I want to measure a small current of 0 to 4000 microamperes using Arduino. The existing sensors cannot measure this current. I want to use the LM358 module. Can you help me with ideas or information?
Insert
Retry
Insert
Retry
I moved your topic to an appropriate forum category @naroui .
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
The current ranger is great for the very low currents. Study it's heritage and published technical articles for inspiration.
You need to supply more details so the best method can be determined...
What accuracy?
What resolution?
Low side (ground referenced) measurement acceptable or is high side required?
What load voltage and how much can be sacrificed for measurement?
Noisy environment?
Probably lots more but that's a start.
If you use ground reference , and if your circuit allows , a 250 ohm resistor and set the internal reference to 1.1 volts that should give you full scale in the A/D at 4mA.
