MAX7221 dont work when connected to DIG-pin
hi!
Im trying to use a MAX7221 on a 7-segment display.
But i cant get it to work. It flashes very dim for like 0.5s then it go black.
I have tested every single LED independently with just power and a resistor and they all work fine.
I have blue LED and I use 27K resistor as Iset.
5V
3.3V forward
20mA current
If i connect the CC-pin from the 7-Segment to ground via 100Ohm it work. But i suppose its not the right way and probably will damage the chip.
Connect CC to DIG0 and it just flash dim for 0.5s and then go black.
Is it a faulty chip or do i do something wrong here?
Code:
  Basic code for using Maxim MAX7219/MAX7221 with Arduino.
  Wire the Arduino and the MAX7219/MAX7221 together as follows:
  | Arduino   | MAX7219/MAX7221 |
  | MOSI (11) | DIN (1)         |
  | SCK (13)  | CLK (13)        |
  | I/O (7)*  | LOAD/CS (12)    |
    * - This should match the LOAD_PIN constant defined below.
  For the rest of the wiring follow the wiring diagram found in the datasheet.
  Datasheet: http://datasheets.maximintegrated.com/en/ds/MAX7219-MAX7221.pdf
  Author:  Nicholas Dobie <nick@nickdobie.com>
  Date:    30 December 2013
  License: WTFPL (http://www.wtfpl.net/)
#include <SPI.h>
// What pin on the Arduino connects to the LOAD/CS pin on the MAX7219/MAX7221
#define LOAD_PIN 7
 * Transfers data to a MAX7219/MAX7221 register.
 * @param address The register to load data into
 * @param value   Value to store in the register
void maxTransfer(uint8_t address, uint8_t value) {
  // Ensure LOAD/CS is LOW
  digitalWrite(LOAD_PIN, LOW);
  // Send the register address
  SPI.transfer(address);
  // Send the value
  SPI.transfer(value);
  // Tell chip to load in data
  digitalWrite(LOAD_PIN, HIGH);
  // Set load pin to output
  pinMode(LOAD_PIN, OUTPUT);
  // Reverse the SPI transfer to send the MSB first
  SPI.setBitOrder(MSBFIRST);
  // Start SPI
  SPI.begin();
  // Run test
  // All LED segments should light up
  maxTransfer(0x0F, 0x01);
  maxTransfer(0x0F, 0x00);
  // Enable mode B
  maxTransfer(0x09, 0xFF);
  // Use lowest intensity
  maxTransfer(0x0A, 0x00);
  // Only scan one digit
  maxTransfer(0x0B, 0x00);
  // Turn on chip
  maxTransfer(0x0C, 0x01);
  // Loop through each code
  for (uint8_t i = 0; i < 0x10; ++i)
    maxTransfer(0x01, i);
Read the instructions.
Show your connections.
Show a perfectly focused photo of your setup. As a link in the posting, not using "Attachments and other options".
Post your code - using "code" tags - the first "</>" icon above the "Preview" window.
ehel:
Hi, yes it could be one of those two things, but we can't tell you which because you have not given a schematic or your sketch. Please provide both and use code tags for your sketch.
Paul
Picture and code added.
Sorry for bad picture. Hard to get a good picture with all wires.
I can't see a problem with your sketch. Your pictures are not clear and do not show the display. Can you draw a schematic? Hand drawn on paper and scanned or photo will be ok.
Try 47K instead of 27K for the iset resistor. There is a paragraph at the top of page 10 of the data sheet that talks about max current when only 1 to 3 digits are used. It says max segment current should be 10mA for 1digit, and for 3.5V Vf leds this corresponds to a 50K iset resistor.
Is it 0.5s or 1s? Your sketch performs a 1s led test at the start.
Try this change:
  maxTransfer(0x0A, 0x0F);
Also I don't see any caps in your pics. You should have 0.1uF and 10uF close to the max's power pins.
Paul__B:
  • Show your connections.
  • Show a perfectly focused photo of your setup. As a link in the posting, not using "Attachments and other options".
  • Post your code - using "code" tags - the first "</>" icon above the "Preview" window.
Ah well, I suppose one out of three isn't bad!
I will have to go and find a computer that can deal with bodgie attachments. This one wants to open them with gedit! :astonished:
