silly problem really, i hope i put it in the right part of the forum
when i try to maximize the gui window the window maximizes, but the gui remains the same size in the upper left corner, the same thing happens if i try to make it bigger by dragging.
anyone having the same problem?
is there a way to make it maximize correctly?
im running ubuntu 9.04
ask if you want a screenshot, to lazy to upload now, but i hope you understad my explanation.
edit: i tried to modify default.window.width / height in ~/.arduino/preferences.txt without any result
never had problems with the window-size on my 1280x1024 screen. I don't think there is any arduino-code that sets a maximum limit for the the window size.
Can you tell us the version of the JavaRuntime you are using?
Open a console window and run the command:
java -version
I am running the Runtime from the Ubuntu "sun-java6-bin" package on 9.04 an it works without problems.
I've had this happen to me on occasion. I normally just close the IDE and re-open (and repeat as many times as it takes for the IDE to open properly). I'm currently using openjava6-jdk but I had the same problem when using sun6. This is on kubuntu 9.04, but I had the same problem with kubuntu 8.10.
Sorry I can't help, just wanted to let you know it's not just your pc
apperently im using java5, so that might be the problem, although both arduino and processing are running smooth (exept this) but i had some problems with other java apps.
will try to install the later version later this afternoon, thanks for the tip!
