Hi everyone!
Well I am new to the forums, arduino and programming etc, but ready to learn.
I come here as I know the versatility of these little boards and all other routes have fizzled out.
Let me start with what I am trying to accomplish:
Mimic the function of an existing PWM circuit controlling a solenoid inside a transmission.
Operation: 12V (14V running) @ fixed 50Hz, PWM controlled where 95% duty cycle = 0.95 A.
12.6 Ohms across the solenoid and circuit.
*One very important characteristic of this circuit is it has to be high side switched.
There is no access to the ground side of this solenoid, it is grounded inside the transmission.
I am definitely not about to tear into it just so I can get access to the ground wire.
This is the one thing that has been the big hang up.
Currently the transmission controller obviously tells this particular solenoid how to operate.
The higher the duty cycle the more hydraulic pressure and lockup there is.
I would like to use an Arduino and other necessarily hardware to manually command a PWM (0-100%) with a POT.
This would be the sole purpose of the Arduino.
What I would like to do is be able to switch to manual control for short periods.
I would like to know if this is at all feasible and what hardware I would need to start this project.
From the little I have taken in thus far on the Arduino, I know they can't directly control the solenoid.
This video is basically what I am trying to accomplish.
But once again the circuit I need to make has to be high side switched.
Can this be done?
Any help would be greatly appreciated!
Thanks
