Magnetic Pickup Sensor
Hello All,
Brief Background on my project. I have a magnetic pickup sensor: https://www.eddevices.com/Manuals/4.5015U.pdf
that I am using with and optocoupler 817 module since the mag sensor is 12v.
My first question, sorry if its a newbie question, but the mag sensor is already powered and grounded to another circuit and so is the signal out, when i attempt to measure the Hz reading using a multimeter the Hz reading drops to zero as soon as i connect the negative lead to the common ground of the existing circuit, but if I leave the negative lead disconnected and only measure with the positive lead at the signal out pin I can read Hz. Why is that?? I've always been told you need to have a common ground to read a digital signal.
Thanks in advance
Read the data sheet , again, that you linked to. The output requires a pull-up voltage, see the output 0-10v NPN?
Anything you are getting on your DVM is from the leads acting as antennas.
Why an optocoupler? Connect your Arduino directly to an input-pullup pin and to the Arduino ground and write a program to read the pin and serial-Print the result. Test the sensor with a piece of steel.
I was told to use an optocoupler since the magnetic pickup is powered by 7.5 - 30 vdc and the arduino outputs 5v, is this not accurate?
sorry i meant 0-10v output off of the mag sensor
The only physical connection between the 7.5-30 vdc is the ground connection. The output means you can apply up to 10 volts. Your Arduino with input-Pullup will apply 5 volts, which is within the 0-10v specification. The device likely already has an optocoupler built into it.
So just to see if i'm understanding correctly
  1. I can get rid of the 817 module?
  2. The only physical connection coming off of the sensor to the arduino would be signal out with a pull up resistor or the input-pullup function correct?
The grounds must be connected too.
Hi, @ecnirp626
Welcome to the forum.
Can you please post a copy of your circuit a picture of a hand drawn circuit in jpg, png?
Some images of your project would be great also?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
