Mach3, M6, Modbus, Arduino, Tool changer, Brain
Hi There,
I have built an arduino-based tool changer for a conventional 2-axis turning lathe machine. It works by receiving a input of 1 to 12 through either the serial monitor or a bluetooth device.
I would like to be able to use this with Mach 3. If I have a tool change in the G-Codes ex. T0101 it should send "1" to the arduino and run the code to do the change.
I have read that this can be done by building a brain in mach 3 using modbus. Is there anyone here that has any experience with this or has ever done anything similar whom might be able to point me in the right direction?
Thank you
Sorry I cannot help you, to much missing information. You might post on the Pay someone for coding location. You might expand on your jargon, a lot of us do not know what G-Codes are along with Mach 3 etc. Links and schematics always help.
I can't believe Mach3 is still around! Your question would be better pursued on the Mach3 forum, if it still exists.
Machsupport Forum - Index
Can we guess you have the source code for Mach 3?
No, he does not have the source code for Mach3. Mach3 is commercial software, a CNC controller application. It is NOT public domain.
Yes, I know. I had a modified version running a CNC selective soldering machine.
Then you should know he does not have the source code. He is asking how to use Mach3 macros or "brains" (Mach3 simple logic functions) to trigger tool changes. Hence my recommendation that he go to the ArtSoft Mach3 forum, where there are people who understand how to do that. It's really a Mach3 question, not an Arduino question.
Thank You, I will try out the Mach 3 forum.
I have a small CN (380mm x 400mm) built by myself. I use Mack3 free.
In the past I used the PC's parallel output, but it needs to be a desktop or notebook with an interface that accepts a PCI/Parallel card.
But in the year 2020 I found the board "DrufelCNC_BSMCE04U" to control the CNC.
It has the great advantage of using the USB bus, and comes with a driver to convert the Mack3's output from parallel to USB.
I bought it and installed it on my CNC and it works great using the notebook's USB port.
It has 4 outputs for general use. Out1 to Out4.
As I've never used these outputs, I don't know if it can be useful for your case, but follow the board's manual:
Hi Ruilviana, thank you but not sure if that would work.
Hi there,
I have read all the posts I could find on the mach 3 forums concerning arduino and mach 3 and connecting this using modbus.
http://www.machsupport.com/forum/index.php/topic,22982.0.html
This post from Zafar has been really helpful in connecting arduino as a slave to mach3 and using it with 2 x potentiometers for FRO and Spindle override
I want to do something similar with the Automatic Tool Changer.
the only thing I need is it should send an integer value between 1 to 12 to the arduino every time it encounters the M6 G code and based on what tool was selected like T0101 (Tool 1)
ex. M6 T0101 - should send "1" to the arduino.
I have no idea how to modify the code to do this. Is there anyone who has done this before??
here is the code that can communicate to Mach 3:
 Modbus over serial line - RTU Slave Arduino Sketch
 By Juan Pablo Zometa : jpmzometa@gmail.com
 http://sites.google.com/site/jpmzometa/
 and Samuel Marco: sammarcoarmengol@gmail.com
 and Andras Tucsni.
 These functions implement functions 3, 6, and 16 (read holding registers,
 preset single register and preset multiple registers) of the
 Modbus RTU Protocol, to be used over the Arduino serial connection.
 This implementation DOES NOT fully comply with the Modbus specifications.
 This Arduino adaptation is derived from the work
 By P.Costigan email: phil@pcscada.com.au http://pcscada.com.au
 These library of functions are designed to enable a program send and
 receive data from a device that communicates using the Modbus protocol.
 Copyright (C) 2000 Philip Costigan  P.C. SCADA LINK PTY. LTD.
 This program is free software; you can redistribute it and/or modify
 it under the terms of the GNU General Public License as published by
 the Free Software Foundation; either version 2 of the License, or
 (at your option) any later version.
 This program is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 GNU General Public License for more details.
 You should have received a copy of the GNU General Public License
 along with this program; if not, write to the Free Software
 Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
 The functions included here have been derived from the
 Modicon Modbus Protocol Reference Guide
 which can be obtained from Schneider at www.schneiderautomation.com.
