MCP1702 vs. Pololu NCP1402 for battery application
I kind of have a two part question. One for the a step-up regulator, and one for a step-down regulator.
I was contemplating on using a step-up voltage regulator to get 3.3V for a wireless module. This would allow maximum battery utilization. But I recently discovered that the Pololu NCP1402 has a pretty high 1mA quiescent current draw even if the load is only drawing a couple uA. They're not very efficient for battery powered applications unless I use the disable pin to actually turn off the regulator. But the enable pin requires HIGH signal to put the regulator to disable mode. I wish it was the other way around - sleep the regulator with a low signal and only enable the regulator when my Arduino is also out of sleep. Maybe there's a clever way to NOT the output of the Arduino?
The other option is to use a step-down regulator (MCP1702). It looks like step-down regulators don't have this inefficiency issue at low load currents. The MCP1702 only draws a couple uA overhead current when the load is a couple uA. That's pretty good. Unfortunately, with step down regulators I'll need to change out the 3xAA batteries sooner. I can't let them run all the way down, as I need the battery voltage to be 3.3 + dropout voltage. So I need at least 4V battery voltage from 3xAA, so about 1.3V from each battery. The battery comes new at 1.5V I think. Does anyone have a feel for what kind of run time I might get if for the most part everything is asleep and is only turned on 3 times day? So let's say 8uA consumption during sleep, and 100mA consumption 3 times a day for 3 seconds each incident?
Do you have a feel for which might be a better option, considering runtime on alkaline batteries?
The best way to maximize battery life is to use the battery directly and design the rest of the circuit so that the battery voltage is not so critical. Some of the low power, cheap 433 MHz transmitters work with any voltage between 2 and 12 V. Similarly, the ATmega MPUs have a pretty wide range of operating voltages (down to 1.8 V), although at the lower voltages you have to use a low clock speed.
On time of 9 seconds a day at 100ma is (9sec / 3600sec/hr * 100ma) .25maH.
Off time for the MCP1702 for the remainder of the day is (24hrs * .008ma) .048maH.
So you've got a total of .442maH/day from a 2200maH battery. That's quite a few years of runtime.
Chagrin:
Well, the battery might be rated 2200mAH, but remember I need to keep the battery voltage above 1.3V per battery, so I don't know that the battery stays above 1.3V for the entire rated 2200mAH capacity. I would guess it doesn't, but I don't have a feel for that kind of thing.
Try Discharge tests of Alkaline AA batteries 100mA to 2A
Per the 100ma, slow discharge rate which is the best match to your problem, you'll only get 600maH out of the battery before it falls below 1.3V. So that means you only get 3.7 years of runtime.
Chagrin:
hehe, thanks! That's a really handy graph
