Many displays use these names also for SPI.
SDA is generic for Serial Data, sometimes for input and output on same pin.
SCL is generic for Serial Clock.
If there is a DC or D/C pin, then it is for SPI, most likely
But when there is no CS pin, it looks like it is not SPI.
Finally, we found one that is SPI
So it has an SPI interface, but according to the old board it too has an SPI interface
I find that hard to believe but could still be true
Please post the details of how the old one was connected to the Arduino. Which pins on which board ?
Thankyou!
The current screen goes to the 3v3 Pin on the board and I have an on off switch with battery link on the 5v Pin on the nano.
So maybe I should put Red to the 3v3 of new screen?
Yes, I meant SCS, (Chip Select in SPI speak). I am hoping that it means Screen Chip Select
and that TCS is the Chip Select for the SD card reader but don't know the relevance of the 'T'
Ok thankyou.
Would you expect the screen to 'come to life' if just the Power & Ground are connected.
Or is this likely to need all wires in the right place to come alive?
