MAX6675 K-type thermocouple readings are too high. Why?
Hi All!
I'm playing with K-typr thermocouple (TC) and MAX6675 module. Hooked it up to Arduino Uno and loaded this example:
// this example is public domain. enjoy!
// www.ladyada.net/learn/sensors/thermocouple
#include "max6675.h"
int thermoDO = 5;
int thermoCS = 4;
int thermoCLK = 3;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
//int vccPin = 3;
//int gndPin = 2;
  // use Arduino pins
  // pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);
  //  pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);
  Serial.println("MAX6675 test");
  // wait for MAX chip to stabilize
  // basic readout test, just print the current temp
  //  Serial.print("C = ");
  Serial.println(thermocouple.readCelsius());
  // Serial.print("F = ");
  //  Serial.println(thermocouple.readFahrenheit());
  delay(250);
MAX is reading the TC, Uno is reading MAX and sending temperature readings to serial monitor in Arduino IDE.
BUT THERE IS SOMETHING WRONG!
Is says there is 25 deg C in my room! This is not true for sure so i hooked this TC to my Fluke multimeter (it has K-type TC input) and it says 19,4 deg C. I've checked analog thermometer - Fluke reading is ok.
So why do i get so wrong readings from MAX6675?
I have 5 MAX6675 modules and 10 TCs. Tried different modules w/ different TCs - same thing so i think the problem may be in the code!?
Please help me to sort it out.
I found this vid:
The guy (i don't know what is he talking about though - german...) did the same thing as I and got ca. 28 eg C reading as room ambinet temp. It looks too much as well.
I have used these modules and K thermocouples quite a bit...
See these examples:
https://arduinoinfo.mywikis.net/wiki/Brick-Temperature-Thermocouple
How are you connecting the 6675 chips? There are issues with offsets if the thermocouple connections and metals are incorrect. I use these modules:
http://www.yourduino.com/sunshop/index.php?l=product_detail&p=509
Let us know what you find...
Do you have the red wire connected to - (NEG) and yellow to + on the MAX6675?
terryking228:
See these examples:
http://arduino-info.wikispaces.com/Brick-Temperature-Thermocouple
I was trying to look at the examples that you reference but the link is broken. Can you update?
Check my MAX6675 library - GitHub - enjoyneering/MAX6675: Arduino library for 12-bit MAX6675 K-thermocouple to digital converter.