 This code has its origins with
 paul@pmcrae.freeserve.co.uk (http://www.pmcrae.freeserve.co.uk)
 who wrote a small program to read 100 registers from a modbus slave.
 I have used his code as a catalist to produce this more functional set
 of functions. Thanks paul.
 * configure_mb_slave(baud, parity, tx_en_pin)
 * sets the communication parameters for of the serial line.
 * baud: baudrate in bps (typical values 9600, 19200... 115200)
 * parity: a single character sets the parity mode (character frame format):
 *         'n' no parity (8N1); 'e' even parity (8E1), 'o' for odd parity (8O1).
 * tx_en_pin: arduino pin number that controls transmision/reception
 *        of an external half-duplex device (e.g. a RS485 interface chip).
 *        0 or 1 disables this function (for a two-device network)
 *        >2 for point-to-multipoint topology (e.g. several arduinos)
void configure_mb_slave(long baud, char parity, char txenpin);
 * update_mb_slave(slave_id, holding_regs_array, number_of_regs)
 * checks if there is any valid request from the modbus master. If there is,
 * performs the action requested
 * slave: slave id (1 to 127)
 * regs: an array with the holding registers. They start at address 1 (master point of view)
 * regs_size: total number of holding registers.
 * returns: 0 if no request from master,
 * 	NO_REPLY (-1) if no reply is sent to the master
 * 	an exception code (1 to 4) in case of a modbus exceptions
 * 	the number of bytes sent as reply ( > 4) if OK.
int update_mb_slave(unsigned char slave, int *regs,
unsigned int regs_size);
int t1,t2,t3,t4,t5 ;
/* Modbus RTU common parameters, the Master MUST use the same parameters */
enum {
        MB_SLAVE = 1,	/* modbus slave id */
/* slave registers example */
enum {
        MB_REG0,
        MB_REG1,
        // line below is for holding registers.    'vinny'
        MB_REGS	= 40 	/* total number of registers on slave */
int regs[MB_REGS];	/* this is the slave's modbus data map */
        /* Modbus setup example, the master must use the same COM parameters */
        /* 115200 bps, 8N1, two-device network */
        //  changed to 19200  bps, 8N1, two-device network 'vinny'
        configure_mb_slave(9600, 'n', 1);
        /* This is all for the Modbus slave */
	update_mb_slave(MB_SLAVE, regs, MB_REGS) ;
regs[0]=analogRead(A0);
regs[1]=analogRead(A1);
 * BEGIN MODBUS RTU SLAVE FUNCTIONS
/* global variables */
unsigned int Txenpin = 0;        /* Enable transmission pin, used on RS485 networks */
/* enum of supported modbus function codes. If you implement a new one, put its function code here ! */
enum {
        FC_READ_REGS  = 0x03,   //Read contiguous block of holding register
        FC_WRITE_REG  = 0x06,   //Write single holding register
        FC_WRITE_REGS = 0x10    //Write block of contiguous registers
/* supported functions. If you implement a new one, put its function code into this array! */
const unsigned char fsupported[] = { FC_READ_REGS, FC_WRITE_REG, FC_WRITE_REGS };
/* constants */
enum {
        MAX_READ_REGS = 0x7D,
        MAX_WRITE_REGS = 0x7B,
        MAX_MESSAGE_LENGTH = 256
enum {
        RESPONSE_SIZE = 6,
        EXCEPTION_SIZE = 3,
        CHECKSUM_SIZE = 2
/* exceptions code */
enum {
        NO_REPLY = -1,
        EXC_FUNC_CODE = 1,
        EXC_ADDR_RANGE = 2,
        EXC_REGS_QUANT = 3,
        EXC_EXECUTE = 4
/* positions inside the query/response array */
enum {
        SLAVE = 0,
        FUNC,
        START_H,
        START_L,
        REGS_H,
        REGS_L,
        BYTE_CNT
CRC
 INPUTS:
 	buf   ->  Array containing message to be sent to controller.
 	start ->  Start of loop in crc counter, usually 0.
 	cnt   ->  Amount of bytes in message being sent to controller/
 OUTPUTS:
 	temp  ->  Returns crc byte for message.
