MCP_CAN Library talking to VAG car
Hello everyone, I am trying to talk to the ECU on my 2005.5 Audi A4 to pulled the coolant temp information.
The ECU is from a 2001 but the rest of the car is 2005.5.
I know the CAN BUS communication works to the ECU because I can talk to it and I can pull the needed data from VCDS.
I cam across coryjfowler MCP_CAN Library and it looked perfect for what I needed.
I ran his sketch "sketch_jul19a" but never could get talk to the car its self.
I am using an Arduino UNO and connected to a low cost MCP2515 "HW-184" module.
I am connected to the High and Low CAN pins on the OBDII port of the car.
I have adjusted the coder for my 8Mhz module.
The code compiles and uploaded to the Arduino fine and I do get information on the serial monitor.
The only information I am getting after making a connecting to the MCP2515 chip is "Error Sending Message..."
I have tried connecting to a 2004 A4 along with a 2008 golf with the same results.
I have also tired to adjust my Baud speed form 500kbs to 100kbs with the same results.
I am guessing I have something setup wrong but not sure where to start for debugging.
Output:@115200
Entering Configuration Mode Successful!
Setting Baudrate Successful!
MCP2515 Initialized Successfully!
Starting to Set Mask!
Setting Mask Successful!
Starting to Set Filter!
Setting Filter Successfull!
Sending and Receiving OBD-II_PIDs Example...
Sketch:
// Service 01 PIDs (more detail: https://en.wikipedia.org/wiki/OBD-II_PIDs)
#define PID_ENGINE_LOAD 0x04
#define PID_COOLANT_TEMP 0x05
#define PID_SHORT_TERM_FUEL_TRIM_1 0x06
#define PID_LONG_TERM_FUEL_TRIM_1 0x07
#define PID_SHORT_TERM_FUEL_TRIM_2 0x08
#define PID_LONG_TERM_FUEL_TRIM_2 0x09
#define PID_FUEL_PRESSURE 0x0A
#define PID_INTAKE_MAP 0x0B
#define PID_ENGINE_RPM  0x0C
#define PID_VEHICLE_SPEED 0x0D
#define PID_TIMING_ADVANCE 0x0E
#define PID_INTAKE_TEMP 0x0F
#define PID_MAF_FLOW 0x10
#define PID_THROTTLE 0x11
#define PID_AUX_INPUT 0x1E
#define PID_RUNTIME 0x1F
#define PID_DISTANCE_WITH_MIL 0x21
#define PID_COMMANDED_EGR 0x2C
#define PID_EGR_ERROR 0x2D
#define PID_COMMANDED_EVAPORATIVE_PURGE 0x2E
#define PID_FUEL_LEVEL 0x2F
#define PID_WARMS_UPS 0x30
#define PID_DISTANCE 0x31
#define PID_EVAP_SYS_VAPOR_PRESSURE 0x32
#define PID_BAROMETRIC 0x33
#define PID_CATALYST_TEMP_B1S1 0x3C
#define PID_CATALYST_TEMP_B2S1 0x3D
#define PID_CATALYST_TEMP_B1S2 0x3E
#define PID_CATALYST_TEMP_B2S2 0x3F
#define PID_CONTROL_MODULE_VOLTAGE 0x42
#define PID_ABSOLUTE_ENGINE_LOAD 0x43
#define PID_AIR_FUEL_EQUIV_RATIO 0x44
#define PID_RELATIVE_THROTTLE_POS 0x45
#define PID_AMBIENT_TEMP 0x46
#define PID_ABSOLUTE_THROTTLE_POS_B 0x47
#define PID_ABSOLUTE_THROTTLE_POS_C 0x48
#define PID_ACC_PEDAL_POS_D 0x49
#define PID_ACC_PEDAL_POS_E 0x4A
#define PID_ACC_PEDAL_POS_F 0x4B
#define PID_COMMANDED_THROTTLE_ACTUATOR 0x4C
#define PID_TIME_WITH_MIL 0x4D
#define PID_TIME_SINCE_CODES_CLEARED 0x4E
#define PID_ETHANOL_FUEL 0x52
#define PID_FUEL_RAIL_PRESSURE 0x59
#define PID_HYBRID_BATTERY_PERCENTAGE 0x5B
#define PID_ENGINE_OIL_TEMP 0x5C
#define PID_FUEL_INJECTION_TIMING 0x5D
#define PID_ENGINE_FUEL_RATE 0x5E
#define PID_ENGINE_TORQUE_DEMANDED 0x61
#define PID_ENGINE_TORQUE_PERCENTAGE 0x62
#define PID_ENGINE_REF_TORQUE 0x63
#define CAN_ID_PID 0x7DF //OBD-II CAN frame ID
#include <mcp_can.h>
#include <SPI.h>
#define CAN0_INT 2                              // Set INT to pin 2  <--------- CHANGE if using different pin number
MCP_CAN CAN0(10);                               // Set CS to pin 10 <--------- CHANGE if using different pin number
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
char msgString[128];                        // Array to store serial string
void sendPID(unsigned char __pid)
  unsigned char tmp[8] = {0x02, 0x01, __pid, 0, 0, 0, 0, 0};
  byte sndStat = CAN0.sendMsgBuf(CAN_ID_PID, 0, 8, tmp);
  if (sndStat == CAN_OK) {
    Serial.print("PID sent: 0x");
    Serial.println(__pid, HEX);
  else {
    Serial.println("Error Sending Message...");
void receivePID(unsigned char __pid)
    if (!digitalRead(CAN0_INT)) {                      // If CAN0_INT pin is low, read receive buffer
    CAN0.readMsgBuf(&rxId, &len, rxBuf);      // Read data: len = data length, buf = data byte(s)
