Hallo zusammen
I tried to conntect two Arduino Mega with two joy-it MCP 2515 can modules.
I use the mcp2515.h library, the standard test programm and also the standard connections. The onls difference is that they use a UNO instead of the MEGA I use.
Connections:
int => D2 5V measured
SCK => D13 0V measured
Sl => D11 0V measured
SO => D12 0V measured
CS => D10
At the CS pin (10) I can read a signal with the oszilloskop.KO It does not change the shape if I change the Baudrate!?! It does change if I delete one message in the send sketch and it also changes if I add a delay inbetween the two messages.
I cannot measure any signal on the other pins!?!
GND => GND
VCC1=> 5V
VCC => 5V
CanH and CanL are at about 2.3 V. No "signals" measured.
In one post I read that with the MEGA instead of the UNO not all baudrates work. There it's told that one should change from 550k to 250K! I have tested all rates without any changes.
Another post tells to change pins!?!? 50, 51, ... instead of the 10 to 13!?!?
Programm to send: (Standard Library!)
#include <SPI.h>
#include <mcp2515.h>
struct can_frame canMsg1;
struct can_frame canMsg2;
MCP2515 mcp2515(10);
while (!Serial);
Serial.begin(112500);
SPI.begin();
mcp2515.reset();
mcp2515.setBitrate(CAN_250KBPS);
mcp2515.setNormalMode();
Serial.println("Example: Write to CAN");
canMsg1.can_id = 0x0FF;
canMsg1.can_dlc = 8;
canMsg1.data[0] = 0xFF;
canMsg1.data[1] = 0xFF;
canMsg1.data[2] = 0xFF;
canMsg1.data[3] = 0xFF;
canMsg1.data[7] = 0x00;
canMsg2.can_id = 0x000;
canMsg2.can_dlc = 8;
canMsg2.data[0] = 0x00;
canMsg2.data[1] = 0x00;
canMsg2.data[2] = 0x00;
canMsg2.data[3] = 0x00;
canMsg2.data[4] = 0x00;
canMsg2.data[5] = 0x00;
canMsg2.data[6] = 0x00;
canMsg2.data[7] = 0x00;
if (mcp2515.sendMessage(&canMsg1) == MCP2515::ERROR_OK){
Serial.println("Messages sent");
else {
Serial.println("Msg1 TX error");
if (mcp2515.sendMessage(&canMsg2) == MCP2515::ERROR_OK) {
else {
Serial.println("Msg2 TX error");
[Code]
Code for reading:
[code]
#include <SPI.h>
struct can_frame canMsg;
SPI.begin();
mcp2515.reset();
Serial.println("------- CAN Read ----------");
Serial.println("ID DLC DATA");
if (mcp2515.readMessage(&canMsg) == MCP2515::ERROR_OK) {
Serial.print(canMsg.can_id, HEX); // print ID
Serial.print(" ");
Serial.print(canMsg.can_dlc, HEX); // print DLC
Serial.print(" ");
for (int i = 0; i<canMsg.can_dlc; i++) { // print the data
Serial.print(canMsg.data[i],HEX);
Serial.print(" ");