 COMMENTS:
 	This routine calculates the crc high and low byte of a message.
 	Note that this crc is only used for Modbus, not Modbus+ etc.
unsigned int crc(unsigned char *buf, unsigned char start,
unsigned char cnt)
        unsigned char i, j;
        unsigned temp, temp2, flag;
        temp = 0xFFFF;
        for (i = start; i < cnt; i++) {
                temp = temp ^ buf[i];
                for (j = 1; j <= 8; j++) {
                        flag = temp & 0x0001;
                        temp = temp >> 1;
                        if (flag)
                                temp = temp ^ 0xA001;
        /* Reverse byte order. */
        temp2 = temp >> 8;
        temp = (temp << 8) | temp2;
        temp &= 0xFFFF;
        return (temp);
 * 	The following functions construct the required query into
 * 	a modbus query packet.
 * Start of the packet of a read_holding_register response
void build_read_packet(unsigned char slave, unsigned char function,
unsigned char count, unsigned char *packet)
        packet[SLAVE] = slave;
        packet[FUNC] = function;
        packet[2] = count * 2;
 * Start of the packet of a preset_multiple_register response
void build_write_packet(unsigned char slave, unsigned char function,
unsigned int start_addr,
        packet[START_H] = start_addr >> 8;
        packet[START_L] = start_addr & 0x00ff;
        packet[REGS_H] = 0x00;
        packet[REGS_L] = count;
 * Start of the packet of a write_single_register response
void build_write_single_packet(unsigned char slave, unsigned char function,
        unsigned int write_addr, unsigned int reg_val, unsigned char* packet)
        packet[START_H] = write_addr >> 8;
        packet[START_L] = write_addr & 0x00ff;
        packet[REGS_H] = reg_val >> 8;
        packet[REGS_L] = reg_val & 0x00ff;
 * Start of the packet of an exception response
void build_error_packet(unsigned char slave, unsigned char function,
unsigned char exception, unsigned char *packet)
        packet[FUNC] = function + 0x80;
        packet[2] = exception;
 * modbus_query( packet, length)
 * Function to add a checksum to the end of a packet.
 * Please note that the packet array must be at least 2 fields longer than
 * string_length.
void modbus_reply(unsigned char *packet, unsigned char string_length)
        int temp_crc;
        temp_crc = crc(packet, 0, string_length);
        packet[string_length] = temp_crc >> 8;
        string_length++;
        packet[string_length] = temp_crc & 0x00FF;
 * send_reply( query_string, query_length )
 * Function to send a reply to a modbus master.
 * Returns: total number of characters sent
int send_reply(unsigned char *query, unsigned char string_length)
        unsigned char i;
        if (Txenpin > 1) { // set MAX485 to speak mode
                UCSR0A=UCSR0A |(1 << TXC0);
                digitalWrite( Txenpin, HIGH);
                delay(1);
        modbus_reply(query, string_length);
        string_length += 2;
        for (i = 0; i < string_length; i++) {
                Serial.write(query[i]);
        if (Txenpin > 1) {// set MAX485 to listen mode
                while (!(UCSR0A & (1 << TXC0)));
                digitalWrite( Txenpin, LOW);
        return i; 		/* it does not mean that the write was succesful, though */
 * 	receive_request( array_for_data )
 * Function to monitor for a request from the modbus master.
 * Returns:	Total number of characters received if OK
 * 0 if there is no request
 * A negative error code on failure
int receive_request(unsigned char *received_string)
        int bytes_received = 0;
        /* FIXME: does Serial.available wait 1.5T or 3.5T before exiting the loop? */
        while (Serial.available()) {
                received_string[bytes_received] = Serial.read();
                bytes_received++;
                if (bytes_received >= MAX_MESSAGE_LENGTH)
                        return NO_REPLY; 	/* port error */
        return (bytes_received);
 * 	modbus_request(slave_id, request_data_array)
 * Function to the correct request is returned and that the checksum
 * is correct.
