Master rocker switch for 2 batteries
Hi, need a little help. I have 2 batteries that need to work separately. One for Arduino mega 2560 and the other for MB-102 power supply. The rocker switch is the master switch, when the switch is turned OFF, all have to turn OFF. And when I turn back ON, all have to turn ON. If the battery for the Arduino Mega, is low and stops working, the MB-102 power supply must keep working.
How to connect the power supply(MB102) to the master switch?
That is why double pole switches are made.
What do you mean by double-pole switches???
This should help. What is a Double Pole Switch? | Herga I also recommend you do a few tutorials on basic electronics.
What is that 9 volt battery? A PP3 fire alarm battery? If so, 6x AAA would be much better.
