I'm working on a project for measure the water level of my underground tank. I'm using HC SR04 ultrasonic sensor for the measurement, now I've think that inside the tank the humidity will be very high, so how can I make water proof the sensor? From what I understand the ultrasonic sensors can't be covered,someone has tried it? Thanks
Hi, i am looking for a moisture resistant HCSR04 ultrasonic sensor to measure water level in a tank, did anyone solve this problem?? Which one of the Futurlec water resistant capsule are ok to change with the original one? US1440 model should be right..?
Thanks for any help!!
Marco
marcoblacks:
Marco
If you look at DIY methods, you should cover the two cans with a protective material with thickness=1/2 wavelength.
Knowing that the frequency of the device is 40kHz, your solution would be a Plexiglas plate of 2.125cm
pierbiag:
Not going to work at all. You have no understanding of ultrasound in air.
[ the acoustic impedance of air and a solid is about 4 orders of magnitude different, any diaphragm
must is very thin indeed to have low enough mass not to just 100% reflect ]
Bringamosa:
I habe a IBC tank outside with on top of that a terra cotta plants pot upside down and in the my sensor.
That works pretty good for about a year now
I also have a water tank with the sensor mounted on its top screw cover facing the water. It works for about a year before he connecrions get oxidised from the moisture and some wire gets disconnected. Then i have to replace it.
I now plan a similar approach to monitor water level in my pool reservoir balancing tank. In this case however the sensor might actually come in contact with water so waterproofing is needed.
I have the pot lifted up for about 2 cm for a bit of ventilation. But if it will come in contact with water i gues i just have to look for some more expensive waterproof modules
Watcher:
Has anyone actually tried to just replace the two senors on the hc sr04 pcb with these waterproof ones?
Yes. I did. but they did not work. i could hear the vibrating sound on the sensor but the reading it was giving was not correct. This is probably due to that these sensors work on 12v . Anyhow , did you find any solution to that because humidity just kills this sensor.!
Oops, after a couple of months of service also my ultrasonic device gave up on me. The little dish inside the speakers came loose and messed everything up.
Bringamosa:
Ordered a waterproof one now, works like a charm
@Bringamosa how did you use waterproof sensor? Can you tell how you connected those waterproof sensor to a board and code?
With HCSR04 we have board for sensor. How did you make board for waterproof sensor? Did you use JSNSR04 2.0 or made your own board with waterproof sensors?
You quoted me, "Ordered a waterproof one now, works like a charm" the HCSR04 is not waterproof. The JSNR04 is waterproof, worked for a while but but also had bad readings so I want just for hall effect switchs for my water levels
Bringamosa:
I thought you bought waterproof transducers and worked on that. Even I bought waterproof JSN but it works fine only when powered with 5v directly, when powered with 12->Buckconverter->5v it does not give consistent readings.
Do you have any idea of how to use waterproof transducers?
I had multiple JSN-SR04T and all of them had an issue with my water tank: They reported the right value, until the water levels dropped far enough and then only measured 20cm. I don't know if it bouned back off the walls or what it was, but nah. The tank isn't even that big. Maybe 1m in height.
