Thanks Dansole, i will wait for your reply till Monday.
ZE11-C2H4 specifications are as follows:
ZE11 is a general-purpose and high-performance electrochemical module. It can detect the benzene,dimethyl benzene,ethylene oxide,chloro ethylene based on electrochemical principle, it has good selectivity and stability. A temperature sensor is built-in for temperature compensation. It has the digital output and analog voltage output at the same time which facilities the usage and calibration and shorten the development period. It is a combination of mature electrochemical detection principle and sophisticated circuit design, to meet customers' different detection needs.
Features
High sensitivity & resolution
Low power consumption & long working life
UART and analog voltage output
Good stability and excellent anti-interference ability
Temperature compensation and excellent linear output
Main Applications
Petroleum and chemical industry, environment protection filed, detection of benzene,dimethyl benzene,ethylene oxide,chloro ethylene and vinyl benzene
Technical Parameters
Model: ZE11
Detection Target: benzene,dimethyl benzene, ethylene oxide,chloro ethylene/ ethylene
Output: UART OUTPUT ; DAC (0.4~2V standard voltage output); Sensor amplified voltage signal
Working Voltage: DC 5.0V±0.1V
Preheat time: ≤3minutes
Response Time: ≤60s
Detection Range: 0-100ppm(C2H4)
Operating Temperature: -20~50 Degrees Celsius
Dimension: Ø32mm*31.2mm
PS: The sensor we used for the ZE11 module is ME4-C2H4, but the gas calibration is done with vinyl chloride instead of ethylene and the measurement range is 0-100ppm, it also reacted to ethylene.
