:52.702Z root INFO Backend a.onStart: 0.1 ms [Finished 0.481 s after backend start]
2026-05-28T19:43:52.705Z root INFO Theia app listening on http://127.0.0.1:51407.
Restoring workspace roots: /Users/thomaspearson/Documents/Arduino/PB_N5110_Clock_ver_m_audio_board_copy_20230417090117
2026-05-28T19:43:52.705Z root INFO Finished starting backend application: 2.7 ms [Finished 0.483 s after backend start]
2026-05-28T19:43:52.705Z root WARN The local plugin referenced by local-dir:/Users/thomaspearson/.arduinoIDE/plugins does not exist.
2026-05-28T19:43:52.705Z root WARN The local plugin referenced by local-dir:/Users/thomaspearson/.arduinoIDE/deployedPlugins does not exist.
2026-05-28T19:43:52.713Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"/Users/thomaspearson/Library/Arduino15/libraries"},"data":"/Users/thomaspearson/Library/Arduino15","downloads":"/Users/thomaspearson/Library/Arduino15/staging","user":"/Users/thomaspearson/Documents/Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2026-05-28T19:43:52.713Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2026-05-28T19:43:52.713Z config INFO Loaded the CLI configuration.
2026-05-28T19:43:52.714Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///Users/thomaspearson/Library/Arduino15","sketchDirUri":"file:///Users/thomaspearson/Documents/Arduino","additionalUrls":["https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"],"network":"none","locale":"en"}
2026-05-28T19:43:52.714Z config INFO Validating the CLI configuration...
2026-05-28T19:43:52.724Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="arduino-cli version 1.5.0"
2026-05-28T19:43:52.725Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Using config file: /Users/thomaspearson/.arduinoIDE/arduino-cli.yaml"
time="2026-05-28T13:43:52-06:00" level=info msg="Executing `arduino-cli daemon`"
2026-05-28T19:43:52.730Z daemon INFO Daemon is now listening on 127.0.0.1:51408
{"IP":"127.0.0.1","Port":"51408"}
2026-05-28T19:43:52.730Z daemon INFO Daemon is running.
2026-05-28T19:43:52.749Z root INFO Resolve plugins list: 45.4 ms [Finished 0.527 s after backend start]
2026-05-28T19:43:52.759Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Checking signature" index=/Users/thomaspearson/Library/Arduino15/package_index.json signatureFile=/Users/thomaspearson/Library/Arduino15/package_index.json.sig trusted=true
2026-05-28T19:43:52.762Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Missing signature file" index=/Users/thomaspearson/Library/Arduino15/package_esp32_index.json
time="2026-05-28T13:43:52-06:00" level=info msg="Loading hardware from: /Users/thomaspearson/Library/Arduino15/packages"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading package SiliconLabs from: /Users/thomaspearson/Library/Arduino15/packages/SiliconLabs"
time="2026-05-28T13:43:52-06:00" level=info msg="Checking existence of 'tools' path: /Users/thomaspearson/Library/Arduino15/packages/SiliconLabs/tools"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading tools from dir: /Users/thomaspearson/Library/Arduino15/packages/SiliconLabs/tools"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="SiliconLabs:openocd@0.12.0-arduino1-static"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading package arduino from: /Users/thomaspearson/Library/Arduino15/packages/arduino/hardware"
2026-05-28T19:43:52.764Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Missing signature file" index=/Users/thomaspearson/Library/Arduino15/packages/arduino/hardware/avr/1.8.8/installed.json
2026-05-28T19:43:52.765Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.8"
2026-05-28T19:43:52.774Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Missing signature file" index=/Users/thomaspearson/Library/Arduino15/packages/arduino/hardware/esp32/2.0.18-arduino.5/installed.json
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded platform" platform="arduino:esp32@2.0.18-arduino.5"
2026-05-28T19:43:52.774Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Missing signature file" index=/Users/thomaspearson/Library/Arduino15/packages/arduino/hardware/zephyr_main/0.55.2/installed.json
2026-05-28T19:43:52.776Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded platform" platform="arduino:zephyr_main@0.55.2"
2026-05-28T19:43:52.776Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Checking existence of 'tools' path: /Users/thomaspearson/Library/Arduino15/packages/arduino/tools"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading tools from dir: /Users/thomaspearson/Library/Arduino15/packages/arduino/tools"
2026-05-28T19:43:52.776Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:adb@32.0.0"
