Measure the light intensity (lux) of a flashing light
Hello,
I'm currently trying to measure the light intensity of a LED that flashes rapidly (my flash lasts 200ms). I was initially planning to use a photoresistance (a classic light sensors, like the Adafruit VEML7700) but I don't think its response time is good enough. I need to be able to measure the maximum of the light intensity during this brief flash. Could a photodiode or a phototransistor be the solution? I'm using the Arduino Nano card. The light intensity expected should be around 6000lux.
Thank you!
Yes.
Okay thank you, I was not precise enough in my post, but do you have a model to recommend maybe? Thanks again!
You will need a photodiode and fast photodiode amplifier. Sample and record the output using the Arduino analog input.
The circuits shown here in Figures 3 or 4 will work.
How will you calibrate it?
I don't know how I will calibrate it yet...
A phototransistor is easier to use than a photodiode. It doesn't need as much gain and it doesn't need a transconductance amplifier. You might not even need an amplifier, but I don't have a feel for that...
You'll need a known-good light meter. :wink: Obviously it doesn't need to be as fast.
Not that with the Arduino you only "sample" the analog input for an instant every time it's read (usually in a loop). But 200ms should be long-enough as long as the loop isn't doing too much "extra".
There is an op-amp circuit called a peak detector that can "hold" the peak analog voltage for a period of time. (I use peak detectors for audio.)
I built and tested this circuit so I know it works.
Photodiodes produce a leakage current that is directly proportional to
the intensity of the light. The output current vs. incident light can be
linear over 6-9 orders of magnitude.
I do have a light meter but its sample rate is 2,5 time/sec which is not so good, but that could do I think. Though the precision of my measurements won't be so great in the end, which is why I was hoping I could use a calibrated light sensor directly (VEML7700). But thank you for your help!