 * Returns:	string_length if OK
 * 		0 if failed
 * 		Less than 0 for exception errors
 * 	Note: All functions used for sending or receiving data via
 * 	      modbus return these return values.
int modbus_request(unsigned char slave, unsigned char *data)
        int response_length;
        unsigned int crc_calc = 0;
        unsigned int crc_received = 0;
        unsigned char recv_crc_hi;
        unsigned char recv_crc_lo;
        response_length = receive_request(data);
        if (response_length > 0) {
                crc_calc = crc(data, 0, response_length - 2);
                recv_crc_hi = (unsigned) data[response_length - 2];
                recv_crc_lo = (unsigned) data[response_length - 1];
                crc_received = data[response_length - 2];
                crc_received = (unsigned) crc_received << 8;
                crc_received =
                        crc_received | (unsigned) data[response_length - 1];
                /*********** check CRC of response ************/
                if (crc_calc != crc_received) {
                        return NO_REPLY;
                /* check for slave id */
                if (slave != data[SLAVE]) {
                        return NO_REPLY;
        return (response_length);
 * 	validate_request(request_data_array, request_length, available_regs)
 * Function to check that the request can be processed by the slave.
 * Returns:	0 if OK
 * 		A negative exception code on error
int validate_request(unsigned char *data, unsigned char length,
        int i, fcnt = 0;
        unsigned int regs_num = 0;
        unsigned int start_addr = 0;
        unsigned char max_regs_num;
        /* check function code */
        for (i = 0; i < sizeof(fsupported); i++) {
                if (fsupported[i] == data[FUNC]) {
                        fcnt = 1;
        if (0 == fcnt)
                return EXC_FUNC_CODE;
        if (FC_WRITE_REG == data[FUNC]) {
                /* For function write single reg, this is the target reg.*/
                regs_num = ((int) data[START_H] << 8) + (int) data[START_L];
                if (regs_num >= regs_size)
                        return EXC_ADDR_RANGE;
                return 0;
        /* For functions read/write regs, this is the range. */
        regs_num = ((int) data[REGS_H] << 8) + (int) data[REGS_L];
        /* check quantity of registers */
        if (FC_READ_REGS == data[FUNC])
                max_regs_num = MAX_READ_REGS;
        else if (FC_WRITE_REGS == data[FUNC])
                max_regs_num = MAX_WRITE_REGS;
        if ((regs_num < 1) || (regs_num > max_regs_num))
                return EXC_REGS_QUANT;
        /* check registers range, start address is 0 */
        start_addr = ((int) data[START_H] << 8) + (int) data[START_L];
        if ((start_addr + regs_num) > regs_size)
        return 0; 		/* OK, no exception */
 * 	write_regs(first_register, data_array, registers_array)
 * 	writes into the slave's holding registers the data in query,
 * starting at start_addr.
 * Returns:   the number of registers written
int write_regs(unsigned int start_addr, unsigned char *query, int *regs)
        int temp;
        unsigned int i;
        for (i = 0; i < query[REGS_L]; i++) {
                /* shift reg hi_byte to temp */
                temp = (int) query[(BYTE_CNT + 1) + i * 2] << 8;
                /* OR with lo_byte           */
                temp = temp | (int) query[(BYTE_CNT + 2) + i * 2];
                regs[start_addr + i] = temp;
        return i;
 * 	preset_multiple_registers(slave_id, first_register, number_of_registers,
 * data_array, registers_array)
 * 	Write the data from an array into the holding registers of the slave.
int preset_multiple_registers(unsigned char slave,
int *regs)
        unsigned char function = FC_WRITE_REGS;	/* Preset Multiple Registers */
        int status = 0;
        unsigned char packet[RESPONSE_SIZE + CHECKSUM_SIZE];
        build_write_packet(slave, function, start_addr, count, packet);
        if (write_regs(start_addr, query, regs)) {
                status = send_reply(packet, RESPONSE_SIZE);
        return (status);
 * write_single_register(slave_id, write_addr, data_array, registers_array)
 * Write a single int val into a single holding register of the slave.