2026-05-28T19:43:52.776Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2026-05-28T19:43:52.777Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2026-05-28T19:43:52.780Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:avrdude@8.0.0-arduino1"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino2"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:gen-rodata-ld@0.1.1"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:remoteocd@0.1.1"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:sync-zephyr-artifacts@0.2.1"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:zephyr-check-size@0.1.0"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="arduino:zephyr-sketch-tool@0.3.0"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading package attiny from: /Users/thomaspearson/Library/Arduino15/packages/attiny/hardware"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded platform" platform="attiny:avr@1.0.2"
2026-05-28T19:43:52.789Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Loading package builtin from: /Users/thomaspearson/Library/Arduino15/packages/builtin"
time="2026-05-28T13:43:52-06:00" level=info msg="Checking existence of 'tools' path: /Users/thomaspearson/Library/Arduino15/packages/builtin/tools"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading tools from dir: /Users/thomaspearson/Library/Arduino15/packages/builtin/tools"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.12"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.6"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.2"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.3"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.10.0"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.11.0"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading package esp32 from: /Users/thomaspearson/Library/Arduino15/packages/esp32/hardware"
time="2026-05-28T13:43:52-06:00" level=info msg="Missing signature file" index=/Users/thomaspearson/Library/Arduino15/packages/esp32/hardware/esp32/3.3.8/installed.json
2026-05-28T19:43:52.897Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded platform" platform="esp32:esp32@3.3.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Checking existence of 'tools' path: /Users/thomaspearson/Library/Arduino15/packages/esp32/tools"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading tools from dir: /Users/thomaspearson/Library/Arduino15/packages/esp32/tools"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esp-rv32@2601"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esp-x32@2601"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esp32-libs@3.3.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esp32c3-libs@3.3.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esp32c5-libs@3.3.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esp32c6-libs@3.3.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esp32h2-libs@3.3.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esp32p4-libs@3.3.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esp32p4_es-libs@3.3.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esp32s2-libs@3.3.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esp32s3-libs@3.3.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esptool_py@3.0.0"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:esptool_py@5.2.0"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@4.0.2-db0513a"
2026-05-28T19:43:52.905Z daemon INFO time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20230921"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20251215"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@16.3_20250913"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:s3-gcc@2021r2-p5"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@16.3_20250913"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading package esp8266 from: /Users/thomaspearson/Library/Arduino15/packages/esp8266/hardware"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded platform" platform="esp8266:esp8266@2.4.0-rc1"
time="2026-05-28T13:43:52-06:00" level=info msg="Checking existence of 'tools' path: /Users/thomaspearson/Library/Arduino15/packages/esp8266/tools"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading tools from dir: /Users/thomaspearson/Library/Arduino15/packages/esp8266/tools"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp8266:esptool@0.4.9"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@0.1.2"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@1.20.0-26-gb404fb9-2"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading package zephyr from: /Users/thomaspearson/Library/Arduino15/packages/zephyr"
time="2026-05-28T13:43:52-06:00" level=info msg="Checking existence of 'tools' path: /Users/thomaspearson/Library/Arduino15/packages/zephyr/tools"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading tools from dir: /Users/thomaspearson/Library/Arduino15/packages/zephyr/tools"
time="2026-05-28T13:43:52-06:00" level=info msg="Loaded tool" tool="zephyr:arm-zephyr-eabi@0.16.8"
time="2026-05-28T13:43:52-06:00" level=info msg="Loading hardware from: /Users/thomaspearson/Documents/Arduino/hardware"
2026-05-28T19:43:53.045Z root INFO Deploy plugins list: 341.7 ms [Finished 0.823 s after backend start]
isTempSketch: false. Input was /Users/thomaspearson/Documents/Arduino/PB_N5110_Clock_ver_m_audio_board_copy_20230417090117/PB_N5110_Clock_ver_m_audio_board_copy_20230417090117.ino
2026-05-28T19:43:56.126Z config INFO The CLI config is valid.
2026-05-28T19:43:56.126Z config INFO <<< Initialized the CLI configuration.