    sprintf(msgString, "Standard ID: 0x%.3lX, DLC: %1d, Data: ", rxId, len);
    Serial.print(msgString);
    for (byte i = 0; i < len; i++) {
      sprintf(msgString, " 0x%.2X", rxBuf[i]);
    Serial.println("");
    switch (__pid) {
      case PID_COOLANT_TEMP:
        if(rxBuf[2] == PID_COOLANT_TEMP){
          uint8_t temp;
          temp = rxBuf[3] - 40;
          Serial.print("Engine Coolant Temp (degC): ");
          Serial.println(temp, DEC);
      case PID_ENGINE_RPM:
        if(rxBuf[2] == PID_ENGINE_RPM){
          uint16_t rpm;
          rpm = ((256 * rxBuf[3]) + rxBuf[4]) / 4;
          Serial.print("Engine Speed (rpm): ");
          Serial.println(rpm, DEC);
  // Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
  if (CAN0.begin(MCP_NORMAL, CAN_500KBPS, MCP_8MHZ) == CAN_OK) { //< -------- - CHANGE if using different board
    Serial.println("MCP2515 Initialized Successfully!");
  else {
    Serial.println("Error Initializing MCP2515...");
    while (1);
  //initialise mask and filter to allow only receipt of 0x7xx CAN IDs
  CAN0.init_Mask(0, 0, 0x07000000);              // Init first mask...
  CAN0.init_Mask(1, 0, 0x07000000);              // Init second mask...
  for (uint8_t i = 0; i < 6; ++i) {
    CAN0.init_Filt(i, 0, 0x07000000);           //Init filters
  CAN0.setMode(MCP_NORMAL);                     // Set operation mode to normal so the MCP2515 sends acks to received data.
  pinMode(CAN0_INT, INPUT);                    // Configuring pin for /INT input
  Serial.println("Sending and Receiving OBD-II_PIDs Example...");
  //request coolant temp
  sendPID(PID_COOLANT_TEMP);
  delay(40); //to allow time for ECU to reply
  receivePID(PID_COOLANT_TEMP);
  //request engine speed
  sendPID (PID_ENGINE_RPM);
  receivePID(PID_ENGINE_RPM);
  //abitrary loop delay
  delay(40);
After doing some reading I think I need a handshake step for the CAN BUS Gateway. That way the gateway makes the request to the ECU for the information I want.
reao:
Are you sure that didn't use K line?
reao:
That "Error Sending Message" indicates to me that it is not connected to an active CAN device. Either check your wiring or test the CAN transceiver on your interface/shield.
Every vehicle I have that has CAN, I only needed to use the receive example to see the existing CAN traffic and any OBDII PID requests were replied to immediately.
reao:
The speeds for OBD2 by legislation should only be 250k or 500k.
Thank you for the reply.
Based on what I have been reading the ECU has both K-wire and CAN BUS.
http://www.volkspage.net/technik/ssp/ssp/SSP_238.pdf
The ECU its self does have a K-wire and a set of CAN BUS wires coming off of it.
The exact data I am looking for is engine coolant temp. I thought that ran on the CAN BUS because the cluster uses CAN for the temp gauge.
I can see this data when reading the ECU blocks in VCDS.
But maybe that information is coming in on the K-Wire for VCDS.
What made me think I could get the data I needed form CAN BUS was this product here.
This box is using CAN BUS to look at the engine temp for controlling the radiator fans along with returning cruse control function to cars running this B5 engine swap.
When reading the install directions for this product the only connection they are making to the car that would read engine temp would be when they connect to the CAN wires, Orange/Black and Orange/Brown.
I wonder if they are pulling the temp data on the Convenience bus line.
reao:
Due to the age of the ECM, it might not have OBD2 CAN functionality available or enabled.
reao:
ArduAudi
I know through CAN sniffing on my own vehicles, there is a lot of information that is on the bus if you know how to figure it out or get lucky enough someone has published their work doing such. OBD2 is kind of a slow interface if you need something to react fast. Does your vehicle show anything when you simply monitor the CAN buses with the receive example?
Ok, big update and I feel a bit foolish.
I soldered some header pins on the end of the CAN wires I am using to connect to the OBDII.
Before I was just pushing the wires into the port.
Now I do have some communication.
I think you are correct on the ECU being too old for the OBDII diagnostic CAN BUS.
Here is the output from the Jul19 code you created.
