Hi All!
Using a Arduino clone but can't upload new code. Using a macbook pro with Mojave.
Ports do show up (the usb) and I can get board info.
UNO R3 Plus Sensor I/O Shield Development Board Atmega328P ATmega16U2 Multifunctional Microcontroller Module Compatible with Arduino
The board was "preloaded" with the internal / pin13 1000 ms blink
If I run virtualbox with win7 or win10 it works and I can upload and the com3 appears in the dropdown fine so the hardware is fine.
What can I do? I need som kind of port driver?
/ johan
Arduino: 1.8.8 (Mac OS X), Board: "Arduino/Genuino Uno"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/johankjellgren/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/johankjellgren/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/johankjellgren/Documents/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10808 -build-path /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494 -warnings=all -build-cache /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_cache_482982 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/johankjellgren/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/johankjellgren/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/johankjellgren/Documents/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10808 -build-path /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494 -warnings=all -build-cache /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_cache_482982 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
Using board 'uno' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Using core 'arduino' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/sketch/Blink.ino.cpp -o /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/sketch/Blink.ino.cpp -o /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_cache_482982/core/core_arduino_avr_uno_51f02b7210b938436b779d1c032618e1.a
Linking everything together...
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.elf /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/sketch/Blink.ino.cpp.o /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/../arduino_cache_482982/core/core_arduino_avr_uno_51f02b7210b938436b779d1c032618e1.a -L/var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494 -lm
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.elf /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.eep
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy -O ihex -R .eeprom /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.elf /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.hex
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-size -A /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.elf
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem4101 -b115200 -D -Uflash:w:/var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005
Copyright (c) 2007-2014
System wide configuration file is "/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf"
User configuration file is "/Users/johankjellgren/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem4101
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
had to cut some out to get below 9000. it was 9 more fails at the end
plugged in another cheap clone and now different ports shows up without me setting up anything else.
Now all works perfectly with that clone. original problem still there.
I thought the ports were machine specific not board specific?