2026-05-28T19:43:56.135Z daemon INFO time="2026-05-28T13:43:56-06:00" level=info msg="Loading package espressif from: /Users/thomaspearson/Documents/Arduino/hardware/espressif"
2026-05-28T19:43:56.137Z daemon INFO time="2026-05-28T13:43:56-06:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2026-05-28T13:43:56-06:00" level=info msg="Loaded platform" platform="espressif:esp32@0.0.1"
2026-05-28T19:43:56.140Z daemon INFO time="2026-05-28T13:43:56-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Library/Arduino15/packages/arduino/hardware/avr/1.8.8/libraries isSingleLibrary=false location=platform
2026-05-28T19:43:56.140Z daemon INFO time="2026-05-28T13:43:56-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Library/Arduino15/packages/arduino/hardware/esp32/2.0.18-arduino.5/libraries isSingleLibrary=false location=platform
2026-05-28T19:43:56.140Z daemon INFO time="2026-05-28T13:43:56-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Library/Arduino15/packages/arduino/hardware/zephyr_main/0.55.2/libraries isSingleLibrary=false location=platform
2026-05-28T19:43:56.140Z daemon INFO time="2026-05-28T13:43:56-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Documents/Arduino/hardware/espressif/esp32/libraries isSingleLibrary=false location=platform
2026-05-28T19:43:56.140Z daemon INFO time="2026-05-28T13:43:56-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.0-rc1/libraries isSingleLibrary=false location=platform
2026-05-28T19:43:56.140Z daemon INFO time="2026-05-28T13:43:56-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Library/Arduino15/packages/esp32/hardware/esp32/3.3.8/libraries isSingleLibrary=false location=platform
2026-05-28T19:43:56.141Z daemon INFO time="2026-05-28T13:43:56-06:00" level=info msg="Loading libraries index file" index=/Users/thomaspearson/Library/Arduino15/library_index.json
2026-05-28T19:43:56.336Z daemon INFO time="2026-05-28T13:43:56-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Library/Arduino15/libraries isSingleLibrary=false location=ide
2026-05-28T19:43:56.336Z daemon INFO time="2026-05-28T13:43:56-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Documents/Arduino/libraries isSingleLibrary=false location=user
2026-05-28T19:43:56.641Z root INFO creating connection for 1
2026-05-28T19:43:56.770Z discovery-log INFO start resolved watching
2026-05-28T19:43:56.774Z daemon INFO time="2026-05-28T13:43:56-06:00" level=error msg="Stopped decode loop: read |0: file already closed" discovery="builtin:mdns-discovery"
2026-05-28T19:43:56.774Z daemon INFO time="2026-05-28T13:43:56-06:00" level=error msg="Discovery builtin:mdns-discovery failed to run: discovery builtin:mdns-discovery process not started: fork/exec /Users/thomaspearson/Library/Arduino15/packages/builtin/tools/mdns-discovery/1.0.12/mdns-discovery: bad CPU type in executable"
2026-05-28T19:43:56.777Z daemon INFO time="2026-05-28T13:43:56-06:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:serial-discovery"
2026-05-28T19:43:56.777Z daemon INFO time="2026-05-28T13:43:56-06:00" level=error msg="Discovery builtin:serial-discovery failed to run: discovery builtin:serial-discovery process not started: fork/exec /Users/thomaspearson/Library/Arduino15/packages/builtin/tools/serial-discovery/1.4.3/serial-discovery: bad CPU type in executable"
2026-05-28T19:43:57.286Z root WARN A command editor.action.toggleStickyScroll is already registered.
2026-05-28T19:43:57.292Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: </Users/thomaspearson/Documents/Arduino/PB_N5110_Clock_ver_m_audio_board_copy_20230417090117/PB_N5110_Clock_ver_m_audio_board_copy_20230417090117.ino>, response: </Users/thomaspearson/Documents/Arduino/PB_N5110_Clock_ver_m_audio_board_copy_20230417090117>.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2026-05-28T19:43:57.362Z root INFO Start frontend contributions: 211.3 ms [Finished 1.234 s after frontend start]
2026-05-28T19:43:57.362Z root INFO Changed application state from 'init' to 'started_contributions'.
2026-05-28T19:43:57.368Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2026-05-28T19:43:57.368Z root INFO >>> Restoring the layout state...
