I disagree. The problem is related to any GFX style library that shares pins with a raw resistive TouchScreen.h panel.
@ philip_l_mega2560
Please restore your original question. e.g. click on the red pen icon in #10
From MCUFRIEND_kbv Button_simple.ino example
bool Touch_getXY(void)
TSPoint p = ts.getPoint();
pinMode(YP, OUTPUT); //restore shared pins
pinMode(XM, OUTPUT); //because TFT control pins
bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
if (pressed) {
pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width()); //.kbv makes sense to me
pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height());
return pressed;
from Adafruit_TFTLCD tftpaint_shield.ino example
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
// if sharing pins, you'll need to fix the directions of the touchscreen pins
//pinMode(XP, OUTPUT);
//pinMode(YM, OUTPUT);
// we have some minimum pressure we consider 'valid'
// pressure of 0 means no pressing!
if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
from MCUFRIEND_kbv Touch_shield_new.ino
tp = ts.getPoint(); //tp.x, tp.y are ADC values
if (tp.z > MINPRESSURE && tp.z < MAXPRESSURE) {