int write_single_register(unsigned char slave,
        unsigned int write_addr, unsigned char *query, int *regs)
        unsigned char function = FC_WRITE_REG; /* Function: Write Single Register */
        int status = 0;
        unsigned int reg_val;
        reg_val = query[REGS_H] << 8 | query[REGS_L];
        build_write_single_packet(slave, function, write_addr, reg_val, packet);
        regs[write_addr] = (int) reg_val;
        written.start_addr=write_addr;
        written.num_regs=1;
        return (status);
 * 	read_holding_registers(slave_id, first_register, number_of_registers,
 * registers_array)
 * reads the slave's holdings registers and sends them to the Modbus master
int read_holding_registers(unsigned char slave, unsigned int start_addr,
unsigned char reg_count, int *regs)
        unsigned char function = 0x03; 	/* Function 03: Read Holding Registers */
        int packet_size = 3;
        int status;
        unsigned int i;
        unsigned char packet[MAX_MESSAGE_LENGTH];
        build_read_packet(slave, function, reg_count, packet);
        for (i = start_addr; i < (start_addr + (unsigned int) reg_count);
	       i++) {
                        packet[packet_size] = regs[i] >> 8;
                packet_size++;
                packet[packet_size] = regs[i] & 0x00FF;
                packet_size++;
        status = send_reply(packet, packet_size);
        return (status);
        Serial.begin(baud);
        switch (parity) {
        case 'e': // 8E1
                UCSR0C |= ((1<<UPM01) | (1<<UCSZ01) | (1<<UCSZ00));
                //      UCSR0C &= ~((1<<UPM00) | (1<<UCSZ02) | (1<<USBS0));
        case 'o': // 8O1
                UCSR0C |= ((1<<UPM01) | (1<<UPM00) | (1<<UCSZ01) | (1<<UCSZ00));
                //      UCSR0C &= ~((1<<UCSZ02) | (1<<USBS0));
        case 'n': // 8N1
                UCSR0C |= ((1<<UCSZ01) | (1<<UCSZ00));
                //      UCSR0C &= ~((1<<UPM01) | (1<<UPM00) | (1<<UCSZ02) | (1<<USBS0));
        default:
        if (txenpin > 1) { // pin 0 & pin 1 are reserved for RX/TX
                Txenpin = txenpin; /* set global variable */
                pinMode(Txenpin, OUTPUT);
                digitalWrite(Txenpin, LOW);
        return;
unsigned long Nowdt = 0;
unsigned int lastBytesReceived;
const unsigned long T35 = 5;
        unsigned char query[MAX_MESSAGE_LENGTH];
        unsigned char errpacket[EXCEPTION_SIZE + CHECKSUM_SIZE];
        unsigned int start_addr;
        int exception;
        int length = Serial.available();
        unsigned long now = millis();
        if (length == 0) {
                lastBytesReceived = 0;
                return 0;
        if (lastBytesReceived != length) {
                lastBytesReceived = length;
                Nowdt = now + T35;
                return 0;
        if (now < Nowdt)
                return 0;
        length = modbus_request(slave, query);
        if (length < 1)
                return length;
        exception = validate_request(query, length, regs_size);
        if (exception) {
                        build_error_packet(slave, query[FUNC], exception,
                        errpacket);
                        send_reply(errpacket, EXCEPTION_SIZE);
                        return (exception);
        start_addr = ((int) query[START_H] << 8) +
                      (int) query[START_L];
        switch (query[FUNC]) {
                case FC_READ_REGS:
                        return read_holding_registers(slave,
                        start_addr,
                        query[REGS_L],
                        regs);
                case FC_WRITE_REGS:
                        return preset_multiple_registers(slave,
                        start_addr,
                        query[REGS_L],
                        query,
                        regs);
                case FC_WRITE_REG:
                        write_single_register(slave,
                        start_addr,
                        query,
                        regs);