2026-05-28T19:43:57.395Z root INFO [a15fef89-f499-415e-bf03-d4e4ad4eb209] Waiting for backend deployment: 46.8 ms [Finished 1.278 s after frontend start]
[26843:0528/134357.484354:ERROR:trust_store_mac.cc(750)] Error parsing certificate:
ERROR: Failed parsing extensions
2026-05-28T19:43:57.772Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886) starting instance
[Object: null prototype] {}
2026-05-28T19:43:58.205Z root INFO [a15fef89-f499-415e-bf03-d4e4ad4eb209] Sync of 23 plugins: 812.6 ms [Finished 2.090 s after frontend start]
2026-05-28T19:43:58.225Z root INFO ------- SERIALIZED LAYOUT DATA -------
2026-05-28T19:43:58.225Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///Users/thomaspearson/Documents/Arduino/PB_N5110_Clock_ver_m_audio_board_copy_20230417090117/PB_N5110_Clock_ver_m_audio_board_copy_20230417090117.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":98,\"column\":21},\"position\":{\"lineNumber\":98,\"column\":21}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":90,\"column\":1},\"firstPositionDeltaTop\":-7},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":182,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":0}},"pinned":[false,false],"size":125,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[\\\"done\\\",\\\"audio\\\",\\\"audiop\\\",\\\"audiopwr\\\",\\\"aud\\\",\\\"audpwr\\\",\\\"11\\\"],\\\"index\\\":6},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":269},"rightPanel":{"type":"sidepanel","items":[]}}
2026-05-28T19:43:58.226Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2026-05-28T19:43:58.447Z root INFO <<< The layout has been successfully restored.
2026-05-28T19:43:58.501Z root INFO Initialize the workbench layout: 1080.1 ms [Finished 2.333 s after frontend start]
2026-05-28T19:43:58.501Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2026-05-28T19:43:58.501Z root INFO [a15fef89-f499-415e-bf03-d4e4ad4eb209] Loading plugin contributions
2026-05-28T19:43:58.501Z root INFO [a15fef89-f499-415e-bf03-d4e4ad4eb209] Load contributions of 23 plugins: 51.2 ms [Finished 2.385 s after frontend start]
2026-05-28T19:43:58.553Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2026-05-28T19:43:58.553Z root WARN a registered grammar configuration for 'cpp' language is overridden
2026-05-28T19:43:58.690Z root ERROR [hosted-plugin: 26886] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2026-05-28T19:43:58.690Z root ERROR [hosted-plugin: 26886] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
2026-05-28T19:43:58.690Z root ERROR [hosted-plugin: 26886] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2026-05-28T19:43:58.690Z root ERROR [hosted-plugin: 26886] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2026-05-28T19:43:58.690Z root ERROR [hosted-plugin: 26886] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
2026-05-28T19:43:58.690Z root ERROR [hosted-plugin: 26886] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
2026-05-28T19:43:58.690Z root ERROR [hosted-plugin: 26886] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
2026-05-28T19:43:58.690Z root ERROR [hosted-plugin: 26886] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
2026-05-28T19:43:58.690Z root ERROR [hosted-plugin: 26886] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
2026-05-28T19:43:58.690Z root ERROR [hosted-plugin: 26886] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2026-05-28T19:43:58.696Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): PluginManagerExtImpl/init()
2026-05-28T19:43:58.698Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-arduino-api@0.1.2 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.750Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(json-language-features@1.88.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.753Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(cortex-debug@1.5.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.753Z root INFO [hosted-plugin: 26886] Debugger contribution has been registered: cortex-debug
2026-05-28T19:43:58.754Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-arduino-tools@0.1.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.755Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(cpp@1.88.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.756Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(json@1.88.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.757Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-bg@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.759Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-cs@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.760Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-de@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.760Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-es@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.761Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-fr@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.762Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-hu@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.762Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-it@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.762Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-ja@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.762Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-ko@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.763Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-nl@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.763Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-pl@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.763Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-pt-BR@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.763Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-ru@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.764Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-tr@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.764Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-uk@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.764Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-zh-hans@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.764Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): initializing(vscode-language-pack-zh-hant@1.96.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2026-05-28T19:43:58.783Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/node/jsonClientMain)
2026-05-28T19:43:58.820Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/extension.js)
2026-05-28T19:43:58.838Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-api/extension/dist/extension.js)
2026-05-28T19:43:58.840Z root INFO [hosted-plugin: 26886] calling activation function on VS Code Arduino Tools
2026-05-28T19:43:58.840Z root INFO [hosted-plugin: 26886] calling activation function on Arduino IDE API for VS Code extensions
2026-05-28T19:43:58.845Z root INFO [a15fef89-f499-415e-bf03-d4e4ad4eb209] Starting plugins.
