Hey guys,
I am using a mcp2515 module over the SPI-bus with the mcp2515.h library with the following code:
#include <SPI.h>
#include <mcp2515.h>
struct can_frame canMsg1; //UQS-Message 1; CatalystReagentTemperature2, CatalystReagentConcentration
struct can_frame canMsg2; //UQS-Mesage 2; AT1SCRCatalystTankLevel, AT1SCRCatalystTankLevel2, AT1SCRCatalystTankTemperature
MCP2515 mcp2515(53); //Chip-Select
//Values CAN-Messages
int crt2, ctt; //Dezimal
double crc, ctl, ctl2;
byte crt2_b, ctt_b, crc_b, ctl_b, ctl2_b1, ctl2_b2; //Binär
unsigned short ctl2_b;
while (!Serial);
mcp2515.reset();
mcp2515.setBitrate(CAN_500KBPS, MCP_8MHZ); //Set Baud-Rate corresponding to Engine subnet //WRONG BAUDRATE!
mcp2515.setNormalMode();
canMsg1.can_id = 0x18FD9BA3 | CAN_EFF_FLAG; //Extended Frame with 29-Bit ID (SAE J1939)
canMsg1.can_dlc = 8; //8 Byte Data Length
canMsg2.can_id = 0x18FE56A3 | CAN_EFF_FLAG;
canMsg2.can_dlc = 8;
//Values
crt2=-21; //Temperature in °C, tank and catalyst get same value
crc=13; //Catalyst Concentration in %
ctl=93.7; //Tank level in %
ctl2=312.0; //Tank level in mm
//Message-Calculation
crt2_b=ctt_b=(byte)(crt2+40);
crc_b=(byte)(4*crc);
ctl_b=(byte)(2.5*ctl);
ctl2_b=(short)(10*ctl2);
ctl2_b1=ctl2_b>>8; //zweites Byte wegschieben
ctl2_b2=ctl2_b&0x00FF; //erstes Byte löschen
canMsg1.data[0] = crt2_b; //0x41;
canMsg1.data[1] = crc_b; // 0x7B;
canMsg1.data[2] = 0xFF; //constant Standard-signals
canMsg1.data[3] = 0xFF;
canMsg1.data[4] = 0xFF;
canMsg1.data[5] = 0xF3;
canMsg1.data[6] = 0xFF;
canMsg1.data[7] = 0xFF;
canMsg2.data[0] = ctl_b; // 0x4D;
canMsg2.data[1] = ctt_b; // 0x45;
canMsg2.data[2] = ctl2_b2; //0x10;
canMsg2.data[3] = ctl2_b1; //0x04;
canMsg2.data[4] = 0xFF; //Standard-signals
canMsg2.data[5] = 0xFF;
canMsg2.data[6] = 0xFF;
canMsg2.data[7] = 0xFF;
Serial.println("Example: Write to CAN");
Serial.println(ctt_b);
Serial.println(crt2_b);
if (mcp2515.sendMessage(&canMsg1) == MCP2515::ERROR_OK) Serial.println("Messages sent");
else Serial.println("Msg1 TX error");
if (mcp2515.sendMessage(&canMsg2) == MCP2515::ERROR_OK) Serial.println("Messages sent");
else Serial.println("Msg2 TX error");
The code works completely fine with the Arduino UNO (CS for UNO is set to 10), but not with the with the MEGA. It has nothing to do with the module itself, since I get "Msg1 TX error" and "Msg2 TX error" in the Serial monitor although its exactly the same code for both.
Does the library not work with the MEGA or am I missing something?
