Making a Spirit box with the TEA5767 radio module
Hey guys n girls, so im trying to build and program a spirit box with the TEA5767 radio chip, and im trying to include a couple functions:
-A potentiometer to adjust the scanning speed
  • A switch button that when on HIGH it will scan upwards, when on LOW it will scan downards through the FM frequencies
  • A button that when on LOW scans through the FM frequencies in a random pattern
This is my code so far:
#include <TEA5767Radio.h>
#include <Wire.h>
TEA5767Radio radio = TEA5767Radio();
int speedPotPin = A3;
  Wire.begin();
  pinMode(A3, INPUT_PULLUP);
  int Val = analogRead(speedPotPin);
  float potVal = ( Val / 1023.0) * 0.9;
  float minVal = 0.1;
  float maxVal = 1.0;
  int delayVal = (potVal + minVal);
  for (int i = 850 ; i < 1080 ; i++ )
    float freq = i / 10.0 ;
    radio.setFrequency(freq);
    delay(delayVal);
    Serial.println(i);                   // For checking the frequency scan speed
At the moment im stuck on getting the potentiometer to work properly, right now it doesnt increase or decrease the scan speed. I think the error is in the delay function and how i'm trying to set it up.
Could someone help me to get this scan speed potentiometer to work properly ?
You have declared the pin A3 as a digital input ( pinMode(A3, INPUT_PULLUP); ). But you want to use it as an analog input...
Take a look at the Arduino reference: analogRead() - Arduino Reference
E40racer:
Ok i have updated the code, i've changed the delay value in the for loop, changed the value from delayVal ( which it doesnt seem to be able to use ?? ) to just Val, now the potentiometer does actually work, but the scan speed increase only applies after i reset the arduino ?
Delay will only take an unsigned long value, not a float. delay() - Arduino Reference
CanniBull33:
...but not posted it.
AWOL:
Code is on its way im editing it so ive got everything set up correctly
Okay i cant get it to work, current code is
#include <Wire.h>
int speedPotPin= A3;
  Wire.begin();
  int value = analogRead(A3);
  float potRatio = (value / 1023.0) * 0.9;
  float minVal = 0.1;
  float maxVal = 1.0;
  float delayVal = (potRatio + minVal);
    float freq = i/10.0 ;
    Serial.println(potRatio);
How do i get the
  float minVal = 0.1;
  float maxVal = 1.0;
portion of the code to fit into the unsigned long format so it works for delay ?