2026-05-28T19:43:58.865Z root INFO [hosted-plugin: 26886] PLUGIN_HOST(26886): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension.js)
2026-05-28T19:43:58.888Z root INFO [hosted-plugin: 26886] Debug configuration provider has been registered: cortex-debug, trigger: 1
2026-05-28T19:43:58.888Z root INFO [hosted-plugin: 26886] calling activation function on Cortex-Debug
2026-05-28T19:43:58.890Z root INFO [hosted-plugin: 26886] GDB server console created
2026-05-28T19:43:58.897Z root INFO [a15fef89-f499-415e-bf03-d4e4ad4eb209] Start of 23 plugins: 395.0 ms [Finished 2.782 s after frontend start]
2026-05-28T19:43:59.014Z root INFO [hosted-plugin: 26886] calling activation function on JSON Language Features (built-in)
2026-05-28T19:43:59.455Z root INFO Frontend application start: 2242.7 ms [Finished 7.234 s after backend start]
2026-05-28T19:43:59.469Z root INFO Replace loading indicator with ready workbench UI (animation): 838.9 ms [Finished 3.226 s after frontend start]
2026-05-28T19:43:59.469Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2026-05-28T19:43:59.469Z root WARN Linked preference "workbench.colorCustomizations" not found.
Checking for update
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <I2CScanner.ino> and sketch folder name <i2c_scanner>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <GPSdataTest.ino> and sketch folder name <GPSdatatest>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <HelloWorld.ino> and sketch folder name <RalphNokia5110>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <PondLevel.ino> and sketch folder name <PondLevel_nonNRF>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <LORA_RXSIMPLE.ino> and sketch folder name <LORA_RXsimple>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <DogAlarmMainA.ino> and sketch folder name <DogAlarmA>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <DogAlarmMainB.ino> and sketch folder name <DogAlarmB>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <5883_controlEverything.ino> and sketch folder name <i2c_scanner>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <WaterFlowGauge.pde> and sketch folder name <WaterFlowGauge-master>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <rawirdecode.pde> and sketch folder name <Raw-IR-decoder-for-Arduino-master>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <nRF24_basicTx_test.ino> and sketch folder name <nRF24_basic_Tx_test>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <rawirdecodestruct.ino> and sketch folder name <rawirdecode>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <YourDuinoPanTiltTest1.ino> and sketch folder name <YourDuinoPanTiltTest1_copy_20230101162358>. Skipping
2026-05-28T19:43:59.520Z sketches-service WARN Mismatching sketch file <YourDuinoPanTiltTest1.ino> and sketch folder name <YourDuinoPanTiltTest1_copy_20230106112357>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <I2CScanner.ino> and sketch folder name <i2c_scanner>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <GPSdataTest.ino> and sketch folder name <GPSdatatest>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <HelloWorld.ino> and sketch folder name <RalphNokia5110>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <PondLevel.ino> and sketch folder name <PondLevel_nonNRF>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <LORA_RXSIMPLE.ino> and sketch folder name <LORA_RXsimple>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <DogAlarmMainA.ino> and sketch folder name <DogAlarmA>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <DogAlarmMainB.ino> and sketch folder name <DogAlarmB>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <5883_controlEverything.ino> and sketch folder name <i2c_scanner>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <WaterFlowGauge.pde> and sketch folder name <WaterFlowGauge-master>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <rawirdecode.pde> and sketch folder name <Raw-IR-decoder-for-Arduino-master>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <nRF24_basicTx_test.ino> and sketch folder name <nRF24_basic_Tx_test>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <rawirdecodestruct.ino> and sketch folder name <rawirdecode>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <YourDuinoPanTiltTest1.ino> and sketch folder name <YourDuinoPanTiltTest1_copy_20230101162358>. Skipping
2026-05-28T19:43:59.573Z sketches-service WARN Mismatching sketch file <YourDuinoPanTiltTest1.ino> and sketch folder name <YourDuinoPanTiltTest1_copy_20230106112357>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <I2CScanner.ino> and sketch folder name <i2c_scanner>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <GPSdataTest.ino> and sketch folder name <GPSdatatest>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <HelloWorld.ino> and sketch folder name <RalphNokia5110>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <PondLevel.ino> and sketch folder name <PondLevel_nonNRF>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <LORA_RXSIMPLE.ino> and sketch folder name <LORA_RXsimple>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <DogAlarmMainA.ino> and sketch folder name <DogAlarmA>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <DogAlarmMainB.ino> and sketch folder name <DogAlarmB>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <5883_controlEverything.ino> and sketch folder name <i2c_scanner>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <WaterFlowGauge.pde> and sketch folder name <WaterFlowGauge-master>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <rawirdecode.pde> and sketch folder name <Raw-IR-decoder-for-Arduino-master>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <nRF24_basicTx_test.ino> and sketch folder name <nRF24_basic_Tx_test>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <rawirdecodestruct.ino> and sketch folder name <rawirdecode>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <YourDuinoPanTiltTest1.ino> and sketch folder name <YourDuinoPanTiltTest1_copy_20230101162358>. Skipping