PID sent: 0x5
PID sent: 0xC
PID sent: 0x5
PID sent: 0xC
PID sent: 0x5
PID sent: 0xC
PID sent: 0x5
PID sent: 0xC
PID sent: 0x5
PID sent: 0xC
PID sent: 0x5
PID sent: 0xC
PID sent: 0x5
PID sent: 0xC
PID sent: 0x5
PID sent: 0xC
PID sent: 0x5
PID sent: 0x5
PID sent: 0xC
PID sent: 0x5
PID sent: 0xC
PID sent: 0x5
PID sent: 0xC
PID sent: 0x5
PID sent: 0xC
The PID is being sent but nothing is returning.
However, When using the CAN receive code in the library I am getting a lot of data back.
MCP2515 Library Receive Example...
Standard ID: 0x5C6       DLC: 8  Data: 0x00 0xC0 0x05 0x00 0x10 0x00 0x00 0x2B
Standard ID: 0x050       DLC: 4  Data: 0x00 0xA4 0x68 0xCC
Standard ID: 0x488       DLC: 8  Data: 0x00 0x53 0x53 0x68 0xA6 0x00 0x00 0x00
Standard ID: 0x0C2       DLC: 8  Data: 0x00 0x80 0x00 0x80 0x00 0x8A 0x00 0x75
Standard ID: 0x38A       DLC: 4  Data: 0x55 0x01 0x54 0x00
Standard ID: 0x0C2       DLC: 8  Data: 0x00 0x80 0x00 0x80 0x00 0xAA 0x00 0x55
Standard ID: 0x320       DLC: 8  Data: 0x41 0x00 0x80 0x01 0x00 0x00 0x00 0x00
Standard ID: 0x0C2       DLC: 8  Data: 0x00 0x80 0x00 0x80 0x00 0xCA 0x00 0x35
Standard ID: 0x38A       DLC: 4  Data: 0x75 0x01 0x74 0x00
Standard ID: 0x0C2       DLC: 8  Data: 0x00 0x80 0x00 0x80 0x00 0xEA 0x00 0x15
Standard ID: 0x288       DLC: 8  Data: 0xFC 0x5F 0x12 0x00 0x00 0x7B 0x68 0x10
Standard ID: 0x050       DLC: 4  Data: 0x00 0xA4 0xA8 0x0C
Standard ID: 0x0C2       DLC: 8  Data: 0x00 0x80 0x00 0x80 0x00 0x0A 0x00 0xF5
Standard ID: 0x5A0       DLC: 8  Data: 0x82 0x00 0x00 0x03 0xE1 0x00 0x10 0xAD
Standard ID: 0x050       DLC: 4  Data: 0x00 0xA4 0xB8 0x1C
Standard ID: 0x38A       DLC: 4  Data: 0x08 0x00 0x08 0x00
Standard ID: 0x0C2       DLC: 8  Data: 0x00 0x80 0x00 0x80 0x00 0x2A 0x00 0xD5
Standard ID: 0x38A       DLC: 4  Data: 0xA5 0x01 0xA4 0x00
Standard ID: 0x0C2       DLC: 8  Data: 0x00 0x80 0x00 0x80 0x00 0x4A 0x00 0xB5
Standard ID: 0x38A       DLC: 4  Data: 0xB5 0x01 0xB4 0x00
Standard ID: 0x0C2       DLC: 8  Data: 0x00 0x80 0x00 0x80 0x00 0x6A 0x00 0x95
Standard ID: 0x1A0       DLC: 8  Data: 0x00 0x17 0x00 0x00 0xFE 0xFE 0x00 0x51
Standard ID: 0x050       DLC: 4  Data: 0x00 0xA4 0xE8 0x4C
Standard ID: 0x5E0       DLC: 8  Data: 0x20 0x94 0x05 0x03 0x00 0x00 0x89 0x00
Standard ID: 0x4A0       DLC: 8  Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Standard ID: 0x050       DLC: 4  Data: 0x00 0xA4 0xF8 0x5C
Standard ID: 0x38A       DLC: 4  Data: 0x48 0x00 0x48 0x00
Standard ID: 0x572       DLC: 1  Data: 0x07
Standard ID: 0x050       DLC: 4  Data: 0x00 0xA4 0x08 0xAC
Standard ID: 0x38A       DLC: 4  Data: 0x58 0x00 0x58 0x00
Standard ID: 0x38A       DLC: 4  Data: 0xF5 0x01 0xF4 0x00
I would just need to find out what ID is for the engine temp.
The goal of the project is to read the engine temp form the ECU and contrail the radiator fans.
The motor that was swapped into the car used a mechanical fan and the body only has electric fans.
The Fan computer looks of a PWM Signal for controlling the speed of the fans.
My goal is to use the CAN information for controlling the radiator fans.
Now you're getting somewhere!
I would capture some data with the engine running idle, then capture some data and unplug that sensor. Something should reflect that sensor disconnecting.
Be warned, this could trigger a fault code that you would need to reset. I've used this method to hunt down pressure sensors.
Good luck!
Thank you for your help! I will try to pin point the ID I need now.
