Matrix operations (LQR controller)
I need operate with matrices and vectors. Because I want do a LQR controller.
I found a library but it is not working:
http://www.arduino.cc/playground/Code/MatrixMath
Somebody knows how can I operate with matrix or if there are some library for that.
Thanks
That is a very vague error message,
Can you post a more explicit error and post your code / sample code that shows the problem?
Thanks for your answer.
The problem is the library, It's a copy from this directory:
The program:
#include <MatrixMath.h>
And the error:
C:\Users\Invitat\Documents\Arduino\libraries\MatrixMath/MatrixMath.h:11:22: fatal error: WProgram.h: No such file or directory
#include "WProgram.h"
For these I ask if somebody knows how i can operate, like sums and multiplication with matrices.
Thnaks
Edgard
edgardM:
If you are using such old libraries from ancient times, it may work to replace #include "WProgram.h" in the library code with:
 #include "Arduino.h"
But if you are not so lucky you might have to do other changes to the code as well.
@edgardM: You can't be using the code at Arduino Playground - MatrixMath because your error message indicates the problem is on line 11 but that line is blank. Also, the code on that page already has a fix for the Arduino.h/WProgram.h problem so you should not have seen that error message unless you were running a version of the Arduino IDE older than V1.0.0
Pete