2026-05-28T19:43:59.578Z sketches-service WARN Mismatching sketch file <YourDuinoPanTiltTest1.ino> and sketch folder name <YourDuinoPanTiltTest1_copy_20230106112357>. Skipping
2026-05-28T19:43:59.645Z root INFO Starting language server: arduino:avr:uno
2026-05-28T19:43:59.645Z daemon INFO time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:avrdude@8.0.0-arduino1"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@5.2.0"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esp32s3-libs@3.3.8"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esp32p4-libs@3.3.8"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp8266:esptool@0.4.9"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:zephyr-sketch-tool@0.3.0"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:sync-zephyr-artifacts@0.2.1"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esp32p4_es-libs@3.3.8"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp-elf-gdb@16.3_20250913"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:openocd-esp32@v0.12.0-esp32-20251215"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esp32-libs@3.3.8"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esp32s2-libs@3.3.8"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2601"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:gen-rodata-ld@0.1.1"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:bossac@1.9.1-arduino2"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.3"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esp32c5-libs@3.3.8"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esp32h2-libs@3.3.8"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:mklittlefs@4.0.2-db0513a"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:remoteocd@0.1.1"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:adb@32.0.0"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:mkspiffs@0.2.3"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.12"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esp32c6-libs@3.3.8"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:s3-gcc@2021r2-p5"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@16.3_20250913"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp8266:xtensa-lx106-elf-gcc@1.20.0-26-gb404fb9-2"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esp32c3-libs@3.3.8"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="esp32:esp-rv32@2601"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="arduino:zephyr-check-size@0.1.0"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="zephyr:arm-zephyr-eabi@0.16.8"
time="2026-05-28T13:43:59-06:00" level=info msg="Tool required for debug" tool="SiliconLabs:openocd@0.12.0-arduino1-static"
2026-05-28T19:43:59.646Z root ERROR Failed to get debug config: arduino:avr:uno, undefined Error: Debugging is not supported.
at Object.callback (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:4761913)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:3797628)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:2231404)
at Object.onReceiveStatus (/Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:2230849)
at /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/main.js:2:4367730
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
Update for version 2.3.9 is not available (latest version: 2.3.9, downgrade is allowed).
2026-05-28T19:44:00.210Z root ERROR ---- !!!SLOW!!! DURATION: search took 736.091 ms. Args: [{"type":"Updatable"}] ----
2026-05-28T19:44:00.210Z daemon INFO time="2026-05-28T13:44:00-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Library/Arduino15/libraries isSingleLibrary=false location=ide
time="2026-05-28T13:44:00-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Library/Arduino15/packages/arduino/hardware/avr/1.8.8/libraries isSingleLibrary=false location=platform
time="2026-05-28T13:44:00-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Documents/Arduino/libraries isSingleLibrary=false location=user
2026-05-28T19:44:00.356Z daemon INFO time="2026-05-28T13:44:00-06:00" level=info msg="Resolving include toneAC.h for arch avr"
time="2026-05-28T13:44:00-06:00" level=info msg=" found better lib" lib=toneAC prio=6B1
2026-05-28T19:44:00.400Z daemon INFO time="2026-05-28T13:44:00-06:00" level=info msg="Resolving include U8g2lib.h for arch avr"
time="2026-05-28T13:44:00-06:00" level=info msg=" found better lib" lib=U8g2 prio=3EB
2026-05-28T19:44:00.575Z daemon INFO time="2026-05-28T13:44:00-06:00" level=info msg="Resolving include SPI.h for arch avr"
time="2026-05-28T13:44:00-06:00" level=info msg=" found better lib" lib=SPI prio=6B0
2026-05-28T19:44:00.745Z daemon INFO time="2026-05-28T13:44:00-06:00" level=info msg="Resolving include Wire.h for arch avr"
time="2026-05-28T13:44:00-06:00" level=info msg=" found better lib" lib=Wire prio=6B0
2026-05-28T19:44:01.484Z root WARN Widget was activated, but did not accept focus after 2000ms: serial-monitor
2026-05-28T19:44:02.699Z daemon INFO time="2026-05-28T13:44:02-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Library/Arduino15/libraries isSingleLibrary=false location=ide
2026-05-28T19:44:02.699Z daemon INFO time="2026-05-28T13:44:02-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Library/Arduino15/packages/arduino/hardware/avr/1.8.8/libraries isSingleLibrary=false location=platform
time="2026-05-28T13:44:02-06:00" level=info msg="Adding libraries dir" dir=/Users/thomaspearson/Documents/Arduino/libraries isSingleLibrary=false location=user
OK, great, I see the cause here:
Does your Mac computer have an Apple Silicon , or an "Intel" processor?
Intel
Hmmm. My hypothesis is that somehow you ended up with the Apple Silicon build of serial-discovery installed on your computer.
serial-discovery is a helper tool used by Arduino IDE. This tool provides Arduino IDE with the list of serial ports on your computer. When Arduino IDE tried to start serial-discovery, an error occurred.
Arduino IDE automatically installs serial-discovery. Arduino distributes a build for each of the supported host systems (macOS Apple Silicon, macOS Intel, Windows x86, Windows ARM, etc.). Arduino IDE automatically installs the appropriate build of serial-discovery for the host machine it is running on. So Arduino IDE should have installed the macOS Intel build of serial-discovery on your computer.
Please perform the following experiment and then report your results:
- Open macOS Launchpad.
- Type
terminalin the "Search" field. - Click on the "Terminal" icon.
A "Terminal" window will open. - Type the following command in the Terminal window:
file /Users/thomaspearson/Library/Arduino15/packages/builtin/tools/serial-discovery/1.4.3/serial-discovery - Press the Enter key.
You should see some information about theserial-discoveryfile printed in the terminal. - Press the Command+A keyboard shortcut.
This will select all the text in the Terminal window. - Press the Command+C keyboard shortcut to copy the selected text.
- Open a reply here on this forum topic by clicking the "Reply" button.
- Press the Command+V keyboard shortcut to paste the copied text.
- Click the "Reply" button to publish the post.
Please let us know if you have any questions or problems while following those instructions.
I had a hypothesis that maybe there was a problem with our release packaging system that resulted in the macOS Intel package accidentally containing the executable built for Apple Silicon. However, I just checked the macOS Intel build of the version 1.4.3 of serial-discovery that is erroring on your machine, and it is indeed an x86-64 executable as expected (for some reason Apple uses the term "Intel" to refer to the x86 processor architecture). So that hypothesis is disproven.
I guess as an engineer you would have expected the terms “x86_64” and “arm64”, but Apple is more consumer-oriented and would naturally use “Intel” and “Apple Silicon” which everyone will get .
That’s possibly a legacy from the PowerPC days where the consumer name and the engineering shorthand were essentially the same thing, so the habit of aligning the two stayed on.
Also run "uname -m" in a terminal window to confirm which CPU your Mac really has.
It should be the same as the CPU info from the "file /Users/thomaspearson/Library/Arduino15/packages/builtin/tools/serial-discovery/1.4.3/serial-discovery" command.
This "bad CPU type in executable" means they are different. Seeing both would show a better picture of what's really going wrong.
Thomass-iMac:~ thomaspearson$ uname -m
x86_64
Thomass-iMac:~ thomaspearson$ file /Users/thomaspearson/Library/Arduino15/packages/builtin/tools/serial-discovery/1.4.3/serial-discovery
/Users/thomaspearson/Library/Arduino15/packages/builtin/tools/serial-discovery/1.4.3/serial-discovery: Mach-O 64-bit executable arm64
x86_64
OK, that confirms my hypothesis. You did end up with the Apple Silicon build of the serial-discovery tool.
- Type
file "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE" - Press the Enter key.
You should see some information about theArduino IDEfile printed in the terminal. - Press the Command+A keyboard shortcut.
